Question about Fargo DTC400 ID Card Printer Package
Mis cue error - Fargo DTC400 ID Card Printer Package
2 Suggested Answers
  • 3 Answers
SOURCE: ribbon mis-cue?
When you have a ribbon mis-cue, first remove the ribbon. Go to the printer driver, printing preferences, calibrate, sensors. Click sesors then send... You should hear 2 beeps. Put you ribbon back in and try to print again.
If you still have the mis-cue it is a belt issue all DTC400's made 2006 and prior have had this belt issue. I don't recommend fixing this yourself, send it to a authorized Fargo repair center. This way it is under warranty.
Posted on Jan 14, 2009
Error iKernel.exe 0x10000
when u want to unstall it click right an execute the "Setup" as administrator
that work whith me;;
Aug 07, 2012 | eGames Cue Club for Windows
Canon printer MP560 communication error - paused printing but nothing in the cue paused
Check it:
1. Your USB cable
2. your cartridges
3. If it did not work with the other two, you have a problem with your logic board, take it to a service center.
Apr 24, 2012 | Canon MP560 All-In-One InkJet Printer
HP CUE-SCANNING FLOW COMPONENT MESSAGE EACH TIME I TRY TO SCAN A DOCUMENT
When you have the Error on the Screen - Dont close it
Click START - Click RUN - Type SERVICES.MSC - Click ok
You will find
HP Cue Device Discovery in the list - doubt click and click Disable
HPQSCX08 - Double click and Click Disable
The Error should Disappear. Close Solution Center and Re-open and try Scanning.
Jun 23, 2010 | HP DeskJet F4280 All In One Printer InkJet
Hp cue status root has stopped working
click on the start button go to start search bar and type services.msc and hit enter now a window will open look for hp cue in that and check status it should be started and automatic not mannual or automatic delayed if its started then there is a problem with the cue version of the hp software
now try downloading the driver through the link and reinstall the software
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3311800&lc=en&cc=us&dlc=en〈=en&cc=us
Jul 10, 2009 | HP Deskjet D1455 InkJet Printer
I have a problem with t644 indicated 900.00 service rip software before this error printer indicated 960 service.after turn printer off then on error code indicated immediatly
Try this...power off printer. Then if it is a network printer go the to print server and clear all the documents from the print cue. If it is a local printer clear all documents in the local print cue then power the printer back on. Once the printer powers up the error should clear, if it doesn't clear power the unit back off and ensure that all documents have been removed from the print cue then power printer back on. This worked for me on the C782e, x854e and x940e models that I have.
Jul 04, 2009 | Lexmark T644 Laser Printer
Hp CUE Status Root has stopped working ERROR
i had this prob. the "hp cue root " error isnt a hp thing, its a microsoft thing. i beleive it was caused by installing a older model printer AFTER installing a newer model. (i had a hp 2500 series,then installed drivers for a hp 1400 series)
just go to control panel, then "programs and features" , then uninstall everything that is assoiated with the printer your no longer using. just deleating the older printer from the "printers" folder won't do it. (this is assuming that you dont need both printers)
I havent gotten the error message since i did this. besides, its a good rule of thumb to not have drivers that you dont need on your machine anyways.
hope it helps
mkyckrv1
Feb 07, 2009 | HP Pavilion dv6000z Notebook
Ribbon mis-cue?
Jan 05, 2009 | Fargo DTC400 ID Card Printer Package
HP CUE Status Root Error
It appears to be a problem with HP Cue Device Discovery Service, the tray notification that tells you when your ink is low, etc.  I solved it on a Vista machine by taking Cue out of the Startup tab in msconfig.  (Could show up as HP Cue Device Discovery Service, or  hpqtray08.exe.)  Note that this will also disable the tray icon and its automatic notifications.  All it does is take Cue out of the startup list, but we don't see the error any more and it hasn't affected the printer's functions.
HP has further advice on deeper "cleaning" for the error: http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&dlc=en&docname=bpy20854
I haven't come across anything other than manual methods of getting rid of the error.  No updates or patches that I've found.
Aug 15, 2008 | Office Equipment & Supplies
Continuous error message
delete the hp cue discovery on your add/remove programs
Jul 17, 2008 | HP Photosmart C3180 All-In-One InkJet...
Fargo DTC400 ID Card Printer Package Logo
20 people viewed this question
Top Fargo Office Equipment & Supplies Experts
Safe-Card ID...
Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
