Question about Dishwashers
Glasses come out dirtier than they went in to the dishwasher but other items clean OK
Glasses come out dirtier than they went in to the dishwasher. Other itmes such as plates are not a problem
  • 10,865 Answers
Remove all dishes and throw two cups of vinegar into your machine then run the complete pot scrubber cycle with the hottest water you can.
Always run the hot water into the sink until it is totally hot before you run your dishwasher.
Posted on May 20, 2009
Samsung dishwasher sprays gunk all over my glasses. When the cycle is over they are coated with dried bits of gunk. Dishes are dirtier than when they went in.
I have the same problem with gunk and spots on dishes. I took apart the parts at bottom covering the heating element. There is all sorts of gunk on everything. I cleaned it all, even under gaskets and filter screen. I am neither sure what caused it nor how to prevent it. My thinking maybe the water source. Water in my town has gotten worse in quality and has bad smell. I use a major water filter system for drinking water. My thought is that the heating element is drying the water up and leaving sediment from water.
Sep 29, 2012 | Samsung DMR57LFS Stainless Steel Builtin...
What is the best way to load the dishwasher? Glassware on top, or on bottom?
Glass where should always go on top.
larger dirtier items in base (pans etc)
Please dont forget to vote this answer was helpful
Many thanks
Feb 13, 2011 | Maytag 24 in. MDB5651A Built-in Dishwasher
After a wash cycle the dishes and glasses have a white film on them making them look dirtier than when the wash cycle started. What's the problem and what do we do?
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is toadd some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1 cup of white vinegar and it will clear up your glasses very well.
You should see marked improvement after the first time you do this. If they are not crystal clear then simply repeat the process until all of the cloudiness is gone. In fact I recommend to using a little vinegar in each cycle to maintain the clarity of the glass.
Note: you can pre-test this by rubbing some vinegar on an individual glass with a cloth. If you cannot remove the cloudiness by soaking it and rubbing vinegar on it then it is possible that the glass is etched due to harsh or cheap dishwasher detergent and vinegar will not solve the problem.
Sep 29, 2010 | Miele 24 in. Incognito G863 SCVi Built-In...
I have used dishwasher cleaners, use Cascade Complete dishwahing detergent but all of the sudden, my dishes come out of the dishwasher dirtier then they went in. The glass glasses have a gritty stuff...
depending were you live they changed the formula in cascade,but they are doin a new formula are you using a rinse agent? claean the machine clean spray arms and soap dispencer,with no dishes run machine with 1cup of CLR or 2Cup of vinegar just pour in tub and let it run full cycle no drying.Thanks
Jul 31, 2010 | Whirlpool Dishwashers
Dirty Dishes Electrolux builtin dishwasher
How long ago did you clean the filters?...are they blocked or maybe damaged letting particles through.A cherry pit should not be able to get to the pump.
Jul 20, 2010 | Electrolux 24 in. EDW5500DSS Stainless...
Not cleaning properly
This is a hard water problem and not your dishwasher. If you are on a well water then check the water softener you are using. If you are using municipal water then you might need to install a whole house water filter because chances are the rest of your house is suffering too.
Mar 13, 2010 | Dishwashers
Glasses Get Dirtier in our Maytag MDBH950AWB Dishwasher
Sounds like you have either a calcium build up or are using to much detergent. more is not always better. if you have a calcium problem you may need to run a cleaner called dishwasher magic through your dishwasher. it comes in a 12oz bottle and can be bought at sears online the part number is wx10x10200. the other thing you can try is running vinegar in a cup facing right side up on the top rack through the dishwasher to see if it helps clean anything out. if not then the dishwasher magic may be the only way to go.
Dec 29, 2008 | Maytag DWU9962 Dishwasher
Top shelf items dirtier after cleaning
After some experience with our own fdw60 with the same problem, we now put all pots and pans on the top rack. Putting them on the bottm appears to stop the clean water rinse reaching the top rack. All washes since have been ok.
Sep 23, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Not cleaning the dishes
You need to check your water temp after it enters the diswasher, it should be at least 120 deg when it get in the dishwasher. If it not then the detergent, food, and greese can't break down.
Jun 20, 2008 | GE 24 in. Profile PDW9880JSS Built-in...
Dirty glasses
there is a new product out called the dishwasher filtration system. it actually filters the water going into your dishes. the dishes look dirty because your water has a lot of calcium and magnesium in it making them appear cloudy or dirty. the dishwasher filter reduces those minerals and my dishes look perfect now. no more dirty and grimy looking dishes. i also dont waste time washing them by hand before and after the dishwasher. hahaha you can get it at www.dishwasherfilter.com. use code DFMTEN and you will get 10% off. it fits right under your sink and is very affordable. you will be glad you bought this product. thanks
Sep 29, 2007 | Tricity Bendix 24 in. BDW53 Free-standing...
Dishwashers Logo
260 people viewed this question
Top Dishwashers Experts
