Question about KitchenAid K5SS Mixer Speed Control Plate Kitchen Aid
Motor won't turn on until speed 6
At the stir setting through speed 4 the motor will not come on; only on speed 6-10
5 Suggested Answers
  • 16 Answers
SOURCE: mixer speed turned erratic!
I would recommend that you first check the Hall effect sensor which determines the speed.  I had this exact problem and I actually went out and bought another Hall sensor for about $13.  I replaced the original sensor and made sure that the connection between the sensor and control board was nice and snug. My blender worked as good as new! But I was curious to know if my original sensor was defective so I put it back in mixer and again made sure all of the connections were tight.  Guess what?  My original sensor also made my mixer work!  There was nothing wrong with my original Hall effect sensor except the connection between the control board and sensor was not adequate--unfortunately I didn't check the connections before I decided to buy another one. My guess is that the connection between the control board and the sensor probably loosens or comes undone over time from use and vibrations.
1.  Download the mixer parts and diagrams from the Kitchenaid website to see what the Hall effect sensor looks like. BTW the part number is 9703312. 2.  You'll need a phillips head screwdriver to open up the mixer. 3.  Make sure that the connection between the control board and sensor is absolutely tight and snug. 4.  Also, make sure that the orientation of the sensor connection between the control board and sensor is correct. it's hard to know which way the sensor should be connected because the control board has three prongs and the sensor can attach facing up or facing down. If, after you've made the connections, the mixer still doesn't work.  Disconnect the sensor and reconnect it with the prongs facing the opposite direction and try it.  I actually found the right orientation through trial and error.  By going through this trial and error, I also had my Eureka moment when I realized that the original sensor probably would also work it were reconnected with correct orientation.   5.  This whole process probably takes less than 10-15 minutes to perform.  6.  Make sure you use common sense and unplug the mixer when making connections and such.
Posted on Dec 30, 2008
ricardok45
  • 135 Answers
SOURCE: KitchenAid 2671 onmly run Stir and Second at high speed
Hi. Goto kitchenaid.com and download the parts catalog for your mixer model, these drawings will assist you in the disassembly and reassembly of your mixer.
You'll need to replace the speed control in your mixer. This is a common problem. Be prepared to wait at least a month for your parts to arrive. Unplug your mixer before you open it up.
If you're still under warranty call kitchenaid!
If this solution has assisted you, please rate it. Good luck! ricardok45
Posted on Mar 21, 2009
hslincoln
  • 235 Answers
SOURCE: kitchenaid 625 watt 6 quart mixer. Was using it
HAMILTONCOOL - It appears that your mixer had a mechanical failure in the transmission box or planetary gear assembly of your mixer failure - one of the main gears has failed, hence the loss of power to the agitator. You didn't mention any associated noise prior to the loss of power to your agitator, but I'm assuming there was just a little more noise than usual, prior to failure.
The inspection and troubleshooting of the transmission is a DITY capability, particularly if your mixer is out of warranty. Just be sure to have the correct Part List manual around when you start to disassemble your mixer. If you're lacking one, you can download it from the KA website. Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, and then select Parts List file. You can check the page titled 'Case, Gearing & Planetary Unit, for the disassembly, troubleshooting, and reassembly of your mixer, along with all the parts. It can be messy but gratifying. Once apart you can check for any other unseemly wear and tear on the gears, etc. Good hunting... I hope this helps - Howard, Burke, VA
Posted on Nov 19, 2009
  • 153 Answers
SOURCE: Kitchenaid Artisan KSM150 Stir problem - Stir
You are not adjusting the screws correctly. All three screws (2 top left and right, and 1 bottom)
must all be adjusted. Here is how:
1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned
anymore. Leave the bottom screw alone for now.
2. Use a dab of white paint or paper whiteout to mark the positions of the Phillips screws.
3. Plug in your mixer and Set the speed selector to "Stir".
4. Turn each top screw One full turn couterclockwise (alternating between Left and Right)
Keep making one full turn at the time (for both left and right) until the motor starts running.
5. Put your hand near the Agitator shaft and allow it to brush your finger slightly. Use your
watch or clock and start counting the number of times the shaft touches your finger in
60 seconds. The correct count should be 60 RPM (Rounds Per Minute). If it is less
or more than 60, give each screw 1/4 turn counterclockwise or clockwise and start counting
again. Now tighten both lock nuts.
6. Set the speed selector to "6" and turn the bottom screw either clockwise or counterclockwise
to achieve a speed of 180 RPM.
For your reference, the planetary RPM's for the 5-qt. tilt-head Artisan Stand Mixer are as follows:
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Posted on Jul 03, 2011
Motor not turning on
Get a copy of the Repair Part List for your model at Kitchenaid.com
Download a Copy of the Kitchenaid Service manual.
http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf
Make sure that the Motor Brushes are not worn out and making good contact with the Motor.
Adjust the mixer speeds (if necessary):
Remove the screw holding the End Cover and locate the three screws from the Control Plate.
All three (2 top left and right, and 1 bottom) must be adjusted.
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Aug 15, 2011 | KitchenAid KSM150PS Artisan Series Stand...
Kitchenaid mixer motor quit , I dont really see any thing wrong with the brushes.
Obtain a copy of the Repair Part List for your model from Kitchenaid.com.
First, you may want to adjust the mixer's speeds:
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Second, if the mixer won't run:
Remove the Control Plate Assembly (36), the Phase Control Board (39)
and the motor Governor Assembly (35). Inspect for loose connections,
burnt or damaged components. If they seem to look OK, re-assemble
them and test the mixer. If the motor still won't run, then I might suspect
a defective Phase Control Board (39).
Aug 01, 2011 | KitchenAid K45SS Classic Stand Mixer
Kitchenaid stand mixer KSM90EM turns off when going to the left on speeds 4 - 6. Makes a bit of noise at stir speed, but runs in time. Also noticed white dust powder in small amounts on the speed...
Get a Copy of the Repair Part List from Kitchenaid.com.
You need to adjust the mixer speeds:
All three (2 top left and right, and 1 bottom) must be adjusted. Make sure that the Control
Plate is not damaged in any way, contacts are not charred or burnt,etc...
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Jul 30, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
Mixer won't start. Fell on its side and on/off lever was bent. Straightened and it now moves back and forth as it did before. I took out the two black screws at the top which hold in magnets on...
Get A Copy of the Repair Parts List from Kitchenaid.com
Make sure the Speed Lever and and the Speed Link are in place
and operating smoothly. The two Large black screws you are referring to
are the Motor Brushes Caps. The Carbon Brushes are keyed and
designed to be inserted into the Motor Housing but one way. If you
insert them in wrong, they will not make contact with the Motor Coils
and you mixer will never run.
All you have to do now is adjust the mixer speeds (if necessary):
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Jul 24, 2011 | KitchenAid Artisan KSM150PSAQ Stand Mixer
Kitchenaid speed controller (don,t work
You need to adjust the mixer speeds.
Obtain a copy of the KSM150PS Repair Part List from Kitchenaid.com.
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Jul 20, 2011 | KitchenAid KSM150PS Artisan Series Stand...
I was grinding some meat and my mixer got very hot. I let it cool down and now it only operates at one speed.
I am not sure what has happened to your mixer but, select
different speeds from Stir to 10. If it runs OK, then there is
nothing to worry about, otherwise do the following to re-adjust the mixer's speeds:
Get a copy of the Repair Part List of your model from Kitchenaid.com
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Jul 18, 2011 | KitchenAid KSM150PS Artisan Series Stand...
The mixer goes real fast on all the settings. Whats wrong?
The K45SS is very similar to the 5-qt. tilt-head Artisan Stand Mixer.
You need to adjust the mixer speeds. Obtain a copy of the K45SS Repair Part List from Kitchenaid.com. Remove the screw holding the End Cover and locate the three screws from the Control Plate. All three (2 top left and right, and 1 bottom) must
be adjusted. 1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned anymore. Leave the bottom screw alone for now.
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Jul 14, 2011 | KitchenAid K45SS Classic Stand Mixer
Speeds don't increase after 6
You need to adjust the mixer speeds. Obtain a copy of the K45SS Repair Part List from Kitchenaid.com. Remove the screw holding the End Cover and locate the three screws from the Control Plate. All three (2 top left and right, and 1 bottom) must all be adjusted. 1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Jul 03, 2011 | KitchenAid K45SS Classic Stand Mixer
I could not regulate the speed as usual. Hubby removed the phase control board and a new one was purchased #9706595. It arrived and was installed and now the mixer won't even turn on. HELP please.
The K5SS is very similar to the 5-QT Artisan KSM150.
You need to adjust the mixer speeds. Obtain a copy of the K5SS Repair Part List from Kitchenaid.com. Remove the screw holding the End Cover and locate the three screws from the Control Plate. All three (2 top left and right, and 1 bottom) must all be adjusted. 1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Jun 28, 2011 | KitchenAid K5SS Heavy Duty Commercial...
Kitchenaid Artisan KSM150 Stir problem - Stir speed is the same as setting 2, but all others (4, 6, 8, 10) work fine. Tried adjusting the control board but "stir" and "2" still spin...
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Jun 20, 2011 | KitchenAid KSM150PS Artisan Series Stand...
KitchenAid K5SS Mixer Speed Control Plate Kitchen Aid Logo
24 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
