Cannot install printer cannot do a disk check cannot install updates
On a pc what does "cannot load installer for disk drive" mean
  • 822 Answers
Install your driver manually. during installation ensure that power cord is connected and data cable to your pc. after installation reboot your pc.
Posted on May 20, 2009
Hp designjet t1100 blank hard drive installation
Unfortunately I had a similar issue with an HP A0 printer. The Hp 'Engineer' could not fix it. The hard drive had failed and there is a complete new hard drive with software loaded available but only through Hp.
Feb 27, 2014 | HP Designjet T1100ps Printer
My laptop will not boot blue screen message *** STOP:0X0000007B(0XF78D2524, 0XC0000034,0X0000000,0X00000000) Do's this blue screen message mean any thing to any one!
Dear, I am not good blue screen code reader. But I guess (from my experience) this can happen in case of defected ram, hard disk or trying to install operating system which is not supported by the motherboard or laptop.
You can try to load changing ram for testing purpose with a good RAM if does not work, try to Remove and install a good hard disk then go for the loading. I think by loading you mean start up your laptop booting form your hard drive. If so, just try to re install your operating system. Let me know updates.
Jun 25, 2012 | Toshiba Satellite P35-S611 Notebook
How do you re-boot the latitude D400 laptop
by rebooting you must mean wiping out and starting fresh? installing a new operating system. you need either the dell factory recovery disks and start the computer up on the disks. with disks inserted follow to the load from cd promptg if not start over and when the computer turns on tap del key and change boot order settings to prompt boot from a cd dvd drive before a hard drive or any device. this way it will check for operating systems in the cd before the hard drive. then continue installing your choice of factory or updated operating system enter the serial number etc etc as it prompts. it should take about one to two hours beginning to end.
Feb 06, 2011 | Dell Latitude D400 Notebook
I installed Ubuntu together with Windows XP but in the process I lost the ability to see (in none of the OS) the USB drives, how can I recover them?
In Ubuntu, go to Administrator/Hardware Driver Update. It will run an update to check drivers available against your hardware. BTW new version of Ubuntu available at the end of the week. Ubuntu Upgrade If that's unsuccessful, run a normal Ubunto Update to do a driver/support search. In XP, boot up,, insert your install disk and right-click on My Computer/Properties/Device Manager. There is an option at the top to "Scan for Hardware Changes". It should recognize the USB hardware. When it asks where to get the drivers, point it to your installation disk which should have all of your USB drivers on it.
Best of luck and enjoy Ubuntu!
Greg
Oct 27, 2009 | IBM NetVista PC Desktop
LightScribe DVD SuperMulti Drive/CD-Writer won't read disks. It has been cleaned and passes all tests. Has read these disks before, but file will not load from disk.
check and see if there are updated drivers and install them. have you changed your Operating System via upgrade or anything.
May 26, 2009 | HP PAVILION A6230N DESKTOP PC
New hard drive operating system loaded, now cant find hard drive
check the cables it properly connected or not. after start up press F8 key to check the installed hard drive is detected or not. if it is not, check with BIOS settings
Thanks Good Luck
Appreciate to rate as "Fixya"
May 09, 2009 | HP Pavilion ze2000 Notebook
Dvd-rw drive malfunctioning
Please Check :-
1) Whether U R using the Proper NERO. I want to mean, try installing the NERO which was provided with the DVD-RW+ Drive.
2) Check whether there is a Firmware Upgrade available for your DVD-RW+ Drive with the help of provided CD/DVD and a compatible Software.
Jul 27, 2008 | Lite On (SHW-1635S) DVD RW Dual Layer...
FACTORY TV CARD PROGRAM AND DRIVERS WON'T LOAD
sir try copying all the files in the installation disk to your hard drive then run the installation in where you copy your file... probably just a read disk error... if you have successfully copied all the files means disk is still working... if you get an error chances are the installation disk is damaged or your disk drive have a problem.
Jan 20, 2008 | NEC VALUESTAR T (VT900/8D) PC Desktop
Erorr in installing the printer
Need more info, sounds like nothing to do with a printer, sounds like you ae trying to install something on your pc and it needs the .exe file placed where it can find it on your computer hard drive that is labeled "DR9".
Nov 03, 2007 | Printronix P7005 Matrix Printer
Slow Speed and Hard Disk LED "Stuck" on...
This has happened to me a few times and it's been posted here by others, and the one thing that is always apparent is it happens after a windows update, this may well be a generic updated driver which is not always the best driver for what you have installed or it could be a programme that has not installed correctly especially windows genuine advantage. I would do a system restore to a point before the windows updates, then go to Microsoft updates yourself and manually install the updates that windows says you require one at at time until the same thing happens, although it may not as it may be the fact that there are too many updates trying to be processed at the same time causing the lag and permanant HD led light.
Oct 02, 2007 | Acer Aspire 1352LC PC Notebook
Computers & Internet Logo
David Payne
David Payne
