Question about Home
Not filling with water
After flushing the water is not running into the waterback or into the reserve
3 Suggested Answers
sandie3796
  • 132 Answers
SOURCE: after flushing, water fills up tank and continues
Your problem is the water fill valve. Check this link.http://www.rd.com/17646/article17646.html
it's not the flapper or flush valve.
Posted on Mar 05, 2010
  • 349 Answers
SOURCE: tank will not fill up after flush. i hear water
Fill valve in tank has a washer in it you take it off and make sure there is no trash restrcting flow and also chack out flaper to see if it is sealing correctly.
Posted on May 03, 2010
HOW TO FLUSH AND RENEW COOLANT?
if the thermostat is in the head at the top radiator hose , remove it an fill the cooling system until the water is at that point --refit the thermostat and continue filling
make sure that the heater is turned on so that any air is moved out of the system
May 30, 2016 | Cars & Trucks
How do I do a proper coolant flush and clean on a 05 Pontiac Montana SV6?
Drain radiator, remove thermostat reconnect housing, fill radiator halfway with water add radiator flush it's by Preston fill up with water start engine run for 20 minutes , drain radiator replace thermostat fill radiator with 50/50 mixture of antifreeze and water run engine and top off radiator as needed
Sep 30, 2015 | Pontiac Cars & Trucks
Have a 2011 polaris 6x6 800 that overheats every time I use it. The coolant will come out the over flow.
The most common causes of a water cooled engine overheating are (1) poor circulation of cooling fluid (bad water pump or stopped up radiator); or (2) inadequate air flow cooling (bad cooling fan); or (3) compression gases entering the cooling system (leaking head gasket or cracked block or head). The first check is to see if air is in the cooling fluid (small bubbles appearing in top of radiator or coolant reserve tank). If so, then #3 is the problem. The second check is to see if the cooling fan (s) is running properly (can feel air flow on output side?). If not check wiring and/or replace fan (#2). The last step is to drain the radiator and engine (turn over engine to allow water pump to empty the block). If additional cooling fluid does not drain out the radiator drain port, the water pump is defective. If the water pump does empty the block, then flush the system with a good flushing agent. Follow instructions on flushing agent bottle. Drain out the flushing agent and re-fill radiator and block with clear water. Run engine as per instructions on flush agent bottle. Drain system again and re-fill with antifreeze (50%) and water (50%). If vehicle is located in a very cold climate, then increase the antifreeze % up to 75% (25% water). Remember, not only does antifreeze help to keep water from freezing, but it also helps to increase cooling ability.
Feb 06, 2015 | Polaris 2011 Ranger 800 6x6
Water reserve bottle is emptying and engine is getting how
flushing a radiator is a waste of time and money as blocked cores do not flush. Have a pressure test done on the coolant system and check for external leaks. have a compression test done to check for head gasket and cracked head. Have a flow test done on the radiator and if shows signs of blockage replace the radiator .. Always fill the radiator at the radiator cap and not the reserve bottle. The reserve bottle water will not go down until the engine coolant starts to cool so if it is going down when the engine is hot then you have a bad leak in the reservoir bottle.
Jan 07, 2014 | 2000 Oldsmobile Intrigue
Jacuzzi toilet
After flush the system must close the hole which lets water into the toilet. If it does not close after flush, it is continuously letting the water thru. Check if it closes after flush and allows tank to fill.
Jul 10, 2013 | Home
2000 Lincoln Town Car. The A/C unit is erratic. When I increase speed, the a/c blower increases. To get any heat I have to put the temperature to 90 degrees. Any advice?
The heater core and radiator require flushing every 2 years / 24,000 miles.
The coolant cap on the reserve tank need to be pressure tested.
Please do the flush with water and it it circle for 1 day then re-flush again
Fill with 50/50 coolant mix.
Jan 31, 2011 | 2000 Lincoln Town Car
Hi, I have a F & P top load washer (model GW701-U) over 10 years old. I use cold water washing. The water fills up very very slowly- just dribbles. After about 7 minutes of the water filling up, the...
Turn off the water to the washer, unscrew the hoses ( do one completely before moving to the other)Once you unscrew the first hose you will see a small filter screen inside the opening on the washer,Remove the screen and clean it, replace it and reattach the hose,Now go to the other hose and do the same thing, once both are done and hooked back up, turn the waterback on and everything should work as normal.
Dec 02, 2010 | Fisher and Paykel Washing Machines
My engine cooling module or radiator assembly will not hold its fluid. It is back filling into my reserver tank. The fluid makes my reserver tank fluid boil. The gages says that the car is not...
Your radiator might be air bound or clogged. When the car gets up to temperature and the thermostat opens shut the car off and try to feel all the corners of the rad. if its cool in any spot you might need a flush or new radiator. (When thermostat opens let car run for about 5 min before shutting down) Hope this helps
Sep 13, 2010 | 2006 Chevrolet Impala
My wtaer reserve tank dries up easy
fill the rad cold and the reserve tank to the cold mark, i suspect the reserve tank is leaking
May 08, 2010 | 2004 Toyota RAV4
After flushing, water fills up tank and continues
Mar 05, 2010 | Home
Home Logo
49 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
