Question about KitchenAid KGSI901PBS Gas Kitchen Range
AM71 U173 EEKGO 092
It comes up with this code when plugged in then it disappears and goes to set clock but it will not let me set the clock. None of the buttons work when pushed. I tried to unlock the control board and again nothing.
3 Suggested Answers
  • 93 Answers
SOURCE: setting the clock
Remove the plug from the socket for a few minutes. Then plug it back. Does the clock control blicking? look at the pictures on the control as a whole.
Do you see anything like a table clock? press it once, then press the numeric pad or up and down arrow button depending on the model you have. press enter or start if set correctly.
Posted on Jul 24, 2008
SOURCE: I'm getting error code AM71 UI75 EEKGO-097 on my kitchenaid stove. The oven is not turning off unless I unplug. Please help.
That is the model #. ID
Posted on Dec 24, 2016
Error AM71 UI44 EEWET107 when I replug the oven broil does not work
Whirlpool RBD305PDS Electric Double Oven Repair ... - Fixya
www.fixya.com > Forum > Ovens > Whirlpool
Whirlpool Oven has an F1E1 error code. Whirlpool Ovens ' Answered on Nov 04 ...Whirlpool error code am71 ui44 eewet107 ยท Whirlpool Ovens ' Posted on Nov ...
Sep 12, 2015 | Ovens
Xerox workcentre 6015 ni error code 092-651
Printer CM205 b error code 092-651
Options My printer FUJI XEROX CM205b is showing an error code of 092-651 with a sub code of 2080000. I have no idea what this means or how to go about fixing it. this has been a great printer and would like to fix it if possible.
Thank you for the help.
Apr 12, 2014 | Xerox WORKCENTRE 6015/Ni Color
Am71 ui42 eewet107
Am71 ui42 eewet204
Feb 18, 2014 | Cooktops
I'm not sure exactly what that error code means, but being a technician I can tell you the control board and the oven sensor need to be replaced. The control board simply because it tells the oven what to do and when to do it, the sensor because its a rule of thumb because the two work hand in hand and because its a cheap part and with the situation has more than likely taken damage of some sort.
May 07, 2012 | KitchenAid Stove / Oven / Range Infinite...
How do you get the clock to operate on a battery only (uses a 9V). I insert the battery, then unplug the clock. The display is dark. But when I plug it back in, it is on the right time. If there was a...
They're just used to retain memory. That's all. Once power comes on, the time should be correct. Now if the power went out and there was no battery on the clock, when the power comes back on it goes straight to flashing 1200.
Jun 28, 2011 | Westclox 181961 Omni II Clock Radio
Panasonic microwave nn-sn668b.. after cleaning it earlier today i went to use it and it didnt work. the time reads 00:00 as if a loss of power had occured (but didn't). The only button that seems to...
If the clock is not set, nothing will work as the controls require the time to be working. Press Clear/stop twice and press clock, set time and press clock again.
Hope this helps.
Dec 23, 2010 | Microwave Ovens
2000 Lexus RX300 clock won't hold memory. We have a 2000 Lexus RX 300. We took it in for a check engine light and to change spark plugs and timing belt. When we got it back, the clock will not hold it's...
tony none of those repairs should have affected the clock in any way. sounds like an unlucky coincedence, but you should go back to the place where repairs were performed and ask them to check it for you. a health check should be performed to se if any fault codes are present.
Sep 27, 2009 | 2000 Lexus RX 300
Keypad automatically goes to locked.
Need to replace the front panel. Try www.partstap.com
Dec 30, 2007 | Kenmore 62622 Microwave Oven
KitchenAid KGSI901PBS Gas Kitchen Range Logo
47 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
