Question about Motorola Mobility HX550 Bluetooth Headset
It has to pair every time I turn it on
Everytime I turn bluetooth on I have to pair it
How to pair it with galaxy tab 4
This is for the 1900, but should be the same. Go to Bluetooth settings on your Galaxy.
Samsung HM 1900 User Manual
Aha, I found this for the 1500
4 Enter the Bluetooth PIN (0000, 4 zeros) to pair and connect the headset to your phone. Your headset supports the Simple Pairing feature which allows the headset to be paired with a phone without requesting a PIN. This feature is available for phones that are compliant with Bluetooth version 2. The headset also can be paired via the Active pairing feature, see page 14. Connecting with two Bluetooth phones
With the Multi-point feature activated, your headset can be connected with two Bluetooth phones at the same time. 1 After connecting with the first Bluetooth phone, press and hold the Talk button until the blue indicator light stays lit. 2 Press and hold the Volume up button to activate the Multi-point feature. 3 Activate the Bluetooth feature on the second Bluetooth phone and search for the headset (see your phone???s user manual). 12
4 Select the headset (HM1500) from the list of devices found by the second Bluetooth phone. 5 Enter the Bluetooth PIN (0000, 4 zeros) to connect the headset to the phone. ??¢??¢ You can set the headset automatically to reconnect to the recently connected phones each time you turn it on. -- To reconnect to the two most recently connected phones, activate the Multi-point feature. Press and hold the Volume up button in Pairing mode until the blue indicator light flashes twice. -- To reconnect to only the most recently connected phone, deactivate the Multi-point feature. Press and hold the Volume down button in Pairing mode until the red indicator light flashes twice. ??¢??¢ When the headset connects to two Bluetooth phones, some phones may not connect to the headset as the second Bluetooth phone. English
Disconnecting the headset
To disconnect the headset from your phone, ??¢??¢ Turn off the headset. 13
Reconnecting the headset
When the headset is paired with a phone, it will attempt to automatically reconnect each time you turn it on. If the headset does not automatically attempt to reconnect, ??¢??¢ Press the Talk button. Pairing via the Active pairing feature
With the Active pairing feature, your headset can automatically search for a Bluetooth phone and try to make a connection with it. 14
3 Press and hold the Talk button until the violet indicator light turns on. The headset will switch to Active Pairing mode, search a Bluetooth phone within range, and attempt to pair with it. [. . . ] ??¢??¢ To switch between the current call and the held call, press and hold the Talk button. 19
http://lastmanuals.com/manual/SAMSUNG/AURICULAR-MONO-BLUETOOTH-HM1500
Oct 30, 2015 | Samsung HM1500 Bluetooth Headset
Cant pair my iPhone with jabra sp5050
forget the headset
turn bluetooth off
turn the headset device off
reboot phone.
try again
Mar 04, 2014 | Jabra A320s Bluetooth Wireless Adapter
My motorola h700 wont pair to my htc hero.when i hold the button down on the bluetooth, it lights up blue for 5 seconds then the light goes out
go into settings, look for wireless controls or bluetooth, should ask you to pair with the name of your bluetooth if it wont, turn off the bluetooth in the phone and turn off the bluetooth itself by holding down the button for about 6 secs till the light blinks a few times then goes out. turn the bluetooth function on on the phone FIRST, wait till it says its on, then turn on the bluetooth itself by holding the button down until the light blinks a few times then you get a solid light, it wont stay solid, it will blink a few times then go out blinking from time to time. go back to your phone and find the bluetooth menu and it should ask you if you want to pair, hit yes or whatever option you have and it should start pairing and then connect or you may have to hit the connect option if you have one they dont all connect automatically sometimes so you have to go through all this when you charge the bluetooth or turn it off. good luck.
Dec 14, 2010 | Cell Phones
Difficulty pairing bluetooth to lg rumor phone
I had this problem with my LG Shine. I took the battery out, put it back in, and turned it back on. It worked!
Sep 05, 2009 | LG RUMOR Cellular Phone
Switching on discovery 925
Switch the bluetooth function on your phone, search for devices and then pair with your headset once it finds it. Allow it to connect without confirmation and leave your bluetooth switched on on your phone. Everytime you turn on your headset it should connect automatically.
Apr 10, 2009 | Plantronics Discovery 925 Bluetooth...
Can't pair bluetooth
....My madcatz bluetooth will not charge everytime i plug it in the ps3 the red light comes on then it goes off and it keeps on doing it and its a brand new bluetooth...i hold it for a long time and it still wont work..HELP PLEASE!!!!!!1
Feb 06, 2009 | Mad Catz PS3 Bluetooth® Headset Wireless...
Old phone would pair with Clarion VRX785BT's bluetooth
you auto connect is turning off on the screen. try keeping ur phone permantley visable.
Jan 10, 2009 | Clarion VRX785BT Car DVD Player
Samsung phone finds Bluetooth but pairing always fails
dear,
first of all delete the searched blue tooth devices in the list and then try it again,
ask further if required,  before rating
regards,
Nov 30, 2008 | Cell Phones
Getting it to work
Pairing This was the second Bluetooth device I?ve used, and I had the headset paired in under 60 seconds once I had deciphered the instructions in the manual. When you press the call control and multifunction control buttons on the headset simultaneously, the M2500 goes into pairing mode. The standard way to get the Treo to pair is to click on the Bluetooth icon and basically follow the prompts: Turn Bluetooth on, make the device ?discoverable,? click on ?set up devices? and then ?Handsfree setup,? and the Treo will find the Plantronics headset. Once you?ve set up one Bluetooth device, you?re a pro. The only thing you need to know is the combination of buttons that puts a device into pairing mode. However, with the Plantronics M2500, I discovered an even easier method. Simply power up the Bluetooth headset while the Treo is on and you will be immediately prompted for the passcode, four zeros, if the devices are not paired. How cool is that? It saves many steps.
Mar 12, 2007 | Plantronics M2500 Consumer Headset
Motorola Mobility HX550 Bluetooth Headset Logo
23 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
