Question about Black & Decker String Trimmer Cordless 12" 18V
I have a B&D grasshog. I tried to charge both batteries, but the
The light doesn't even go on when the charger is plugged in. Would it be the batteries that need replacement or could it be a problem with the charger
5 Suggested Answers
  • 72 Answers
SOURCE: Need to replace 18V batteries for B&D Grasshog trimmer/edger
Have you tried Batteries Plus? , they have them and are not too expensive.
Posted on Jun 08, 2009
  • 903 Answers
SOURCE: battery to fit Black & Decker CST20000 Grassho...
Unfortunately, the battery pack as a unit has been discontinued, but the battery itself (part #243213-00) can be purchased online. Amazon sells it for $35.99. You can find it here:
http://www.amazon.com/Black-Decker-243213-00-Replacement-Grasshog/dp/B0027Z7G94
Posted on Jul 10, 2010
HansPP
  • 2510 Answers
SOURCE: My B&D GrassHog CST2000 doesn't hold a charge very
Battery cases are usually welded closed and must be cut open to access the cells. The cells are also spot welded together to make up the battery voltage.
Posted on Jun 01, 2011
richroth
  • 9472 Answers
SOURCE: I am trying to get a black and decker cordless trimmer edger (cst2000)'s battery to charge. There are 2 lights on the head of the charger where it plugs into the wall. One green for "Ready", the oth
You will need to check the charger with a multimeter to see if you are getting 12 volts.
Posted on Oct 25, 2011
Battery charging but laptop won't work while plugged in
The purchased is sub standard. Get a replacement from the store. N.B the fujitsu charger will work for some
Time and damage your laptop because of the higher amp
Jan 27, 2013 | Toshiba Satellite Computers & Internet
SAMSUNG LAPTOP PLUGGED IN NOT CHARGING
try removing the battery and just use the mains power. If the laptop works you may need a new battery. If it doesn't your charger is faulty.
Nov 26, 2012 | Samsung R580 Notebook
Motorola cellular w376g, battery won't charge
If possible test with another charger like a car charger if you have one
also try removing the battery plug in the charger and put the battery back in (don't touch the contacts/gold pins)
if it works with other chargers then the charger is bad
if it doesn't work with other chargers charging port/battery/phone is bad
May 27, 2012 | Cell Phones
My laptop is completely dead, fine yesterday. Today no lights, sounds nothing. I tried removing the battery , unplugging no response. Thanks,
Remove the battery for at least 3 minutes... Then put it back and then plug in the charger and switch on the charger. If the battery is completely drained, it would take a while for the charging to initiate. Please have patience and leave it on charging even though without the charging indication for at least an hour. After that still if the charging indicator doesn't lit, then its definitely your charger or laptop. You will need to take it to a service centre in that case.
Nov 03, 2011 | Compaq Presario 2170US Notebook
I was using my psp while it was charging and the charging light turned off, so i naturally assumed that it was fully charged. But a few minutes later the battery died and it wont charge when i plug it in....
Have you tried to remove the battery and put it back in and try to turn it on. Try removing the battery and putting the charger in and starting the PSP. If it starts, it might be the battery. If it doesn't, it's either the plugin for the charger or the PSP is just dead. If it does start with the charger, try putting the battery back in, if it charges awesome. If it doesn't the battery might be dead.
Sep 27, 2011 | Sony PlayStation Portable (PSP) Console
I'm borrowing a Jet 3 Ultra from the local Am. Legion for my Mom to use. They know nothing about it except they were told it had a new battery. I plug it in and all the LED's light up with the...
The batteries need charging and when you plug in the charger and the power is on the lights wil flash indicating that the charger is plugged in. Now look at the rear of the chair near where the charger cord plugs into the chair and you should see a voltmeter. With the charger plugged in the voltmeter will indicate about 5-6 amps and after charging overnight the voltmeter should be reading 0 amps. If when you plug in the charger cord and the voltmeter indicates 0 amps then I would suspect that the charger is not working or that the fuse is blown in the charger circuit. The only way to see if the batteries charge would be to borrow or find an offboard charger that will plug into the charger port located under the front of the joystick and after charging for 10-12 hours see if the battery level lights show full charge Hope this helps
Jun 25, 2011 | Pride Used Mobility Jet 3 Power Wheel...
Jun 01, 2011 | Black & Decker Garden
Dirt devil doesn[t hold charge
Try running the battery all the way down by letting the vacume run in a corner or another room and even when it stops leave it on for a hour to drain the battery. Then shut the switch off and try charging the battery. Make sure the charger is putting out enough volts by looking at the rated output of the charger and while it is plugged in check it with a volt meter. If it does not hold a charge and the charger is putting out the right voltage you need to purchase a new battery for the vacume
Mar 18, 2011 | Dirt Devil Easy Lite Quick Vacuum
Black & Decker String Trimmer Cordless 12" 18V Logo
82 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
