Question about KitchenAid Refrigerators
Ice maker won't work
I have a kitchenaid refridge kssc42qms01 that has sat for 1 year. I can not get the icemaker to work. What do I need to do?
  • KitchenAid Master
  • 19,396 Answers
Check that lines are not frozen.
Check the inlet at the back of the fridge, ensure is not blocked.
Defrost unit completely to ensure it is not a frozen lines problem.
Check icemaker inlet valve, solenoid, and mechanics.
Here diagram and parts for your fridge's icemaker.
Posted on May 20, 2009
Kitchen aid icemaker won't dump
Sounds to me that you need parts or as most Whirlpool/Kitchenais Ice Makers their averagte life is 5 years. Call before purchace to confirm but here is what I have for the complete Ice Maker=> 4317943 Ice Maker Assembly
For much more info click here=> Broken Ice Maker Repair
I will be here if you have any other questions, Thanks, Sea Breeze
utube.png You-Tube video "VCUgA5T5ASw&feature=player_embedded#!" placeholder
Sep 18, 2011 | KitchenAid KSCS25FKSS Side by Side...
GE refridge icemaker won't work
The ice maker unit give the command to the water valve to relese water for a short time.
you cna check with volt meter on the water volve that got the pip go to the ice maker unit if it getting 120V for short time when the fingers of the ice maker making full round.
if you get 120v the problem is the valve (the ice maker and the water have difrent water path so its difrent valve used) if you dont get 120v or the fingers of the ice maker not turning then its your ice maker unit need to be replace.
I hope you find this Very Helpful and best regards!
Jan 03, 2010 | GE Refrigerators
The icemaker on my KitchenAid superba KSBS25in does not work
Their might be an easy fix here. Try a hair dryer. heat the ice maker and dislodge a possible stuck ice cube( a common problem)
More HERE
Dec 15, 2009 | Kitchen Ranges
Kitchenaid ice maker not making ice
first check the tube running to the ice maker where the water flows in see if it is frozen if not take the cover off the ice maker front and see if the little tabs in the middle of the gear is broken there are two one might be broken off
Mar 30, 2009 | Refrigerators
Icemaker does not make ice after first harvest.
theres whats called a cam inside of the ice maker and that is more than like;ly the problem. you can but your own ice maker from place like first service. good luck.
Jan 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
No ice in the icemaker
what is the temperature inside of the freezer? it should be below - 2 degrees before the cemaker will work.
Dec 27, 2008 | LG LRSC26980 Refrigerator
Icemaker won't fill
its a tricky one to diag, this IDI{in door ice maker}. id be interested to see something in the ice maker head assy itself, under the right side bottom of the ice maker asssy is a 1/4in screw, holding a cover for the wire harness,if you remove the screw and the plastice cover it will allow you to slide the ice maker assy foward, youll need to depress a small plastic tab on the left side wall preventing the ice maker from coming out any more than an inch or so. After that the ice maker will twist out and by inserting a screwdriver into ice maker cover you be able to "pop" off the front white cover to reveal the inner workings. a problem with some of their modules is that the center white gear actually cracks off the module head itself, if thats the case when you open the cover, youll need to replace the ice maker assy
Oct 25, 2008 | Refrigerators
Kitchenaid Superba Ice Maker quit
If you add some water there, yourself. It should make some ice for you, untill the water runs out.
Try this
http://www.acmehowto.com/howto/appliance/icemaker/diagicemaker.php
Sep 08, 2008 | KitchenAid Superba Architect KSCS25INSS...
Rubber door gaskets very warm to touch, ice cream soft, ice ok
the icemaker will work until the frezer gets to 17 then it will quit sound like a defrost issue defrost heater defrost thermastat or defrost timer need to get it fixed sooooooon you dont want to loose food at the price we have to pay
May 08, 2008 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
247 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
