Question about KitchenAid 24 in. KUDP02SRSS Stainless Steel Built-in Dishwasher
Kitchenaid dishwasher Model# KUDN230YWH - need diagnosis please
I'm sorry but I have no idea what product I chose from the dropdown list provided on this request form.  I put the correct product model # in the subject line.  Below is everything I know:
I have a KitchenAid built in dishwasher.  On the front it says the dishwasher is an "IC Series"  & is ~7-9 years old. (model #KUDN230YWH; Serial #VNC4201304; Type: ND2/2) It has stainless steel interior.  One of the Light toggle on/off switches in the kitchen controls power to the dishwasher externally. On the front panel there is a "meter" that shows what part of the dishwashing cycle it is currently in.
I have not used is very much over the past 5 years.  I tried to run it a couple of weeks ago and it became stuck in the "washing" portion of the cycle.  I tried to select different cycle types to make it complete a cycle (ex:  pots & pans, normal, etc) with no success.  The wash cycle works - hot water fills, motor runs the cleaning cycle, but it never moves on - perpetually washes as long as I leave the power on.
What are the probable causes of this problem?
Are they fixable (economically feasible)?
Having an appliance service technician come out to the house is a minimum of $70 just to diagnose problem.  I hope you can help me decide if it is worth it!
Thank you very much,  Connie Townsend
  • 1 more comment
  • connie1214 Oct 20, 2007
    Last night I tried resetting the dishwasher circuitry by turning off the house circuit breaker to the kitchen, waited about 5 minutes and flipped the breaker back on.  This partially succeeded:  the cycle moved from being stuck in "wash" to being stuck in "rinse".  I tried a couple of more times and let the washer run a very long time, but it never moved out of the "rinse" mode.
    Therefore I still desperately need someone's help please!  Thank you,  Connie
  • gunnercva66 Nov 16, 2008
    water enters the washer and water temp seems hot but water does not pump thru spray arms. washer continues to cycle the water drains??
    HELP
    Kitchen Aid
    Model # KUDN230YWH
  • jmrice Nov 29, 2008
    I have the EXACT same problem.  Very troubling.  I just tried cutting the breaker for about 10 minutes, but it doesnt seem to help. No modes complete the cycle, and I'm stuck.  We just moved into a new house and I feel like we've complained about a ton of things to our landlord.  Im hesitant to have them call someone.
    Anyone have a solution?
THENTHEREWER
  • 131 Answers
SOURCE: KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher
sorry stclairn,if its new & you have a waranty let them deal with it(why through good money after bad)hope this helps.thanx for using fix-ya.
Posted on Nov 16, 2008
aborcass
  • 2651 Answers
SOURCE: Lights flashing on clean. Program does not take.
you can open the lowe racess panel of d/w and you find a techsheet/ trouble shooter, in ther they will explain how to reset a clean light blinkin 7 times.. you can try pushing the "sani-rinse"---"heated dry"--- "sani-rinse" --- "heated dry"... toggling these buttons will triggor a test mode, youl know your in it for all the lights will light, close the door and wait 30 secs or so, the reopen door and cancel cycle, after it runs for 2min it will be ready fro you to start using again.. of the clean light issue returns, id recommned calling for service
Posted on Jan 10, 2009
rylee_smith
  • 8619 Answers
SOURCE: I have a Kitchen Aid
Hi
Thanks for using FixYa. If the cycle doesn't complete, then the first thing that should be checked is the Timer and then the heating element. Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it. Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next depends, as follows: On some units, the pause is timed and the unit continues after the allotted time. On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 26, 2010
  • 441 Answers
SOURCE: I have Kitchenaid dishwasher KUDL03,
You need to do a vinegar wash, the film you are getting is from a change in detergent. many states have now outlawed phosphates in detergents, when the new stuff meets the old that is still in your dishwasher lines it makes the film happen. Fill a cup with vinegar and place it on the upper rack, then run it with no other dish's in it on heavy duty, the water will be displaced from the cup during the wash and will help to stop the film. I had to do this 7 times before the film stopped, good luck
Posted on Jan 21, 2011
Daniel S
  • 4323 Answers
Hi
Please check below video for drain pump removal---
Please refer these instructions for details---
1. Unplug dishwasher or disconnect power. 2. Turn off the water going to the dishwasher. 3. Disconnect the drain line from the dishwasher. 4. Remove the dishwasher drawer and turn it over. 5. Unclip the locking tab from the air cover, slide it forward off the rails, and remove the cover. 6. Use a screwdriver and unsnap the underside of the wiring cover arms, and remove the cover from the bottom of the drawer. 7. Wedge a screwdriver blade into the three top slots of the wiring cover and unsnap the cover from the motor housing. 8. To remove the hall sensor: a) Disconnect the wire connector at P701. b) Unclip the locking tab from the hall sensor board and lift the board up and off the motor/heater housing. 9. To remove the wash and drain motor and heater element assembly: a) Remove the hall sensor (see step 8). b) Disconnect the green wire from the ground terminal. c) Remove the drain and fill hoses, and the electrical wires from the locking ring clips. d) Disconnect the heater element wiring connector. e) Unclip the two locking arms on the motor housing from the end of the drain hose, and pull the hose out of the housing. f) Pull straight up and disconnect the three wire connectors from the motor terminals. g) Lift the locking arm, and rotate the locking ring in a counterclockwise direction until the outer tabs line up with the tub slots. NOTE: The motor housing tabs and slots will also be loose at this point. h) Lift the motor housing, locking ring, and heater element off the tub, and pull the suction nozzle out of the tub drain opening. i) Remove the wash and drain motor and the heater element from the tub.
REASSEMBLY NOTES: 1. Check the motor and heater seals for wear or damage. Replace them, if necessary. 2. When you reinstall the heater element, locking ring, and wash & drain motor onto the tub, make sure that the seals below the locking ring and the motor housing are properly positioned to prevent leaking. 3. When tightening the locking ring, make sure that you tighten it fully so that the locking arm (shown in the photo to the left) is locked behind the tub. If the ring is not fully tightened, the locking tabs will not align properly with the slots in the wiring cover. Hope this helps...please post back for further assistance. Daniel
Posted on Mar 05, 2011
Kitchenaid whisper quiet plus dishwasher
It is likely the thermal fuse is cut off and will need to be reset or replaced depending on the model number of your dishwasher. Please provide actual model number in the comments.
Apr 25, 2014 | KitchenAid Dishwashers
Kitchenaid dishwasher imperial 21
Take the kick panel off under the door and see if the technical spec sheet is there. That lists all the diagnostics that you can run
Nov 20, 2013 | Dishwashers
How to install the sump pump gasket on my kitchenaide dishwasher
please provide the model number of the dishwasher.
Apr 19, 2013 | KitchenAid Dishwashers
I need the length, width height dimensions for a KitchenAid 24 in. KUDS02FRSS Stainless Steel Built-in Dishwasher
if you cannot view this picture then go to kitchenaid site and type model number kuds02frss and select installation guide from the list. Please rate this solution if helpful or else post a comment.
Feb 25, 2011 | KitchenAid 24 in. KUDS02FRSS Stainless...
Seal on door came off where can I get a new one?
Replacement door gaskets can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three websites also have exploded view parts illustrations to assist you with locating and properly identifying any parts you may need. If the model is correct, the gasket is listed as item 3 under the "Tub and Frame" parts list on most of the parts listings. The part number will depend upon the model number. The model number you provided is not complete.
If you need instructions on how to replace most common dishwasher gaskets, the following link can give you some guidance:
http://www.fixya.com/support/r3555822-my_dishwasher_leaks
Most dishwasher gaskets are the press in place variety. However, some require gluing in place with a special rubber cement. The glue will come with the installation kit.
If you have any questions, please post back with your complete model number (located around the door edge frame, or door opening). I hope you find this information helpful.
Dec 18, 2010 | KitchenAid KUDS24SE Built-in Dishwasher
I have a Kitchenaide Whisper Quiet Ultima dishwasher. It will come on, but no water comes in. Is there a reset button or something that may be clogged?
Are you able to provide the model no. of your dishwasher please.
NO water coming in could be either due to water inlet solenoid not working, the controller not working or the flood switch being triggered.
Need the actual model no. to confirm likely situation.
Sep 20, 2010 | KitchenAid Dishwashers
Drivers
Click on the link provided below; (AOpen MX46-533V)
http://download.aopen.com.tw/Default.as
Once opened, click on the drop down button as follows:
Under the first window, " select a product ".
Choose, " Motherboard " from the drop-down button.
Under the next window, " Select a model ". Choose " MX46-533V ".
Under the last window, " Category ". Choose,
" Driver ". Download the drivers you need. When finished go back to the drop-down menu and click on,
" Released Date ". This will show any updated drivers for you're motherboard. Suggest you book mark the site just in case you need other information/drivers.
Cheers'
Mike
Mar 31, 2010 | AOpen MX46-533V (91.89U10.061) Motherboard
Lost the assembly instructions for halo wars mega bloks wolverine set, where can we get them?
go to megabrands.com on the right side of the screen chose halo wars from the dropdown list. next click on consumer services (green button at top of screen) choose the instructions then u will have to chose halo wars again then follow the next list until u see wolverine. click it u will then be provided with a way to print or download the instructions
Feb 03, 2010 | Mega Bloks Toys
Hi I need ASUS A7V400-MX Video Drivers urgently Please help
Left click on the Asus link provided below;
http://www.asus.com/product.aspx?P_ID=hORgEHRBDLMfwAwx&content=download Click the dropdown menu listed & choose your operating system. Once complete the drivers for your A7V400-MX MB will be listed. Click the + sign next to VGA. Download & install;
VIA/S3G KM400A Graphics Driver V5.10.146.0.
Cheers!
Mike
Oct 10, 2009 | ASUS A7V400-MX Motherboard
Dishwasher fills but does not wash
Is your Kitchenaid Dishwasher a model KUDI02?
If yes, you need to order item 10 on the page link below:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5137276
Good Luck!
Feb 09, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
KitchenAid 24 in. KUDP02SRSS Stainless Steel Built-in Dishwasher Logo
387 people viewed this question
Top KitchenAid Dishwashers Experts
Carmen Mikulic
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
