Question about Dryers
Kenmore dryer runs great but no heat
Kenmore dryer all of a sudden yesterday quit heating. It still tumbles and everything but does not heat up. I have checked with my ohm meter and have continuity across the two poles on the element, and there are two small items mounted on the element housing and I don't know if they are supposed to show continuity across them or not. I also checked across the thermal fuse and it also checks to be good. Can someone please tell me how and if the items mentions are supposed to show any kind of reading across them when unplugged? It is a Kenmore 110.96595520 Electric Dryer, and was one of the first digital models to come out about eleven or twelve years ago. Please Help??
Thanks
Walt
  • 460 Answers
Am sending you the information I have so you can ask me with the names of the parts you want me to assist you.
If nither of this match to your dryer I need the model n serial# .
your retiing is very important for me
was this helpful?
Posted on May 21, 2009
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
Kenmore gas dryer 110.78622700 Runs, tumbles, heats but does not heat long enough to dry clothes. Amy ideas what to check first?
Probably the solenoids on the gas assembly are bad. If it heats at all that is a sure sign of them heating up and quiting. Very common and easy fix. Before trying to check that look for sensor bars inside the dryer under the filter and clean em with windex. If the have buildup on em they might not be sensing wetness.
Jul 13, 2013 | Dryers
Dryer quit heating suddenly.
The fuse is located on the blower housing and if it was blown the dryer would not run at all. The limits is mounted on the heater housing and that could kill the heat as well as a blown heating element. I worked on a similar dryer not long ago with a heating problem and did a video:
DRYER NO HEAT
Jul 08, 2012 | Dryers
Kenmore 70 series dryer. Heats up but quit tumbling.
belt is off or broken here is a website that will help:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
routing of belt:
http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.html
Good Luck Tim
May 11, 2011 | Dryers
I have a Kenmore Dryer model #110.66732500 that just quit heating. Everything else is working fine, tumbles but no heat. It is 4.5 years old. When it quit it tripped the circuit breaker, we reset the...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
bn
Sep 28, 2010 | Kenmore Dryers
Kenmore 600 Dryer- suddenly stopped working
can you hear the motor running, if so then more than likely the belt broke, you need to unplug it ,remove the front cover, then top cover, then remove drum and you can start to restring the new belt
Oct 26, 2009 | Kenmore 600 7962 Dryer
I have a Kenmore electric dryer series 80...It tumbles but suddenly no heat??? I need to check the fuse but I don't know how to get at it? I have the back TOP panel off & it has a piece of paper with a...
first its not the fuse or thermal fuse
if that was bad you would not get tumble
it is your heat package
remove the back panal, lower right is you heat
making sure the unit is unplugged disconnect the heat 3-4 wires and one 5/16 nut on the left lip
take out the heat and visualy inspect,,,
Oct 05, 2009 | Kenmore 84052 Dryer
Maytag dryer heating element does not turn off when tumbling stop
your timer is bad,the cost of a timer is close to a new dryer.
Jan 21, 2009 | Dryers
Dryers Logo
143 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
