Question about Panasonic Palmcorder PV-DV52 Mini DV Digital Camcorder
Tape will not eject
My tape will not eject. The door doesn't even open. It makes a noise like it is trying to turn wheels inside but nothing happens.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 122 Answers
Probably tape stuck, unless u know what u are doing take it to a repair shop. Fixing it takes a minute
Posted on Apr 02, 2016
SOURCE: Tape will not eject, and reset button does NOTHING!
I am having the exact sam problem on my PV-GS14. Have you been able to resolve the problem? If you have, how were you able to get the tape out? Thanks
Posted on Nov 23, 2006
  • 76 Answers
SOURCE: Newly Inserted Tape Ejects Automatically
More than likely either the capstan motor or the drum motor are not turning and tape wont load.have you tried reseting by removing battery and reattaching,this sometimes resets micro and all will be fine.If this doesnt work is a job for technician,.
Posted on May 15, 2007
  • 11 Answers
SOURCE: tape rack stayed open
A similar thing happened to me - I took it to panasonic service centre to fix and unbelievably the problem was that the HAND STRAP was quite tight (I have small hands and set it snug) and prevented the door from openeing just another milimetre more, and thus caused the carriage to 'jam'. Loosening the hand strap and opening the door allowed the tape carriage to move properly again. This was a great relief (although I still had to replace the carriage mechanism a few months later.....due to reset button message)
Posted on Jun 09, 2008
SOURCE: power light flashes and tape is chewed.
Try using a head cleaner.
Posted on Nov 05, 2008
leecom72
  • 4806 Answers
SOURCE: Panasonic Palmcorder PV-43D cannot get door open
Hi there.
Sometimes a gentle slap with the palm of your hand with the door facing towards the ground does the trick, make sure you power it off then on press eject while you gently slap it.
Good luck and thanks for using FixYa!!
Posted on Apr 21, 2009
I have a dvd stuck in the slot. It won't play or eject. I hear the tv trying to eject but nothing happens. How can I fix it?
You will need to open up both dvd case and dvd player! the rubber type band that turns the wheels to open tray is bad, not tight enough to turn wheels! This rubber type band is located at the front of tray. you might be able to get tray to open by taping the top front of player after you push eject, just not hard enough to bend case.
Mar 25, 2016 | Televison & Video
The tape won't eject. press any button and nothing happens makes a whirring sound
I would take the top cover off the machine and see what is happening inside. It's clearly trying to get the tape out from the noise.
Aug 23, 2014 | Mitsubishi HS-U410 VHS VCR
Pinch roller stuck in "up" position, eject button won't open door
The very first mistake is to pry a door open. That damages them. You are never to do that. The correct way to get a tape out is to open the unit up and find out why the tape is stuck and then take action to release the door in the normal way- usually it is a loose belt or defective cam motor. As to the Pinch roller there are slide plates and even some pinch rollers had lubrication on them so that may have dried leaving you with a stuck part. The normal order of business is the find out what is stuck and then take action to clean and lubricate the mechanism to return to normal function. The problem with some Pinch Rollers is that there may be a particular spot it needs to be set at. This is true if it has a guide fitted to it. Then you will need either a jig or mirror tape to be able to set it correct again. I can not give any further advice without seeing the unit but this should get you started.
Dec 03, 2012 | Audio Players & Recorders
VHS got jammed, clicks, turns self off
Open it up and next to the right spindal where the tape goes there should be a small, black B-S button, press it in with a pencil or pin, and it should reset the VCR's computer.
Feb 04, 2009 | Sylvania DV220SL8 DVD Player/VCR
VCR tape won't eject
you should take the bottom off and you will see a gear with a belt around it try to turn it the same direction as when it is turned off, do not force it but it may need a little force to move the wheel.
Mar 17, 2008 | Sony SLV-998HF VHS VCR
Help ejecting dvd
I had the same problem and tried for ages (even tried forcing the door open thinking I could just tape it shut) without luck.
Then my very clever wonderful husband had a go (I know i'm crawling and yes my knees hurt).
Any way to the relevant bit. If you hold the eject button down and at the same time slide a knife or similar object round the edge of the door where the screw is near where it says photo/select you'll find that the door opens as this is an override mechanism.
Feb 22, 2008 | Hitachi DZ-GX3200A DVD Camcorder
Error Message Reconect Power even if power is connected
It sounds like the tape door is out of alignment, causing stress on the tape and the inside mechanical system.  Requires a visit to the service shop.
Jan 28, 2008 | Sony Handycam DCR-HC40 Mini DV Digital...
Eject is flashing with fast beeps. Won't eject tape or open compartment.
sad to say that the problem of your camera is the timing gear is already damage....it need to disassembly the camera to fix the timing gear....go to the qualified service center for fixing or replacing the timing gear..
Jun 15, 2007 | Sony Handycam CCD-TRV37 Camcorder
More info on Aiwa HV-MX100 not powering up
mechanical fault needs profesional technisian just not to make it worse , regards
Apr 30, 2007 | Aiwa HV-MX100 VHS VCR
Panasonic Palmcorder PV-DV52 Mini DV Digital Camcorder Logo
35 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
