Question about Itronix Husky FEX21 Pocket PC
Husky handheld fex21
Will not sync (no signal?),(aircard not connected?) ,no connection cannot ping server everytime i try to sync
Put the thing in the bin best place fot it
Posted on Sep 04, 2008
Have you tried discharging the batteries then reconnecting as a new partnership?
Posted on Jan 17, 2008
I can connect to my own WiFi but it will not connect to the server
Hi Mary,
Your Q. is not clear. I assume your internet is working but you cant connect to the local server on your network right? IF so please try restarting your router and see if it helps. Thanks .
Jan 02, 2018 | The Computers & Internet
Wireless don't work,I can only use internet explorer when ethernet is plugged in.I have good signal from my server box in either way. [ airmax 101
first of all change your wireless settings again.if it`s vista choose WPA,if it`s xp choose WEP.Try the channels from 3,6,9,11(and 13 if it`s available depends on your country).disable MAC security if it`s on. try connecting now.try to use internet.if not then goto start - run - .cmd - enter..type the default gateway,if successful then ping ,if successful then ping ping statistics should say sent = 4,received = 4,lost = 0.if not u need to disable all securities like firewall and antivirus.update adapter`s driver & router`s firmware.provide fixed IP under wireless network connection and DNS server address should be & restart your computer it should work.if it doesn`t then change ur wireless settings again and connect without security.
come back for more advance steps if it doesn`t work.also provide model of router. Thanks..
May 27, 2009 | Acer Computers & Internet
Dns Record not being deleted
Does this server which is deleted from DNS has a static IP? If yes, then you will always be able to ping by IP address. Are you able to ping by name of the server?
Apr 09, 2009 | Microsoft Windows Server Standard 2003 for...
Husky fex21 will not turn on
Hi, disconnect from AC power then remove battery and then re install it - this sometimes works if there are re charging problems. Also try doing a number of soft re starts and try turning on with AC power connected. If all else fails do a hard reset - you will lose any added programs that are on the units memory but not if they are on a CF card.
Good luck
Feb 17, 2009 | Itronix Husky FEX21 Pocket PC
I do not have a router because i live in the country and the only way i could go was a sprint aircard and i wanted to see how i could use that to connect the internet to a ps3
You will need a second Wireless LAN Card or USB Wireless device for the P3, then install all SW for the devices, set BOTH computers to have the same workgroup name (Rt click My Computer, Properties, Computer Name, Change) then reboot both boxes.
Log onto the Aircard box
Goto to Start, Settings, Networks and Settings
Double click Aircard
Click Properties
Click Advanced tab at the top
Click Allow other to share
Click settings
Pick your poison
Add any extra you need
Click OK 2x
Goto start, Run and type cmd
type ipconfig /all
write down settings
Goto P3
goto Start, Settings, Networks and...
Double click the WLan icon
click properties
On the top scrollbar find TCP/IP and highlight it
click properties
change IP to Use this IP and set to same as Aircard +1
Massk is same
Gateway is same
DNS is same. If no DNS make this PC same as Aircard IP
type ipconfig /all
write down settings
Type PING (IP of Aircard to see if P3 can SEE it
if OK, then open Browser and come to this site ;-)
If not OK (Ping timeout)....
go back to Aircard PC
Click Start, Settings, Networks and Settings
Right click Aircard
Click Properties
Click Advanced Settings
write down all these
WLAN protocol: 802.11a,b,c,g....
Encryption type (changge if P3 does not support)
Password (copy to .txt file and save to memstick or floppy)
Go back to P3 and do same
Then click scan for hosts
find your Aircard name
Click connect
copy/paste ot type in Password from Stick or floppy
try open browser again
Jan 17, 2009 | NetGear WGR614 Wireless Router
IPAQ 1950 suddenly will not connect to PC to allow sync
Same problem, on four computers with two iPAQ 1950's. I installed ActiveSync 4.5, and all works fine now. This link will get you to AS 4.5:
This SHOULD work for all PDAs, but I have only used it for the 1950.
Nov 11, 2008 | HP iPAQ rx1950 Pocket PC
Can't send e-mail
Check your network connection. Can you visit web pages? If not, check your network cable, modem, etc.
If your connection is good, try pinging your outgoing mail server.
If the ping fails, phone whoever maintains the server, and ask them when it will be back online.
If the ping is successful, try closing, then opening your mail client. Doublecheck the settings for outgoing server, port, encryption options, username and password.
Sep 17, 2008 | Gateway Computers & Internet
Adapter problem--compact wirel
i have tata internet connection. i inserted two ethernet cards in server system. when i was going to use ping command for internet connection, "DNS server host not reatchable" message coming. ping command working & and also browsing after one of the ethernet card disable.
i want to connect the systems on LAN for internet from server. please suggest for this problem.
Apr 27, 2008 | Computers & Internet
i have had three aircards due to many problems including not being able to install the communication manager program from the aircard to not being able to connect to the att network. well, i got a laptop the other day and figured i was going to have problems with the aircard UNTIL i went to the sierra wireless website and did some investigating!! i think the problems lie with the communication manager rather than the aircard itself. >>>download the 3GWatcher program directly from sierra wireless and use that instead of the communication manager. it offers all the same functions and worked right off the bat....i took my laptop with the aircard out on a golf course in the middle of nowhere to test and everything worked beautifully!!
i, too, spent many hours on the phone with att....very frustrating!
and no reps even suggested that i try the 3GWatcher program...they all blamed the problems on a "bad batch" of aircards.... hmmmmm!!
try it, you'll like it!
Apr 19, 2008 | HP Compaq Presario V2000 Notebook
Connection Issues
can you give more info,
1>can you see the network? (scan)
2>can you connect to the network?
3>do you get a valid IP?
4>can you ping the server?
if you can not connect to the network(2) but see the network(1) via scan the problem is in your wireless profile, delete the profile and resetup, check that the region settings in the profile match that of the unit.
i will need more info about you network, ie wep/wpa? ch? authentication type? and so on
Oct 19, 2006 | Symbol MC9063-K (mc9063kkehbeea4ww)...
Itronix Husky FEX21 Pocket PC Logo
130 people viewed this question
Top Itronix Computers & Internet Experts
Steven Wander
Steven Wander
Larry Chandler
Are you an Itronix Computer and Internet Expert? Answer questions, earn points and help others
