Question about E-Machines eMachines Refurbished EMA SYSTEM BOARD MODEL T2984 eMachines (102257) PC Desktop
Adding ram can't find the maximum amount of ram for ECS M907V12 1.0 motherboard. It has two slots. 256MB installed. The slot is open.
Max RAM is 2GB.Users manual page 2.
Cau. Jano
Posted on Oct 28, 2010
    Scholar:
  • 81 Answers
Go to your google search bar and type in SIW, download the program and run it, when you get it up and going to can scroll to the hardware catagory to memory, it should tell you what your maximum memory is you can install.
Some premanufactured computers like the Dell 8400 I'm using right now will only recongize 3GB, but it will actually take and use 4GB.
SIW should help you out a bunch.
Good luck
Posted on May 20, 2009
  • 326 Answers
Http://www.crucial.com/uk/systemscanner/?click=true
download the scanner from that site then run, will tell you everything about your motherboard
hope it helps
Memory settings for ddr
http://www.motherboards.org/mobot/motherboards_d/ECS/K7AMA/
Since the Processor Front Side Bus (FSB) support is 200 or 266MegaHertz (MHz), the ram memory will be DDR Sdram at either 100Megahertz or 266MHz.
That is PC1600 and PC2100, respectively.
2GB's maximum TOTAL amount for motherboard.
1GB per ram memory slot - Maximum
If you have a Socket A (Socket 462) AMD processor with a 200MHz FSB, I suggest DDR Sdram at 100MHz. (PC1600)
AMD processor with 266MHz Front Side Bus = either PC1600, or PC2100. I would go with PC2100.
Voltage in BIOS Setup is 2.5 Volts. That is is the JEDEC standard voltage, for DDR Sdram.
Ram timings will be dependent upon what the ram memory supports.
IF you have just ONE ram memory module ('Stick'), it goes in Slot 1.
(DIMM 1)
This is the ram memory slot the Processor reads first.
http://www.cpu-upgrade.com/mb-ECS/K7AMA%28V1.5%29.html
http://www.ocinside.de/go_e.html?http://www.ocinside.de/html/workshop/ecs_k7s6a_vcore.html
http://8000.hillbillyhardware.com:8000/Reviews/ecs_945gcd-m/ecs_945gcd-m.html
"When it comes to innovative motherboards ECS is not a company that first comes to mind. Not since the days of the K7AMA that offered DDR266 and PC133 memory options for AMD's K7 line of processors has ECS released a motherboard that has filled a gapping hole in the PC hardware market space. Lets just hope that the failure rate of the 945GCD-M is nothing like the failure prone K7AMA."
Hmmmmm,
Not doing it for you? Then post more details in a Comment.
Regards,
joecoolvette
Jan 03, 2013 | EliteGroup K7AMA Motherboard
MS 6368 VER 5 MEMORY
It takes SD Ram, Which is no longer available. Below is the lonk to the Specs.
Link:
Mar 09, 2012 | Computers & Internet
Can I install more than 512mb of memory on a Presario s5300nx. I actually want to do 2gb or more. If so, how can i safely do it w/o messing up my computer. Thank you.
> I want to do 2GB or more.
As the Rolling Stones sang, "you can't always get what you want".
See: http://www.memorystock.com/ram/CompaqPresarios5300nxRAM.html
which states that your motherboard has 2 RAM slots, with a maximum of 512MB per slot.
So, how many RAM slots currently are empty, and how much RAM is installed?
If you currently have 2 sticks, at 256MB/stick, you will need to remove both sticks, and install two new sticks.
If you currently have 512MB of RAM, and one empty slot, then that web-page describes the exact type of RAM that you can insert into that empty slot.
Jun 26, 2011 | Computers & Internet
How many slots for dram chipsets? For AZ11/ AZ31 motherboard? Thanks!
FIC AZ11 (First International Computer {Inc}
3 Ram Memory slots.
Supports SDR Sdram at 100MegaHertz, or 133MHz. (PC100, and PC133 respectively)
Maximum Total Amount is 1.5GB
Maximum Amount for EACH ram memory slot is 512MB. (1/2GB.)
Uses the VIA KT133 motherboard chipset,
(Northbridge - VIA VT8363
Southbridge - VIA VT82C686A/B)
http://en.wikipedia.org/wiki/List_of_VIA_chipsets#Slot_A_and_Socket_A
Socket A processor socket for AMD processors. (Also referred to as Socket 462)
http://www.xbitlabs.com/articles/mainboards/display/fic-az11.html#
FIC AZ31
3 Ram Memory slots
Same type of ram memory as above, same total amount, and amount for each ram memory slot.
Uses the VIA KT133A motherboard chipset.
(Northbridge - VT8363A
Southbridge - VT82C686B
Socket A processor socket.
http://en.wikipedia.org/wiki/Socket_A
http://www.baber.com/baber/411/fic_az31.htm
Oct 30, 2010 | FIC AZ 11E Motherboard
If i change the ram stick will my pc reconise it
Yes.
Provided,
1) It is no more than the maximum amount, for that ram memory slot.
2) Adding it, will not go over the Maximum Total Amount for the motherboard.
If this pertains to an Acer Aspire T135 desktop computer,
A) The Maximum Total Amount is 2GB.
B) The Maximum Amount for Each ram memory slot is 1GB.
C) PC3200 is the best you can use.
DDR Sdram at 400MegaHertz. (400MHz)
[It can also use PC2100, and PC2700.
DDR Sdram at 266MHz, and DDR Sdram at 333MHz, respectively ]
Once you install the ram memory, BIOS should automatically find it.
If you are only going to use one ram memory module, be sure to put it in Slot 1.
The Processor reads ram memory in Slot 1 first.
[Slot 1 is closest to the Processor.
It may have DIMM 1 printed on the motherboard, next to Slot 1 ]
Jun 21, 2010 | Acer Aspire T135 PC Desktop
T2742 Desktop eMacine I want to upgrade the RAM from 256 MB to 1 GB. Can I replace the single 256 MB memory board with a single 1 GB memory board? Or, should I use two 512 MB memory boards?
Maximum Total Amount is 1GB.
EACH ram slot's Maximum Amount is 512MB.
Note* If you only install one ram memory module, make sure it goes into Slot 1.
(On the motherboard it may have DIMM 1, printed next to the slot)
Slot one is closest to the Processor. The processor reads ram memory that is in Slot 1, first.
Apr 16, 2010 | E-Machines T2742 PC Desktop
I have a intel 845GL motherboard with 1.7Ghz
2 x 184-pin DDR DIMM socket support up to 2 GB
recommended: 1GB x 2 DDR 333
http://www.svbinternational.com/motherboards/motherboard_845_chipset.htm
contact ur system admin/vendor for more details....
Nov 02, 2009 | Computers & Internet
Adding memory to a a75-s211
How much memory did it have before you removed the 256Mb RAM?
If it had 756Mb RAM then the memory in the laptop has 512 Mb plus 256 Mb RAM modules, the 256Mb in the slot you can see and possibly 512Mb in a slot under the keyboard or soldered on the motherboard.
Therefore by removing the 256Mb and replacing with 1Gb memory module will give you a total of 1.5Gb
Jun 22, 2009 | Toshiba Satellite A75-S211 Notebook
Beeping noise after installed memory on ecs motherboard L4S5MG
Some older computers, like mine, have a maximum memory they can handle. This one happens to be 1 gig, but yours may be less. Do you have an older computer? Yup, you do. As seen here, the maximum supported ram is 256. I'm sorry. Please rate.
http://www.dealtime.com/xPF-E-Machines-eMonster-500a-EMONSTER500A
Jun 18, 2009 | E-Machines eMonster 550 PC Desktop
E-Machines eMachines Refurbished EMA SYSTEM BOARD MODEL T2984 eMachines (102257) PC Desktop Logo
169 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
