Question about Homelite Consumer Products 4.0 Amp, 13 In. Trimmer
My trimmer is barely rotating no power to cut grass
My trimmer barely rotates to cut grass
3 Suggested Answers
  • 81 Answers
SOURCE: Homelite strin trimmer head wont rotate
The only way to access the bottom of the metal shaft is to break it. This is fused on at the factory. It sounds like your flexshaft has twisted in two. Remove the flex shaft from the engine end and see if it is in one whole piece or is damaged in someway. If it rotates at the top but doesn't rotate at the string head this is probably the problem. However, Homelite no longer offers just the flex shaft for purchase. You would probably have to purchase the shaft and the tube as a unit.
But if you are saying the spool and string is not turning at the bottom it could be that the cup which holds the string has worn and can not longer be turned by the shaft. Replace the cup that holds the string.
Another possibility is that the shaft have moved forward, away from the engine and just need to be jammed back in, and retightened (the handle grip and the boom clamp).
Posted on Jun 17, 2009
  • 20 Answers
SOURCE: how do i adjust the homelite carburetor
if you have had this trimmer for a wile you might check the little muffler to see if it is cloged up with carbon i had on and adjusted the thing till i was blue in the face and pulled the sreen of the muffler cleaned it now it runs great
Posted on Jan 30, 2010
How do you remove trimmer head from a John Deere model 260G Grass trimmer in order to replace with a Ugly Head
Block the arbor from rotating- should be somewhere you can shove in a small pointy object to lock it.
Then, looking from below, rotate the head CLOCKWISE to remove it. (Left-hand-threaded.)
And ... if all else fails, one can read the instructions. :')
Jun 15, 2016 | Garden
How can I remove the cartridge head to clean?
Usually the cutting head will have a couple of plastic tabs you push in to release the spool cover and get access to the spool
Mar 06, 2016 | Garden
Why won't the spool on my B&D weedwacker rotate?
Is it on the right way? Does it face the correct way? Is it clogged with solid grass?
Jul 28, 2014 | Black & Decker Black and Decker & Grass...
Trimmer starts but hardly rotates when giving it gas.
Check for a tangle of grass or wire just above the string head where it attatches to the shaft. A buildup in that area can interfere with the movement of the head.
Sep 10, 2011 | Craftsman Convertible 14" Gas Line Trimmer
Cutting head on 29cc trimmer will not stop rotating at idle,cleaned filter,changed oil, cleaned spark arrester, tried adjusting idle speed, nothing seemed to help
You didn' t list the model number. Have you tried placing the head on the grass? does it stop then? It has a centrifugal clutch, if the idle speed is too fast, it will spin. There could be a broken spring or dirt in the clutch keeping it engaged.
Jul 26, 2010 | Craftsman Garden
The motor works but strimmer does not rotate
If the head does not turn, but the motor runs freely, then the reduction gear is damaged. It is inside the motor housing. If the motor tries to run but does not rotate, then there is likely material bound up between the moving and non-moving parts.
MANUAL:
http://www.dewaltservicenet.com/servicenet_home.aspx?AspxAutoDetectCookieSupport=1
PARTS:
http://www.ereplacementparts.com/black-and-decker-grass-trimmer-parts-c-4167_9518.html
Apr 02, 2010 | Black & Decker Garden
Engine/shaft stopped working. Need to fix Ryobi trimmer.
Hi, I have a Ryobi brush cutter and the engine has a tendency to move up and down the shaft. It also rotates around the shaft
May 16, 2009 | Garden
Line continues to advance and wrap around axle
I used a file to sharpen the line cutter which controls the amount of line. After sharpening the small cutter on the trimmer, the length of the line is now under control and now my trimmer works just fine.
Sep 13, 2008 | Worx 10" 18v 2 In 1 Grass Trimmer/In Line...
Black and Decker Grass Hog Model #GH1000
the drive cable probley kinked or bent and does not drive the head the cable goes from the motor to the head take the clamp bolt out and lift the head off the cutter check the cable
Jul 30, 2008 | Black & Decker String Trimmer Cordless 12"...
Homelite Consumer Products 4.0 Amp, 13 In. Trimmer Logo
183 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
