Question about Siemens Dryers
Siemens dryer wtxd5500uc/01 won't start
Display seems fine, door is closed, lint filter is cleaned, but the dryer will not start.
SOURCE: lint filter wanring signal
I posted in late December on the lint alarm and what I discovered was a bit alarming. (no pun intended) Lint had been accumulating on and around the heating coils used to dry our clothes. Some of the lint was burnt and the remainder, amounting to a small handful, was caught up in other area's around the lint sensor. After carefully cleaning the heating coils (with a tooth brush) and removing the rest of the lint and successfully putting everything back together, we have not had a lint alarm issue since. (Touch wood). No need to replace the lint sensor or any other parts. It was not that hard to take apart the back and remove the heating coils to clean, but it requires the unit to be unplugged, careful attention to what came off and where it goes back on. After what I found, I will be cleaning the heater coils out once a year. Which then raises the question. Should a person have to do this? The obvious answer is no! But from time to time we buy things that are not what we would expect and do what we need to do to make it work. From what I can tell, lint is getting past the lint filter and ending up where it shouldn't be. Hope this helps any of you that are having the same issue.
Posted on Jan 12, 2009
SOURCE: LG dlg5988W Gas Dryer - flashing "clean filter" light
i got the same problem and no repair man could help . i think i just got mine fixed 6-15-09 .what you do is go behind the dryer , remove the air duct and then remove the pipe that is inside the machine by removing one screw . this will give you access inside the machine .first clean as much as you can of the lint inside by vacuuming it . if you look to the left you will see 2 wires with a black button in the middle this is the ignitor ,clean it good because i think the dirt is not allowing it to light up . i did that and mine is working but the cooling light is still on .
Posted on Jun 16, 2009
57 varieties
  • 1653 Answers
SOURCE: Samsung dryer DV448AEP/XAA - lint buildup
Yes this is rellatively normal as clothes are just not made the same way any more. You could turn down the drying temperature slightly and put in an anti static drying sheet but it won't make that much difference.
Posted on Oct 13, 2009
Testimonial: "I just had a repairman out because the dryer was no longer heating. The whole inside of the dryer was full of lint. It was awful. "
  • 3 Answers
SOURCE: Bosch Nexxt 500 series gas dryer lint building up inside dryer
Absolutely those dryer sheets are the root of all evil....I would also recommend a good vent brush to clean your dryer vent.
Follow these steps, it worked for me:
1. use a shop vacuum to clean out the dry vent or a vent brush.
2. Clean your lint filter with windex, hot water and and soft bristle brush.
If this doesnt work try running the until disconnected from the vent for a cycle to isolate the vent as your issue
Posted on Dec 01, 2009
richroth
  • 9472 Answers
SOURCE: my kenmore elite dryer will not start up,all the
There are some things about the "Check Lint Screen" light you should know. It's a reminder light and doesn't actually check anything. When you select a cycle it should come on and stay on until the Start button is pressed, the door is open or after 5 minutes.
If the Control Lock is not turned on then you may have to replace the console/interface to resolve this problem.
A hard reset is used to describe a reboot process. With the dryer stopped and the control turned off (if possible), unplug the dryer to completely disconnect electrical power. If it is difficult to reach the dryer outlet plug, you can shut off the breaker for the dryer to completely disconnect electrical power. Leave the electrical power completely disconnected for 5 minutes. This will sometimes reset a control board that is stuck due to a power surge or glitch encountered through the electrical lines. Plug the dryer back in to see if the control will operate properly.
If the control does not reset and work normally after the hard reset, then you could have a stuck "touch up" button on the control. The image below describes a diagnostic test mode that can be entered to check the buttons on the control. If you are able to enter this mode, you can check to see if the "touch up" button is stuck. You may not be able to enter this mode with a stuck button, bad user interface control board or a failed machine control board. If the dryer will not go into this diagnostic test and the console will not respond to other cycle selections, then I recommend calling a service technician to diagnose and repair the dryer. It is likely that the user interface control board will need to be replaced.
Test Mode Sheet
Posted on Dec 11, 2010
I own a Bosch Nexxt Series Electric Dryer, the clothes come out with a petrolium smell, grease or something. I have cleaned the trap, duct work, bearing shield to no avial. It is not the washer, the
Instructions
Dryer Does Not Turn On
Ensure that the dryer's power supply cord is firmly plugged into an electrical outlet.
Inspect the structure's fuse box for a tripped fuse. Each fuse is assigned a single "On/Off" switch. If any fuse switch is in the "Off" position, flip that switch to the "On" position. If the problem persists, contact a professional electrician.
Press the "Start/Stop" button on the left side of the dryer's control panel.
Close the dryer door firmly so that the door clicks into place. The dryer will not operate if the door is not shut.
Lint Filter
5
Clean the lint filter. Twist the program selector knob on the control panel to the "Off" position, then open the dryer door. Pull the lint filter out of the dryer. The lint filter is located at the front of the dryer's tumbler, and is inserted vertically into the dryer. Gently stroke your hand over the filter to clear the lint, then reinsert the filter and close the door.
6
Turn the dryer off and allow at least 30 minutes for the dryer to cool, as excessive heat can cause a drying program malfunction.
7
Increase the ventilation of the room the dryer is located in, such as by opening a door or window. Excessive heat will cause the dryer to automatically turn off until it cools as a safety measure. Increasing the ventilation will help keep the dryer cool.
Clothing Not Fully Dry
8
Clean the moisture sensor. Open the dryer door to access the moisture sensor. The black-colored sensor consists of two bars, and is located at the front of the dryer's tumbler, to the left of the lint filter. The sensor should be cleaned with a clean cloth and white vinegar once per month.
9
Clean the lint filter. Twist the program selector knob on the control panel to the "Off" position, then open the dryer door. Pull out the lint filter. The lint filter is located at the front of the dryer's tumbler, and is inserted vertically into the dryer. Gently stroke your hand over the filter to clear the lint, then insert the filter back into the dryer and close the door.
10
Spin the laundry at a higher spin speed in the washing machine before placing the laundry into the dryer to reduce the moisture content.
11
Turn the dryer off and allow at least 30 minutes to pass for the dryer to cool, as excessive heat can cause a drying program malfunction.
Jan 09, 2013 | Bosch Nexxt WTMC 3300 Electric Dryer
LG DLG5988W
check your door interlocks and connections
Mar 15, 2008 | LG DLG5988 Gas Dryer
Tip
Bosh Dryer Lint Problem
When your bosh dryer stops working and the lint light filter turns on ,close door and start again.This time push door and hold so that the door is closed more tightly.This time dryer should work.
To fix this ,remove the door then remove hinge bracket .Under the bottom part of the bracket insert plumbing ruber gasket.This will adjust the dryer door,it should close more tightly.
Lint light should not turn on again and dryer should work fine.
Please let me know is this works for you.
Since the adjustments of my dryer door, I have not had any problems.
If you have any questions, just ask.
P.S- I know it may sound weird to do this, but since I had adjusted the door this way, the dryer does not turn off during drying sessions.
leco
on Mar 12, 2010 | Washing Machines
I have a Kenmore HE 3, model number 110.8787,8789. I cleaned the lint screen, unscrewed the plastic that holds the screen and cleaned all lint out. After doing so, my dryer won't start. The lig
when you removed the screen from the inside you disconnected the wires from the 2 metal strips. now you need to remove the lower panel on the front. and reconnect them. you will need a T-20 torx and unplug the dryer to be safe. the wire will have 90 degree push on connectors and it does not have any polarity concerns. the two male connectors are real close to the top of the panel, maybe even slightly under the other panel. By the upper right of the silver fan duct.
Jan 02, 2012 | Kenmore Dryers
My friend has an xqg65-11 all in one that she bought used. It worked fine for a few weeks, then started to not move to the next cycle, it just stopped. She has been manually clicking it to the next cycle....
There is a lint filter right under your washer door. You push that lid open, and you will find the lint filter. I have the same machine. but min is an xqg50-11. Is that a washer/dryer combo?
Jul 20, 2011 | Haier XQG50-11 Front Load Washer / Dryer
My siemens electric dryer will not start a cycle. The lint filter light is on, but dryer will not start. All ducting is clear. Is there a sensor that could have gone bad? I see two on bottom of lint...
One is a thermal limiter that operates the heating element and the other is a moisture sensor.
Check to see that the door switch is operating properly with an ohmmeter (with the power disconnected, of course).
Feb 21, 2011 | Siemens WTXD5300US Electric Dryer
Dirty Dryer
its blows dirt lint by the seall more when the vent going out home is pluging up need to desasemble dryer to clean it out
Mar 20, 2008 | Dryers
Bosch Tumble Dryer Filter Light
Helenhjb, there is a couple of things I can think of that can cause this. The filter is one. The mesh on the filter is extremely fine, so get a steady stream of water running, then put the filter under the water. If the water doesn't run straight thru, then wash the filter with detergent until the water does run straight thru. If this works fine, then your issue may be that the door switch is set too far back and when you do heavy loads, the laundry pushes on the door and shuts down the dryer. On the Bosch, any time you open the door during the cycle, it will flash the lint filter lamp. The only other thing I know of usually has an E:01 flashing on the display is restricted vent. Hope this helps.
Jan 29, 2008 | Dryers
Bosch Dryer lint filer warning
The Bosch Dryer has a temperature probe in the heater exit and in the exhaust area visible when you open the door. If the temperature difference between the two gets to high, the lint filter is assumed to be plugged and the alarm goes off.
It seems that the temperature probe at the heater, can end up with a faulty connection to the control panel over time due to corroded contacts or lint build up. When this happens the control panel thinks the filter is clogged and it may also not turn on the heating elements properly. Remove the back cover over the heating element (12 screws) and then remove the one screw holding the red wiring connection to the dryer body. You can then wiggle out the wiring connection and clean / unplug and replug in the connector for the sensor. (plug with two small wires only). A little hard feeding the connector back through the hole so take your time and don't damage the wires). Should all work again. May want to inspect inside the heater at same time and make sure the overheating switch is not tripped. ( press in the red button).
May 21, 2007 | Bosch WTMC3510UC Gas Dryer
Dryers Logo
171 people viewed this question
Top Siemens Dryers Experts
Tim Whalen
Gerry Harvey
Gerry Harvey
Craig Butler
Craig Butler
Are you a Siemens Dryer Expert? Answer questions, earn points and help others
