Question about Garmin nuvi 260W GPS Receiver
It can only be used when it is not charging...there are 2 problems with this. 1.If it is not already charged by the time I need it, I cannot use it. 2. If I am driving for a long distance and the batt
I have the Garmin Nuvi 260W. It can only be used when it is not charging...there are 2 problems with this. 1.If it is not already charged by the time I need it, I cannot use it. 2. If I am driving for a long distance and the battery runs out, I have to turn it off to recharge it and hope that I didn't have to exit or turn before I can turn it on again and use it. Unless I constantly have it charging so I dont' have to predict when I need it, I can't use the device. Even if I have it charged, however, if I have a long trip this won't solve the problem.
  • bigpappi24 May 20, 2009
    Nuvi 260w will not charge and will not turn on when plugged in. Makes it kind of useless. Any ideas?
  • jmuasher May 20, 2009
    You're right. I ended up calling the customer service line too and although my blackberry phone charger fits in the Nuvi260W and charges it, it locks it from use. Only the adaptor allows for charging and usage simultaneously. Thanks!
    Problem Solver:
  • 14 Answers
Same thing happened with me. But got the workaround......as you are connected the other end to the car battery charger, remove it after starting the vehicle and observe that GPS would act like it is starting. As soon as gps shows "loading maps" insert the power end that you removed from the car charger socket and gpw would continue with the car power.
I hope this help.
--Sandeep.
Posted on May 26, 2009
I believe you need the power adaptor instead of the charger.
Posted on May 20, 2009
Sonic scooter will not go,first turn on status light blinks 1 time then 2 times, 1 time then 2 times then 3 times then 1 time 3 times then 1 time and continues that 3 and 1 blinking, what can I do?
Test batteries to see if they full, the controller thinks either you need to charge the batteries or it is over charged. 2 beeps need charging, 3 beeps overvoltage.
Sep 28, 2015 | Sonic Health & Beauty
Ups is not working
The battery is defective. first, you have to check the voltage of the battery if low than 12 volt need to charge. Try to charge the battery outside the unit. if this is already charge in 2 hrs then install it. check you ups if works. fyi. Battery last only for 1 year or 2 years depend on the use. Your lucky if reach higher year of use.
Aug 15, 2011 | Refrigerators
The gyropter will not charge when I plug it in
Check the charger adaptor if it has any output power. If no power comes out replace the adaptor.
Check also the battery terminal, it might already corrode and needs clean up.
If all does not work, the battery in the helicopter is already malfunctioning.
hope that helps you out!
Aug 14, 2011 | JCPenney Gyropter RC Helicopter
Hi I m salman And i have 5200 mobile phone but there is one problem That's problem is keypaid problem i have already change keypaid i.c but that problem still remain i have cheked the board properly...
short battery life is contributed to these, 1. Old battery 2. Lots of apps running in the background 3. Taking lots of photos 4. Charging the phone when it does not need a full charge 5. Leaving your phone in direct heat or cold 6. Dropping the phone 7. Leaking battery 8. 1 year or more old battery 9. Continuously talking and charging at the same time 10. Ensure to contact your insurance to see if the battery is protected under your plan
Jan 26, 2011 | Nokia 5200 Cellular Phone
My Seiko never seems to charge enough to pass the first "indicator" scale. After a few minutes of charging it by swinging it back and forth, then wearing it all day and night; the next morning I get the "2...
There seem to be three possibilities
(1) the battery is not taking charge
(2) the generator is not charging the battery
(3) you need to swing it for much longer (one maker said swing their watch several hundred times!.
I suggest your try the easiest first i.e. No. 3.
If this does not improve things, go to your nearest dealer and discuss your problem with him.
If you need a service center, you can find out where one is by going to their web site (seiko.com) and click on "support".
Feb 13, 2010 | Watches
Honda cbr 2004 my bikes stalls an wen i come to a complete stop it turns off
To clarify.... Have you had it on a trickle charge? Do you ride it all the time? Alarm? Sounds to me (with out being there) like a common problem....But I would need to hear it. Does it run sluggish just before it stalls or dies? If yes to most or all of those it may be that your battery isnt hold a charge. You have to run your bike at high RPM for it to properly charge. Just starting it in the garage from time to time dosnt really charge the battery. Take it to autozone and get a good charge on it if you havnt already. It take 3 hours to charge that battery fully. Also another 2 things strike me as well. 1.It could be the tilt sensor isnt operating properly. 2. The kick stand sensor or kick stand loose. I would try those first. Let me know.
Jan 14, 2010 | 2004 Honda CBR 1000 RR Fireblade
NOKIA 5310 not charging? i already replace a new battery and check the power adapter,,(thanks for helping sir brukau747) and test the output voltage of my charger,,and they are all good,.any solution to...
Eventually the problem was internal hardware, the charging terminals has a problem and that's why you getting this error on your unit while you try to charge your cellphone,
You have an alternative to use a desktop charger in able to charge the battery, or you may bring the unit for repair.
Hope this helps
Sep 01, 2009 | Nokia 5310 Cellular Phone
Dell latitude D600 battery charge light flashing
Go to support.dell.com and download the latest bios firmware to update it. If it still does not work then most likely it is already a hardware issue so you need to contact dell support for the hardware issue.
Jun 03, 2009 | Dell Latitude D600 Notebook
Kodak M753 wont charge
I hope this will work for you.
Clean all the gold termanels with a cotton swab and a little alcohol.
Make sure all surfaces are dry. Before you try to use it.
Apr 08, 2009 | Kodak Easyshare 1725043 M893Is Digital...
Charge
hi your battery has created a memory because you didn't follow simple battery guidelines:
For a new phone with a new battery;
1)Use the phone the first time until the battery dies,
2)Do a full charge - 6-8hours for the first time
3)Use the phone until it dies the second time
4)recharge the battery for 3-5 hours
then your battery should be good, but now your battery needs to be changed, as it already has memory and can only be restored if completely discharged by a battery conditioner
Jan 30, 2008 | Motorola Mobility RAZR V3
Garmin nuvi 260W GPS Receiver Logo
536 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
