Question about Craftsman Vacuums
Interchangeable parts will generic filter work for craftsman shop vac?
SOURCE: shop vac
Vacuum is less than a year old and died in the middle of a use. No power... tried to plug it into 3 known, good outlets. Suggestions?
Posted on Jul 06, 2008
SOURCE: craftsman shop vac no power when turn on
I just picked up a similar model someone was throwing away. turns out there is a thermal fuse inside the motor housing that blew. I just need to find the values of the fuse and repalce with appropriate size. motor runs when fuse is bypassed.
Posted on Jun 09, 2009
Richie_asg1
  • 1036 Answers
SOURCE: old shop vac
Yes there should be a filter fitted onto the top section.
For suppliers, it would be cheapest to find your nearest stockist, or buy online and have it shipped. It's still current stock - so spares should be readily available.
Sears stock it -
CRAFTSMAN FILTER
Thank you for using Fixya,
Posted on Sep 22, 2009
shastalaker7
  • 1515 Answers
SOURCE: Older model shop.vac parts/owners manuel
Hi, I know on my Craftsman shop vac 2 different sizes of vacs that I use, I try and stick to the craftsman filters, but you can use other brands if they are not available or you want to save some ( $ ) ? As far as a manual for this vac, more then likely you will have to go to the maker and distributor as Sears, O.C.Hardware also sell there products. You may have to go with a manual that is the same peak H.P.and gallons that covers all different makes and models. Filter wise, make sure you have the right ones on or off when using the wet or dry pick-up settings.
Sincerely,
Shastalaker7
Posted on Jan 23, 2010
  • 10865 Answers
SOURCE: parts for a craftsman shop vac
Hello. The best source of craftsman parts is sears.com
If they don't have these parts I will be very surprised. regards, Joe
Posted on Feb 12, 2010
My shop-vac stopped mid-job with no warning
Maybe it over heated or the hose was jammed. Unplug it for a few minutes, check the hose for any stuck debris, then plug it back in. Shop vacs also come with a filter. If the filter is too dirty, it might have shut off as a safety precaution to not cause a fire. Follow directions to clean the filter. Hope this helped. Dee
Oct 13, 2014 | Craftsman Shop Vac 8 Gallon Replacement...
Who made craftsman wet/dry shop vacs in the late 70's?
here is a link that may be helpful
http://vintagemachinery.org/craftsman/manufacturers.aspx
it details the manufactuars that craftsman used based on then model and OEM number
Feb 08, 2013 | Vacuums
Need filter for craftsman6hp. 16 gal shop vac model 113.177060
They're availabe at Sears and Kmart. Lowes and Home Depot also have filters that will work.
Dec 27, 2012 | Craftsman 17765 Canister Wet/Dry Vacuum
Genie 400PC 16 gal shop vac but can't find filters
If you need paper filters, you can easily use a bag filter cut in half, and have less dust clouds than the original filter. Remember to use the lock ring. Generic ShopVac mini's have the same filter in foam.
Mar 11, 2010 | Genie Company GV150 Wet/Dry Vacuum
Parts for a craftsman shop vac
Feb 12, 2010 | Vacuums
Sincerely,
Shastalaker7
Jan 23, 2010 | Craftsman 17765 Canister Wet/Dry Vacuum
Old shop vac
Sears stock it -
CRAFTSMAN FILTER
Sep 22, 2009 | Craftsman 17765 Canister Wet/Dry Vacuum
I need to replace a brush to operate the shop vac. Where can I find it?
true value hardware stores have books to order these parts , piar of brushes are between $3 -$7 ,also most vaccume sweeper shop
Jul 13, 2009 | Craftsman 9-17765 12 Gallon Wet/Dry Vac,...
Genie Wet/Dry Vacuum replacement part
Hi, you can find genie replacement parts on amazon, click here and take a look: WORKSHOP Vacs Suck It Up Get It Done. I hope this was helpful. Cheers
Feb 17, 2008 | Genie Company GV150 Wet/Dry Vacuum
Shop vac
the neoprene sleeve used as the filter may have come off the cage. there's a plastic ring that fits over the filter and cage and holds it in place. as far other suggestions, use an old cotton sleeve from a pajama top. tie it off one end, slip it over the cage and fasten with a large wide rubber band.
Sep 03, 2007 | Craftsman 17765 Canister Wet/Dry Vacuum
Vacuums Logo
107 people viewed this question
Top Craftsman Vacuums Experts
downhille
Vernon Taylor
Are you a Craftsman Vacuum Expert? Answer questions, earn points and help others
