Question about LowerPriceUSA.com Computers & Internet
300 Mbps wireless adapter does not work on my XP desktop system.
Installation instructions cannot be followed exactly because the software does not auto Run, so the dialogue panel is not presented to Install the Driver. The instructions say to go to the CD and in the Driver directory run the Setup program. There is no Driver directory at the root level of the CD. If I go the WINXP directory and run Setup, it appears to Install successfully. However, the Utility does not recognize the adapter. The System Device Manager shows the adapter having an improper configuration on the driver. I cannot reinstall the driver in any manner that is successful. It's got to go back!! :-(
  • 173 Answers
SOURCE: "WPC54G is not installed"
Hai rob if ur device manager says error code 10then it seems the drivers are not installed properly for the adapter, try to update drivers, go to device manager, right clich adapter and click update driver and try to update driver, in some case ur pc may require win 2000 cd to.. check for the instructions while installing it , that would surely fix your problem..
Posted on Nov 14, 2007
SOURCE: Linksys WPC54GS wireless adapter installation issue
It sounds like you may have a band PCMCIA slot. Have you attempted to use any other expansion cards in it to test this theory?
Posted on May 10, 2008
  • 30 Answers
SOURCE: Not recognizing driver
These belkin wireless cards are version dependant, on your card it shows you what version it is, use the driver for your version.
It tells you this on the support page on belkin.com
Posted on Feb 28, 2009
gpetti2009
  • 92 Answers
SOURCE: XP does not recognize the Intel wireless network adapter
Dell has a known problem with driver conflic the best remedy is to right click on my computer click on property open hardware uninstall the driver there and restart the conputer but first make sure you download the driver from intel and burn them on a cd then when you reinstall you won't have to try to figure out if everything is downloading also in security make sure that you allow this site so that all the drivers download.
but most of the time if these driver are on a card that is micrsoft certified it will be in the driver file and will reload automaticly when you restart the computer after uninstalling and it should elimenate the driver conflic.
Posted on Apr 13, 2009
  • 20 Answers
SOURCE: Reformatted Windows XP does not recognize D-Link wireless adapter
I ran recently across the same problem and solved it by changing the PCI slot where the card was installed... it makes little sense to humans, but apparently make a world of difference to the PC hardware ;)
Assuming you had installed unsuccessfully both Card and Driver you have them (like I did) both on your PC. In such ase, the solution for me was as follows: 1) Turn Off PC 2) Remove the card from the current PCI slot 3) Turn PC back On and remove driver 4) Turn Off PC, remove power cord and wait a minute or two 5) Do not install card yet 6) Turn PC back On and install the driver 7) Turn Off PC remove power cord 8) Install the Wireless card in a different PCI slot THIS IS VERY IMPORTANT!!! Can't be the same slot as where it was installed before!!! Note: If you have none available swap PCI slots or remove a PCI card to free up a different slot for the wireless card... remove a card you need the least and in its place install the Dlink Card. You may want to hold off on installing in a second step the card you have just removed, to be on the "safest" side.
9) Once the card is installed, Power up your PC 10) Once windows will be back up and running the hardware wizard should kick in and tell you that new hardware was found. 11) Follow the on-screen instructions 12) click "Continue Anyway" when XP will warn you that the driver hasn't been signed 13) Installation should be completed after you click Finish at the end of the New Hardware Wizard process 14) Simply go to your wireless networks and make sure all works in order
(I know that this process may sound a bit "anal" in some steps, but I was no longer willing to deal with any possibility of problems of any kind as I was ready to rip that wireless card to shreds!)
I hope this will help those who struggled with reviving an old PC to give to a friend!
Posted on Sep 23, 2010
DWL-G510 cant find network
please, is there anybody who can help me with the setup cd(installation cd) for d-link airplus dwlg510.
Jun 26, 2009 | D-Link AirPlus G DWL-G510 802.11g/b...
Netgear wg111T Wireless Adapter 2.0 connectivity issues
Wireless Adapter Installation
A. Install the software.
Note: Firewall and anti-spyware need to be disabled. They sometimes treat software installation as a behavior of a spyware and therefore will prevent installation.
Windows XP:
1. Please power on your computer. Allow the operating system to boot up completely and log in as needed.
2. Insert the NETGEAR adapter Resource CD into your CD-ROM drive. The CD main page shown at the right will then load.
3. Click the Install Driver & Utility.
4. Please make sure that you follow the Install Shield Wizard steps. Click Finish when done and turn off your computer.
Windows 2000/ME/Win98SE:
Note: Windows 2000 may require you to be logged on with administrator rights.
2. Insert the NETGEAR adapter resource CD into your CD-ROM drive. The setup page will then load.
3. Afterwards, click on the Install Driver & Utility link.
4. Make sure to follow the Install Shield Wizard steps, and click Finish when done to restart your computer.
B. Install the adapter.
Windows XP:
1. Please make sure that you shut down the PC first and then remove the power cord.
2. Please insert the NETGEAR adapter into the available expansion slot.
Note: If you have PCI adapter, connect the antenna to the adapter, making sure the antenna is in the upright position.
3. Reconnect the power cord and reboot the computer.
4. When the Found New Hardware Wizard displays, please click on Next and then follow the prompt. If you are prompted with a Windows XP Logo testing message, just click on Continue Anyway.
5. After the installation completes, click Finish to close the wizard.
2. Insert the NETGEAR adapter into the available expansion slot.
4. On the Found New Hardware Wizard, click on Next, then follow the prompt to proceed.
5. After the installation completes, click Finish to close the wizard. Please make sure that you can see the NETGEAR icon located at the lower right portion of your computer screen.
Note: If Windows displays Digital Signature Not Found warning, click Yes to continue.
C. Configure the NETGEAR adapter.
1. Please Double click on the NETGEAR icon on the right lower end portion of your computer.
Note: If you do not see the icon, click on Start and go to Programs. Locate the NETGEAR Utility and click on the NETGEAR Smart Configuration Utility.
2. Click on the Networks tab.
3. Click on the Scan button.
4. Select the Network Name or SSID of your wireless network.
5. Click on the Connect button.
6. You will be directed to the Settings tab.
7. Type a name for the Profile.
8. The Network Name (SSID) will be the same with your wireless network.
9. Make sure that the Network Type is set to Access Point (Infrastructure).
10. Select the Security that you are using on your wireless router.
11. Click on Save Profile.
12. Click on the Apply button.
Jan 02, 2009 | NetGear WG111U 108 Mbps Wireless USB 2.0...
Restored factory settings on pc & cant re -instal belkin adaptor
The Belkin site has very specific instructions for installing this adapter in a pc with Vista. These instructions are at: http://www.belkin.com/support/article/?lid=en&pid=F5D9050&aid=6112&scid=0
I would first unistall any Belkin Software that has already been installed, shut down the system completely and then restart. After you have fully restarted the system then follow the Belkin Site instructions EXACTLY. Any variation is apt to mean an unsuccessful install. Good Luck and have patience.
Nov 14, 2008 | Belkin 802.11g Wireless Desktop Network...
Cannot connect to my laptop with a built in wireless.
Windows XP:
Windows XP:
Jul 13, 2008 | NetGear WG111T 108 Mbps 802.11g Wireless...
Wireless-G USB 2.0 adaptor stops midway through installation
Are you sure the adapter is VISTA compliant? Some are, some are not. BPCS
Dec 28, 2007 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Failed to install
Belkin drivers are a bit of a pain, uninstall the drivers again and remove the usb adapter, and follow exactly as per instructions, normally driver first, but ignore the pop up about the driver not being a signed windows if it does, just click install anyway. toward the end of the installation you should be prompted to connect the usb adapter, the hardware should be found and then the installation should complete. If driver installed ok but the adapter cant find the the driver plug it into a different usb port and again the found hardware should pop up then install driver popup should show and you should select install automatically.
Sep 10, 2007 | Belkin (F5D7050) 802.11a/g/b Wireless...
Computers & Internet Logo
41 people viewed this question
Top LowerPriceUSA.com Computers & Internet Experts
David Payne
David Payne
Are you a LowerPriceUSA.com Computer and Internet Expert? Answer questions, earn points and help others
