I need a help
I have one problem which USB supporm of printer. When I on my printer the USB controller begin on/off and it's work all time. Please tell me what do I can from this problem?
    Brigadier General:
  • 10,406 Answers
Try to connect the printer to a different computer.
If it exhibits the same behaviour, the problem is inside the printer,
and the most cost-effective solution is to replace the printer,
and responsibly recycle the old printer.
Posted on Aug 23, 2010
My scanner want scan
Re-install the software but do not connect the USB cable immediately. Begin the installation and let the software tell you when to re-connect the Usb Cable to the computer. Let it finish
Reboot computer and Windows will find it.
Or, go in control panel and click on Scanners and Cameras. You should see the Kodak icon there. Click it and scan from there. If the scanner was well installed, it should work from there as well.In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Kodak Printer Support
Feb 26, 2014 | Kodak Esp 3250 All-in-one Inkjet Printer
Usb port not working
Printers are particular about which usb port they are plugged into, a virtual printer port is assigned to USB1 in the computer, when you select the printer port for it to use. You may need to plug the printer into each USB port, until you fine the USB port 1 which it works in, remember to always connect it to this same usb port, otherwise it will not work. There is only one USB port number 1.
Apr 10, 2013 | Brother MFC-7340 All-In-One Laser Printer
I bought a konica minolta magicolor 1690mf, printer. please can one help me on the step by step on what to do? and how to connet it to wireless or ethernet. please i need an answer please.
Since several computers or laptops will access the printer, it is recommended to connect the wireless printer to the main computer through the USB port.
To begin the installation process on Windows XP, access the network setting in the Control Panel, and activate the file and printer sharing option in the LAN setting.
This will allow the operating system to recognize the availability of a wireless printer.
Now, click the Start button, go to Devices and Printers, select Add a Printer option.
Click the second option- Add a network, wireless or Bluetooth printer.
The computer will search for available printer and reflect it on the screen.
Click Finish; and the printer is ready to begin the printing process.
if you have any problems with your printer
click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow? ! question exclamation mark or a red X this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or
select properties again you will have the similiar options also you can troubleshoot the device
hope this helps you
Sep 19, 2011 | Konica Minolta magicolor 1690MF All-In-One...
Printer x2500 not communicating with computer
Start from the begining
Unplug the usb lead from the printer
Go to control panel / programs / and uninstall all lexmark software.
Pop the cd in and load the software and drivers.
plug the usb cable back in and turn on when it asks you to
Reboot
Jul 18, 2010 | Lexmark X2500 All-In-One Printer
HP3600 USB printer works but won't print on my HP7058 Laptop
Try removing all ports from your laptop, then reboot, and then create just one USB port. Also, go to your hardware devices and make sure your usb ports don't have any question marks or yellow warning symbols. Be sure first that the drivers for your USB ports are installed and working first. This sounds either a faulty USB cord, which does happen, or USB drivers issues in your laptop. The printer is probably not the problem here.
Feb 17, 2010 | HP LaserJet 3600n Printer
How to install Canon faxphone L75 without a set up CD? I download the driver. The printer won't set up without a CD
Hi ...
Visit the below link to download the drivers for your L75..
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=241&modelid=8721#DownloadDetailAct
Before You Begin the Installation: white_square.gif Do Not Connect.
Do not connect the USB cable to the port on your computer at this time. When you begin the installation of the software, the installation program will prompt you when it is appropriate to connect the printer to your computer. white_square.gif Cancel new hardware detection.
As a reminder: If your system displays a found new hardware dialog box, click Cancel, and then disconnect the USB cable from the port on your computer. white_square.gif Turn on your computer. Start Windows.
If you have not already done so, turn on your computer and start windows. white_square.gif Close all applications.
If any Windows applications (including any virus checkers) are open, close the applications. With the applications closed, you must ensure that the software installs properly.
If your current printer purchase is replacing a MultiPASS printer, you must remove the MultiPASS software installed on your system before installing the new printer. For instructions on removing the MultiPASS software, see the software user's guide that came with your MultiPASS software.
Please vote if this helps ... Cheers :)
Jul 31, 2009 | Canon Office Equipment & Supplies
USB port problems with hp printer
use 2.0 ports and not less than that.if still nothing works out,check your port connections or that of ur printer.
Jan 03, 2009 | HP DeskJet 3745 Printer
My printer will not print documents
Yes definetely something wrong with the USB cable or the Device driver.
Please check in the Device Manager, for printer entries if not showing anything marked.
Also check the Event Viewer for any red cross entries in "System" and "Application" related to printers.
Please click >> Start >>Control Panel >> Administrator Tools >> click >> Event viewer in the event viewer click on application.
Regards,
Ellin
Oct 20, 2008 | Office Equipment & Supplies
There are few things to remember using USB.
  • If your System is in hybernation mode, don't remove any attached USB device, because it will damage your USB driver. This is one of the known problem from microsoft.
  • If you have to remove any USB device use 'Safely Remove Hardware'.
To remove currepted USB drivers its not enough to remove your printer drivers.
  1. You should un-install the 'Universal Serial Bus Controllers' from Device Manager.
  2. Then re-boot to clean registry.
  3. Install the 'Universal Serial Bus Controllers' using XP Setup CD.
  4. Then check the Mass storage, PDA etc, it should recognized by XP.
  5. Then install printer driver (don't attach printer to system untill setup finish or setup says to connect).
I think it will fix.
Please let me know your feed-back.
Thanks
Iqbal
Apr 15, 2008 | HP Photosmart C3180 All-In-One InkJet...
k24674
jasbo
jasbo
