84 Replace photoconductor?
We have a RICOH-IBM printer, and with message states 84 replace photoconductor. Not sure how to replace or find it?
  • pcslayer2 May 20, 2009
    Thank you, for your help!
  • 469 Answers
The photoconductor is the drum unit, usually a kit you would purchase from your product supplier, the box should contain the instructions on what steps need to be taken to complete the operation.
Hope this is of some help.
Ed
Posted on May 20, 2009
Hola tengo una lexmark x340 presenta erro 84 remplazar fotoconductor
84 Replace Photoconductor
This message displays when the photoconductor is at the end of life.
The photoconductor must be replaced.
Jul 22, 2011 | Lexmark X342n All-In-One Laser Printer
Replace pc unit problem on Lexmark W840 Laser Printer
Here is an excerpt I found from the W840 user manual. Looks like you need to change the photoconductor kit. Here is the link for the user manual: images.lexmark.com/publications/pdfs/w840/eng/ug.pdf
To ensure print quality and to avoid damage to the printer, the printer stops operating after the photoconductor kit has reached approximately 60,000 pages (Letter/A4). The message 84 Replace PC Unit is displayed when the printer reaches this point. If the Toner Alarm setting is set to Single or Continuous (default is Off), the printer automatically notifies you before the photoconductor reaches this point and displays the message 84 PC Unit Life Warning. To avoid having the printer stop operating, replace the photoconductor kit when you first receive the 84 PC Unit Life Warning message. Once the photoconductor kit has been replaced, normal printer operation resumes
Apr 11, 2011 | Lexmark W840 Laser Printer
We are receiving the error message "84 oc life exhausted". What can we do to solve?
84 PC Life Exhausted indicates that the photoconductor unit has reached its functional life. The photoconductor kit will need to be replaced. The printer will not function so long as the Exhausted message remains on the display. The only way to clear the message is to install a new photoconductor. After replacing the photoconductor unit, you need to manually reset the pc page counter as well. Thank you for choosing Lexmark.
Sep 01, 2010 | Lexmark Optra SC 1275 Laser Printer
WHAT IS 84 Replace Photoconductor
The 84 Replace photoconductor message means that the photoconductor has reached the expected life spam. It will be time now to replace it.
Jan 30, 2010 | Lexmark X342n All-In-One Laser Printer
What shoud I do when error 84 replace
Photoconductor is the part of the printer where the image gets created this is a very delicate and important part in the Laser printing process. If you open the printer and remove the toner, you should see it sometimes is like a green or blue color. The message 84 is just telling you that the photoconductor has reached the end of life and needs to be replace. Here is also a link on how to do the replacement http://bit.ly/bn2HFc
We have message to Replace Photocondutor. Is that toner? If not, s it self-install or do we call for Tech?
Most photoconductor assemblies are what they call "CRUs". That means that they are Customer Replaceable Units.
Check with the Ricoh web site "Support" to verify the installation process and order the part.
Don
Nov 19, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Code 84 Replace Photoconductor
put back your old drum and let me know what gos on thanks
Nov 18, 2009 | Lexmark E352dn Laser Printer
Replace photoconducter 84 on lexmark e350d
Go to www.lexmark.com Select the correct country. then Selectg "Technial Support" Enter the model of your printer "E350D" Click on search. Under the "Knowledge base" header place this number into the search bar: "ENUS27198" click on search. ************************* Lexmark E350d Country / Region: United States Language: English Need to download a driver? How to Reset the Photoconductor Page Count on a Lexmark E350d or 352dn Printer ID: ENUS27198 Procedure Follow the steps in the table below to reset the photoconductor (PC) page count. NOTE: The directions in this article are in English. To download a PDF file containing these instructions in several other languages, click here (file size: 782 KB). Step Action 1 Enter the printer's Configuration menu: Power off the printer. On the printer's operator panel, press and hold the select button () and the back button (). Power the printer back on while keeping both these buttons held down. When you see the messages Performing Self Test or Busy on the printer screen, you can release both buttons. If the printer has successfully entered configuration mode, you will see a new menu with the heading CONFIG MENU at the top of the screen. 2 Press the right arrow button () until you see Reset PC Cnt. Press once. You will see Reset. Press again. The printer will display a Resetting PC Count Value message and go back to the previous screen. 3 Press once. 4 Press or on the operator panel until you see Exit Config Menu. Press once. Selecting this will cause the printer to reboot. If the counter has been reset correctly, the printer should return to a Ready prompt. 5 If this does not clear the PC Life Warning or Replace Photoconductor message, power off the printer and attempt this entire procedure again. If the error remains after two attempts, confirm that: The correct photoconductor unit is installed. The part number on the photoconductor unit should be E250X22G. If it is not, install the correct photoconductor unit into the printer. The photoconductor unit has not been refurbished by a third party or is not damaged in any way. If the photoconductor unit was refurbished by a third party or appears to be damaged, try replacing it again before seeking service on the printer. If the error persists, the printer may require service to correct the issue. Contact Lexmark Technical Support for more information. Don
Jun 03, 2009 | Lexmark E350d Laser Printer
Error Message: Replace Black PCU
I'm not sure how to obtain one, but "Black PCU" stands for Black Photoconductor Unit, and according to a manual for a different Ricoh printer model, it should be fairly simple to replace if you can find one.
Nov 10, 2006 | Ricoh Aficio CL2000 Laser Printer
894 people viewed this question
k24674
jasbo
jasbo
