Question about Samsung - Projection TV replacement lamp Projector Lamp
Samsung projection TV intermittent shut-down problem
Samsung Model HL-R5067W will shut down intermittently and when restarted will come on and sometimes after a few minutes shut down again. Othe times when restarted it will run without a problem for several days. my hcn4226w/hcn436w keeps shutting down
    Brigadier General:
  • 3,614 Answers
A blown fuse is a very common type of fault due to poor design very often triggered by power surges due to outages or lightning storms. However, the most likely parts to short are easily tested, usually in-circuit, with an ohmmeter and then easily removed to confirm.
If the fuse really blows absolutely instantly with no indication that the circuits are functioning (no high pitched horizontal deflection whine (if your dog hides under the couch whenever the TV is turned on, deflection is probably working).) then this points to a short somewhere quite near the AC power input. The most common places would be:
  • Degauss Posistor - very likely.
  • Horizontal output transistor.
  • Power supply regulator if there is one.
  • Power supply chopper (switchmode) transistor if there is one.
  • Diode(s) in main bridge
  • Main filter capacitor(s).
You should be able to eliminate these one by one.
Unplug the degauss coil as this will show up as a low resistance.
First, measure across the input to the main power rectifiers - it should not be that low. A reading of only a few ohms may mean a shorted rectifier or two or a shorted Posistor.
Posted on May 20, 2009
I have a Samsung HL-R5067W. I have had this tv
the digital pcbs on these sets go bad and need to be replaced when they start showing these symtoms
Jan 23, 2010 | Samsung Televison & Video
Remote Code Samsung 50" DLP HL-R5067W
022 036 043 159 160 170 175 212 215 702 713 706
Dec 14, 2008 | Samsung 50" Slim-Depth DLP HDTV
TV goes off intermittently
sounds like an intermittent shut down which is heat related. some part , maybe one stuck on a heatsink is warming up and running too much current triggering shutdown.
to find it you can tell what is shutting down with a voltmeter, or you can heat suspected parts with a blow dryer to speed the shutdown .. or freeze spray to see if it goes beyond your shutdown time.
Nov 10, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung DLP TV shuts off
sounds like your power supply is going south...check the voltage coming out of the wall first
Feb 25, 2008 | Samsung DLP HL-P5663W 56" TV
No sound or picture HL-R5067w samsung
See my TIP on my page and see if that helps u. Also the lamp could be toasted. Let me know, i may have one in stock. Thank you GURU JAY
Jan 18, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
sounds like ur tuner is bad.. ur better off buying a new tv then geting it repaired
OTHERWISE- THIS SET MAY HAVE THE DREADED 1500UF POWER CAPACITOR ISSUE WHICH ARE EASY TO SEE IF YOU CAN ACCESS THE MAIN POWER PC AND VISUALLY CHECK FOR 'POPPED' CAPACITORS ON THAT PC. JOE TV
Oct 04, 2007 | Samsung - Projection TV replacement lamp...
Tv shuts down
does the main board have the flyback on it? if so the yokes or CRTs can be intermittently shorting which in turn triggers your shut-down.
turning it off or unplugging just resets the shut down circuit.
Sep 04, 2007 | Samsung HL-R4266W 42" HDTV-Ready...
126 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
