Question about Bose Wave Radio
Disassemble bose wave awrc1g
No power and need to take apart and do not know how this is don
SOURCE: replace fuse Bose Wave Radio
For the AWR1-1W turn it over and there are 4 screws that you must remove. When your looking at the circuit board the fuse is just below the power supply and back of radio. If the radio makes a ‘POP’ sound when you unplug it may not be the fuse as power is getting past the fuse. I have the same trouble with mine. I called BOSE Tech and he said if it makes that ‘POP’ sound after unplugging it is not fuse or power supply. They will not even allow me to send it in for repairs as the radio is over 15 years old and considered unserviceable.
Maybe someone else can give us a quick fix.
Posted on May 06, 2008
DigidocTN
  • 22 Answers
SOURCE: Bose wave radio will not power on. used to work
I repaired mine recently. Check transistor Q4 for an e-b short. The replacement costs less than $1.
Posted on Jun 27, 2009
  • 13 Answers
SOURCE: My bose wave radio wont turn on. It has no power
I have the exact same AWR1-1W model for repair last week. I am assuming you have a meter and you also have soldering skills here.
You might want to check the Q4 transistor (2SC3792) for a short on the two outide pins. With the power disconnected, measure with a multimeter the resistance between the two outside pins of the Q4 transistor. If you measure anything between 0-3 ohms it is shorted. Replace this part with a similar part or you could replace it with the new Bose recommended part - 2SD438F-MP-E but it is very hard to obtain. I have used an 2SC2655 instead and had no problems so far with the radio. This radio also came in totally dead with no display nor the radio working.
Posted on Jun 07, 2010
SOURCE: bose radio awrc1g only static like there is no
Mine did the same thing. I took the cover off and took the radio apart. I discovered the FM/AM tuning crystal was separated from the mother board (soldering failed). Anyway, when figured out where the crystal went I reinserted it and it worked great. I considered gluing it back in but opted to test my soldering skills and it worked out just fine. The crystal is a small silver electrical component with 2 prongs that plug into the motherboard.
Good Luck.
Posted on Jun 21, 2010
  • 2468 Answers
SOURCE: Need a 110v power supply(power
if the secondary voltage of the transformer is 12 volts A.C. go to radio shack and they will have a transformer,though being it an aftermarket transformer it will work
Posted on Aug 01, 2010
Why did left speaker stop working?
If the speaker is not defective, a common problem with the AWR1CG and P models is liquid damaged circuitry. Where openings in the top case appear over the circuitry, spilled liquid drips down and may damage, or over time badly corrode, the circuit board traces, small through-connections, and/or electronic components. This is not a repair an untrained/experienced person should attempt. We service many of these liquid damaged units with good success rate. CET Services, 117 Windsor Ave, Hurley, WI 54534 // don.miller60@outlook.com.
Dec 31, 2015 | Bose Awrc1g Wave Radio Cd Player Only -...
Bose Wave unplugged now it wont power up
The power supply and power regulation circuits on these particular models can be finicky and fail in various assorted manners, causing a no power up condition. This is not something an untrained person should attempt to repair. If there is a possibility that liquid seeped into the unit from a spill (common) then that can present its own set of problems. We service hundreds of these units. CET Services, 117 Windsor Ave., Hurley, WI 54534 // don.miller60@outlook.com.
Dec 30, 2015 | Bose Awrc1g Wave Radio Cd Player Only -...
How do i repair the cd player on my bose awrc1g radio cd player
Hi Susan
As there are no user serviceable parts inside your unit, your best bet would be to contact Bose directly. This is likely best left to the pros, especially if the unit is still under warranty.
Here's the link to your owners manual, service centres are on page 29.
-Steve
https://www.bose.co.uk/GB/en/images/owners-guide_Wave-Radio-CD_AM250723_05_tcm6-57006.pdf
Jan 19, 2015 | Bose Awrc1g Wave Radio Cd Player Only -...
Bose wave radio cd does not power on--nothing!
This obviously is a power problem which can be handled only by a qualified service personnel.
Feb 17, 2014 | Bose Awrc1g Wave Radio Cd Player Only -...
Bose wave radio cd won't play cd's
If your CD is not scratched,the optical lens need replacement.
Apr 02, 2013 | Bose Awrc1g Wave Radio Cd Player Only -...
AWRC1G Bose radio/CD I have....when I turn on there is nothing but a tremendous screeching sound and thats all I hear.
I know this is an old post, but more likely than not you have a liquid damaged unit. This is very common and symptoms such as that which you describe are the result. We service hundreds of these units with great success. CET Services, 117 Windsor Ave., Hurley, WI 54534 // don.miller60@outlook.comS2XL9M
Aug 23, 2012 | Bose Awrc1g Wave Radio Cd Player Only -...
Bose radio awrc1g only static like there is no antana. Works some times. CD works fine.
Good Luck.
Oct 20, 2009 | Bose Wave Radio
My bose wave system will not turn on.
There's a line fuse inside the radio, mounted on a PC board. CAUTION: disconnect the set from power before opening the case or poking around inside. The fuse could be bad, but these sets are notorious for losing the power transformer. If the fuse is ok then you are looking at a $100 repair fee from Bose. You might want to check out the new HD radios -- better sound, MUCH lower price.
Bill B.
Nov 15, 2008 | Bose & Wave& Music System
No power
Unfortunately Bose will not release their schematics or parts lists, effectively giving them a monopoly on repairs. Their web site, www.bose.com, offers to repair most Wave radios for $100 or to give owners of broken sets a $200 allowance towards the purchase of a new Wave. Before spending the big bucks though, you might want to check out the new HD radios. Better sound and a MUCH lower price.
Nov 11, 2008 | Bose & Wave& Music System
Bose Wave Radio Logo
56 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
