Question about Watts Onan Portable Generator - 5000 , Model# 6500
Location onan quiet diesel fuse f3 - Watts Onan Portable Generator - 5000 , Model# 6500
Why doesn't it click or start?
quite possibly you ruined a lot more than a fuse .
Dec 11, 2015 | Onan Cummins Quiet Diesel RV Generator -...
Where is the fuse on the onan 5500 built in generator?
Try under the bench seats around the table, near the heater.
Jul 14, 2014 | Onan Marquis Gold Quiet Gas Generator 5500...
Looking for fuel filter for Onan HDKAK=1046 rv generator. Anyone have the product number
You didn't indicate a Spec number for your gen that would be required. Any RV place can get this part it is Cummins part # 149-2513 but a Spec number would help.
Oct 09, 2013 | Onan Cummins 8.0 HDKAK/1046 RV QD 8000...
How to field flash the onan 8hokak-1046k
Did you get this fixed? this is an old post. If not visit www,advanced-power-technologies.com (Cert Cummins Dealers) They can answer your questions.
Oct 03, 2013 | Onan Cummins 8.0 HDKAK/1046 RV QD 8000...
Onan quiet diesel 6000 won't crank clicks
Check battery voltage, starter solenoid, then starter motor
Mar 31, 2013 | Onan Cummins 12.5 HDKCB/11506 RV QD 12500...
I have an 8.5 onan diesel generator that idles fine but surges badly when the air conditioner is started - the motor races out of control - what could be wrong?
Is it only when a load is on the unit? I am assuming the voltage output os correct and the HVAC is working properly on shore power and does not have a locked compressor. If it does there is too much demand on the generator and it cannot govern, if the HVAC and ouplut voltages are all good, make sure you have the right weight oil and level in. It sounds like a governor issue, or the engine is mechanically not provifing enough HP. More than likely a governor issue
Aug 29, 2012 | Onan Cummins 8.0 HDKAK/1046 RV QD 8000...
Watts Onan Portable Generator - 5000 , Model# 6500 Logo
Top Watts Electrical Supplies Experts
Jim London
Jim London
Ottoniel
Joseph Hoffmann
Are you a Watts Electrical Supply Expert? Answer questions, earn points and help others
