Question about QuarkXPress
Color matching When bringing in files from Illustrator 10 to Quark 7 The colors are all not matching. I am using the same Pantone color profile in both programs but getting different colors when imported into Quark. I am on MAC OSX v7.5
    Problem Solver:
  • 8 Answers
If this is a print problem and not just a screen issue, here's what I suggest.
In Illustrator, double click the colour swatch for the Pantone Book colour you are using and obtain the CMYK values.
In Quark, instead of using the same Pantone Book colour, create a new Process colour with the same CMYK values as the Illustrator swatch.
Posted on May 28, 2009
Saved illustrator 10 file gets corrupted
Check for a damaged pattern, gradient, or custom color
To determine if the problem is caused by a damaged pattern, gradient, or custom color:
1. Choose Edit > Select All and change the fill and stroke to process black.
2. Perform task 4 again to determine whether the problem occurs in a new file that does not contain the patterns, gradients, or spot colors. If the problem does not recur, re-create the pattern, gradient, or spot color in the original file.
Otherwise:
First option: http://www.filerepairforum.com/forum/adobe/adobe-aa/illustrator/383-%E2%80%8Bcorrupted-fonts-in-illustrator-file-urgent-help-need
Second: shareware tool Illustrator Repair Kit
See more about:- http://www.illustrator.repair/
Oct 27, 2014 | Adobe Illustrator 10.0 for PC
Hi, i'm trying the PMS code Pantone 2756 C on illustrator Cs4 and what i'm getting on the screen/printed material is completely different from the color bridge that i have
You cannot match a Pantone swatch book to your monitor unless you have calibrated it using something like Huey: http://www.pantone.com/pages/products/product.aspx?pid=562&ca=2 as a monitor is backlit and printed materials are not.
Depending on what sort of printer you are using, it also may need to be calibrated or have its profiles updated.
Oct 08, 2010 | Pantone Color Bridge Uncoated
I am the Graphic Artist and Printer for a public library. We have a logo that has the Pantone color PMS 375 green in it. I mix my own inks and have no problem reproducing the color properly on a printing...
Laser printers, although they have a larger color gamut than a CMYK offset press, still will not be able to reproduce a majority of Pantone special colors.
Professional inkjet printers, especially those using more than 4 inks, are far better at this - the ink pigments are more color-pure and concentrated than those in laser toners.
Remember, that Windows print drivers work in RGB, and use ICC profiles to convert color data to CMYK components for printer. If you have a CMYK file, and look at it on your monitor, it's converted (using monitor ICC profile) to monitor's RGB colorspace, and then back to CMYK with the printer ICC profile when printed. Converted twice with ICC, which always introduces distortions...
If you have a properly calibrated monitor, and a good printer profile installed, you have better chances of reproducing screen colors on the printer, especially if you work in RGB.
As a simple, but laborious solution, I would suggest preparing "swatch sheets" yourself using some graphics software. Preferrably in RGB, not CMYK. A series of gradients with the green component going from, say, half way to maximum, and other components in various combinations, like R0 B0, R10 B0, R20 B0,... then R0 B10, R10 B10, R20 B10... and so on. Print those, and try to find a spot in the gradients that is the closest to your color sample, and then make swatches with smaller increments around that color to find the best RGB combination.
Good luck :)
Nov 13, 2009 | HP Color LaserJet 5550hdn Printer
Phaser 8560 Colors are Off
Here are the directions for Tec Color correction. If this doesnt work then replacing the print head is the most likely solution. The TekColor correction options provide simulations of different color devices. Automatic is the default correction for general image processing. Use the following table to determine what option you want to use. TekColor Description Automatic Applies the best color correction to each graphic element: text, artwork, and photographs Office Color sRGB Display: Approximates the colors on a computer display. sRGB Vivid: Produces brighter, more saturated colors than sRGB Display. Press Match SWOP Press: Matches specifications for Web Offset Publications. Euroscale: Matches Fogra glossy paper specification. Commercial: Approximates U.S. commercial press target. SNAP Press: Matches specifications for Newsprint Advertising Production. None Applies no color correction. Use with other color management tools, such as International Color Consortium (ICC) profiles, ColorSync, or the PANTONE Color Chart for the printer. Black & White Converts all colors to shades of gray From the workstation, select the color correction in a supported driver. Microsoft Windows 98 SE / ME / 2000 / XP/ Server 2003 / NT 4.x Operating Systems (OS): NOTE: Some of the color corrections are grouped under Office Color or Press Match. 1. Within an application, click [File] from the toolbar, and then select [Print] from the menu. The Print window will be displayed. 2. Click on the [Properties] button located on the top, right of the window. The Properties window will be displayed. 3. Click on the [TekColor] tab. 4. Select the required color correction. Apple Macintosh OS 9.x: 1. Within an application, click [File] from the toolbar, and then select [Print] from the menu. The Print window will be displayed. 2. Click on [General], and then select [TekColor] from the pull-down menu. 3. Select the required color correction. Apple Macintosh OS X, (version 10.2 and higher): 1. Within an application, click [File] from the toolbar, and then select [Print] from the menu. The Print window will be displayed. 2. Click on [Copies and Pages], and then select [Image Quality] from the pull-down menu. 3. Select the required color correction.
Jun 08, 2009 | Xerox Phaser 8560MFP Laser Printer
Dull colors on 8550 phaser printer
Looks like you don't use the Magenta ink that much, on this machine because it is so hot all the time after a while the magenta can get a strange brown colour and the cyan can get like a aqua marine colour. All you can do is purge the magenta by printing magenta sample pages or just wait until it goes away.
Also you could try the following Tek Colour correction (but It probably won't work). See below
TekColor
Description
Feb 20, 2009 | Xerox Phaser 8550DP Printer
Imac / illustrator10
According to something I read in another forum:
Use migration assistant (in utilities) to copy over Illustrator 10 via firewire from your G4 to your imac. This is the only thing that might work without upgrading to a newer version of Illustrator.
I'm planning on trying it with both Illustrator 10 and Indesign 2.0 - Photoshop 7 won't go at all no matter what one tries according to what I've read. I'll be upgrading to CS3 for Photoshop. No choice.
Jun 29, 2008 | QuarkXPress Passport 6.0 for Mac
Color printing problem~only green, yellow, blue
TekColor
Description
Dec 05, 2007 | Xerox Phaser 8500/DN Printer
Bizhub C250/252 ICC Color Profile
HI i am fron DPI Grafica SH and have made test of diferents ICC profiles.
I will tell you how is my system to get to correct colors an sharp texts.
First - i print fron Adobe Ilustrator or Adobe PDF Profesional. If you have your file in Corel Draw export it to pdf or Publish a PDF File.
Second - I select s"sRGB IEC6 1966-2.1" this profile prints acurate fonts and colors that match whit de monitor. Is a little bit desaturate if you compare with " COATED Foagra". This one prints blurry fonts and blur edges.
This is the best result that i can get after print tests with all de ICC profiles.
Greetings and i hope that you can solve this problem.
Nolasco.
Oct 12, 2007 | Konica Minolta bizhub C250 All-In-One...
Flash File Overall Color and Contrast too light
MAINLY CONTRAST OF THE FILE IS DUE 2 BRIGHT COLORS. SO YOU BETTEER 2 USE LIGHT CLORS. & BRIGHTNESS MUST BEE REDUCED 2 SOME WAT ACCORIND 2 YOUR PROJECT
Sep 26, 2007 | Macromedia Flash MX
Error 1168: Calibration Data not found
You have to put the file C:\WINDOWS\SYSTEM32\spool\drivers\color\spyder2express.icm into display properties (click right on the desktop, select "properties", parametres, click on button "advanced" and tab "color profiles"). I use a french OS, so words may be different.
Sep 13, 2006 | Pantone ColorVision Spyder2 monitor...
QuarkXPress Logo
122 people viewed this question
Top Quark Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Michael Galve
Michael Galve
Are you a Quark Computer and Internet Expert? Answer questions, earn points and help others
