Question about Aqueon Motor Unit For Quiet Flow 55 / 75 Aquarium Filter
Impeller noise - Aqueon Motor Unit For Quiet Flow 55 / 75 Aquarium Filter
I have a Kenmore HE washing machine, model number 11047512601. A rubber part in the impeller for the pump is broken, and the pump makes a grinding noise when trying to drain. I took the impeller out and...
YOU CAN NOT BUY IMPELLER FOR PUMP YOU HAVE TO BUY A NEW ONE, JUST TAKE THE OLD PUMP TO AN APPLIANCE PARTS STORE AND THEY CAN MATCH IT UP ON ON SEARS ONLINE
Nov 08, 2010 | Washing Machines
Impeller shaft broke at impeller. moytor started to make loud noise . removed end of pump to find impeller at bottom of housing.
i have the wsame problem. A new pump will run me 550 I dont think I could replace the impeller shaft
Oct 17, 2010 | RTO AquaScape 4500 GPH Pump
Bauknecht washing machine WAK 1400 ex. Loud rattle in drain pump, but clean filter and no blockage. Impeller looks OK, spins fine dry. No odd sounds from motor without impeller. Is there a guide for the...
Have the drain pump connected off line and tested, if there is the nosie then open and clean well try to back flush by using a water from the reverse direction.
If the noise has susbsided then reconnect to cirruit and test with load.
If there is play in the impeller it can makea noise , you remove and grease the shaft to set it in, if noise is absent then might need to put in worn bearings.
Sep 19, 2010 | Washing Machines
Im getting a loud buzzing noise when the pump is running
could be an obstruction in the impeller, or the bearings going out. You can split the pump in two be removing the large clamp or 4-6 bolts holding the two halves together. (not the 4 bolts holding the motor to seal plate, but the the bolts holding the seal plate to the seal plate housing. once you remove the clamp or bolts, the motor with seal plate and impeller and diffuser can all be pulled back away from the pump. You need to remove the diffuser (plastic housing that goes around the impeller) usually by a series of 3 to 6 small screws. Now you can easily try and spin the impeller and check for obstructions that might have bound it. If you do not see anything stuck in the impeller, then the noise is likely coming from the motor (probably the bearings) you can replace the motor, or have it rebuilt. if your not gunna rebuild it you can deal with it as long as the noise doesn't bother you and the motor is not getting too hot
Sep 15, 2010 | ADVANTAGE Waterway SVL56 Pool Pump...
Not washing
Hi, there is a circulation motor that has an impeller attached to it. this is called the wash motor. it is located under the sump area. this wash impeller has become damaged and, you will need to replace it asap. this is causing the grinding noise. the impeller may be stripped or, it has slipped off the shaft. replacing this damaged impeller will fix this issue.
Jul 26, 2009 | Dishwashers
Dishwasher pump making a real loud noise
HI. the circulation pump has an impeller that is attached to the drive shaft stud. this impeller has become unstable and, it is producing this noise you are hearing during the wash. you will need to replace the wash impeller asap.
there are kits available on-line or, you can initiate a service call for this as well.
Jun 21, 2009 | Frigidaire 24 in. PLD2850 Built-in...
My Bosch SHU43C will sometimes make a loud noise
It may be more cost affective to just replace this unit. the circulation motors that are used in these dishwashers are not reliable. the wash impellers seems to have issues dealing with staying attached to the drive stud and shaft. this will cause the impeller ti shift inside the housing, causing noise and jams.
A new circulating impeller kit will cost about 100 dollars and, labor for this type of repair is 80 dollars an hour.
Jun 21, 2009 | Bosch Dishwashers
LG LDF8812ST WONT DRAIN JUST INTERMITTENT BUZZ NOISE
Hi, there may be an obstruction in the pump housing that is causing the motor to freeze or, the impeller may be stripped and , jamming the pump. this will cause the hum you are hearing. the best way to inspect is to , extract the drain pump by, removing
the bottom drain filter housing or sump. manually
move the pump impeller to self it is moving freely. if the impeller is stripped, it will not be able to produce the draining surge necessary to pull the water out.
If the impeller is fine and, there are no obstructions visible, this will confirm pump failure.. replace the pump in this case
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
Jun 19, 2009 | LG LDF8812 Stainless Steel Built-in...
Kitchenaid dishwasher making funny noises while running
HI. this sounds like a busted impeller in the pump housing. there are two impellers. one for the wash and one for the drain. the drive shaft will strip the impeller center nut, causing this noise. I would inspect the pump housing for lose impeller action. replace the faulty impeller if found to be damaged.
Jun 11, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Grinding noise in dishwasher. 4 day after warranty..Can I fix it myself...Need your help... Thank You, Sandi
Hi
Grinding noise is due to a cracked impeller which can be accessed by removing the spray arm. Sometimes a poor washing complaint is common after this wash impeller has cracked. Remove power first before investigating.
The motor shaft has started to rust and swells out and this swelling cracks the upper impeller. Most times a new seal and impeller kit can cure this complaint but sanding and cleaning of motor shaft is required before replacing the new seals and impellers.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Apr 21, 2009 | Dishwashers
Aqueon Motor Unit For Quiet Flow 55 / 75 Aquarium Filter Logo
46 people viewed this question
Top Aqueon Fish Experts
J.D. Browning
J.D. Browning
john h
Richard Lindsey ...
Are you an Aqueon Fish Expert? Answer questions, earn points and help others
