Question about HP Color LaserJet 2600n Printer
Blue and Yellow Streaks
My office uses the HP 2600n. We have a high volume of color printing we need to do and after about 100 pages we will get two or three blue lines (about 1/2 - 1in thick). We have our cartridges filled at Cartridge World and don't know if it is the cartridge we are using or if it is just a crappy printer. The more and more I search for a solution online, I find others have the exact same issue...when you open the front of the printer, the film on the cover is drenched in blue and yellow ink. Anyone have an idea as to how to clean it? I'm sick of spending money to have it cleaned every time something goes wrong.
  • 52 Answers
When doing the refill, they may not have emptied the waste bin and may be overflowing. You can shake the cartridge horizontally and gently to evenly distribute the waste in the waste bin.
Posted on May 20, 2009
Streaks or lines
Vertical streaks:
Check,which color/s streaks are appearing on print out,remove that cartridge/s check on drum surface for streaks.. if found replace that cartridge/s..check.
Horizontal streaks:
This problem appears when the cartridge/s image drum not rotating properly. Resit the cartridges properly, print 20nos of blank pages, then check.... replace the cartridge..
Dec 29, 2012 | HP Color LaserJet 2600n Printer
HP Color Laserjet 9500hdn printing yellow streaks at bottom of page
I'm not familiar with this model but have you ran the cleaning mode if it has one?
Aug 23, 2012 | HP Color LaserJet 9500HDN Printer
The logo in my print job is color Green but its coming out in color blue. what is the problem
Check the yellow toner cartridge, printing a configuration page.
Configuration page
The Configuration page lists the current settings and properties of the printer. You can print a
Configuration page from the printer or HP Toolbox. To print the Configuration page from the printer,
complete the following steps.
1 Press the (LEFT ARROW) or the (RIGHT ARROW) buttons to select the Reports menu.
2 Press the button (SELECT).
3 Press the (LEFT ARROW) or the (RIGHT ARROW) buttons to select Config report.
4 Press the button (SELECT) to print the Configuration page.
Yellow print OK?
No? try print with another yellow toner cartridge (Q6002A).
Aug 10, 2011 | HP Color LaserJet 2600n Printer
Why do I get color streaks of blue and magenta on every page when I print?
One of yr toner is defective. to cross check pls change one by one tonner.
Feb 16, 2011 | HP Color LaserJet 2600n Printer
Will not print blue? HP 2600
SPACILLY FOR HP PRINTERS DONT USE THE REFIL CART
this problem due to refill cart replace with new one ur problem will be resolved
Jul 01, 2010 | HP Color LaserJet 2600n Printer
Ink "banding" on hp laserjet 2600n
Viscosity of the ink is likely your problem. Sure the inks are not leaking at the same time, but that is likely because the different colors use different tints which can be slightly thicker or thinner. Many printer manufacturers (HP most notably) makes many patents on their ink, and not solely on the colors, but also the viscosity. The ink jets could slowly be leaking and might need to be replaced, finding these parts yourself might be easy, but replacing them is not.
I'm going to assume you've replaced the blue and suggest you remove the roller and clean it with glass cleaner. You may find it EXTREMELY difficult to remove the roller, so I would probably find a printer repair/ sales shop. Usually these places are not easy to find, so you'll probably want to find an office equipment sales business. These are the companies that usually sell the larger copier/fax/printers for large offices, or you could call HP and ask where a certified HP printer technician is in your area. I will tell you though, the cheaper ink may have just caught up to, having a copier technician repair this printer could cost quite a lot, but doing the job yourself, could be disastrous. The amount of small screws, easy to break plastic tabs, and interesting clips, etc make the job nearly impossible for a novice.
Good luck -Skyler
Mar 19, 2009 | HP Color LaserJet 2600n Printer
A very thin light blue line appears on all printing jobs
Have you tried running some printer cleaning sheets through it? They are available through Office Depot, Fry's and other stores.
Also, it could be an issue with the imaging drum. I've worked on several printers which have had a similar issue and they needed the imaging drum replaced. Typically that helped.
Dec 09, 2008 | HP Color LaserJet 2600n Printer
Every page covered in magenta and black won't print across the page
This is caused by toner contamination in the laser scanner unit, it is quite a complex job removing and cleaning the laser scanner. I would suggest you contact HP regarding the repair.
Sep 04, 2008 | HP Color LaserJet 2600n Printer
Red and Yellow colors are playing up
It's normally caused by dirty scanner mirrors, the machine will need to be dissembled, the laser scanner unit removed, taken apart and the mirrors cleaned. Unfortunately it is quite fiddly getting the scanner unit out, but this is a very common problem for the HP colour laserjet 2600's
If you want the service manual it can be downloaded from the following link free of charge http://www.eserviceinfo.com/equipment_mfg/HP_22.html
Sep 01, 2008 | HP Color LaserJet 2600n Printer
HP LaserJet 2600n
It sounds like it, but before you replace it you might want to troubleshoot this through the HP Toolbox (the software would have come with the printer) if you haven't got it, download it from www.hp.com (it's straight forward and easy to use)
Jun 12, 2008 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n Printer Logo
332 people viewed this question
Seeker5211
Seeker5211
