Question about Samsung DV520AGP Dryer
Dryer will not start
When start button is pressed dryer will not start (turn/cycle). A single clicking sound is heard after one second and then another after three seconds. Almost seems as if igniter is not able to light. Power and gas flow have been confirmed. Vents and lint tray are free of build-up.
57 varieties
  • 1653 Answers
SOURCE: Samsung dryer DV448AEP/XAA - lint buildup
Yes this is rellatively normal as clothes are just not made the same way any more. You could turn down the drying temperature slightly and put in an anti static drying sheet but it won't make that much difference.
Posted on Oct 13, 2009
Testimonial: "I just had a repairman out because the dryer was no longer heating. The whole inside of the dryer was full of lint. It was awful. "
heatman101
  • 43501 Answers
SOURCE: The dryer is not heating up during drying cycle.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 04, 2010
heatman101
  • 43501 Answers
SOURCE: When I push the start
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Posted on Jan 24, 2011
heatman101
  • 43501 Answers
SOURCE: Good Afternoon Modle DV219AG Gas Dryer: The
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Mar 21, 2011
Macmarkus
  • 2605 Answers
SOURCE: Put full load of wet in, had set for heavy dry,
Hello Scott,
Welcome to FixYa.
Based on your description and my experience, I'd say possibly the belt has come off,( hence the big "thud" ) thus activating the "kill switch".
I've seen this many, many times...though the belt usually doesn't break it just comes off. Very common for Samsung dryers for whatever reason.
**Unplug the unit before proceeding...safety first**...
The good news is if you can get to it from the back you can simply remove the small panel around the exhaust tube as shown here,
if it's not accessible from back you'll need to go from the front...that's do-able too, just a little more involved. Let me know.
Once in the back the belt should look like this when routed properly, with the "V" grooves towards the drum and motor pulley.
i.e.
Hope that moves you forward...or even better, fixed up.
Let me know what you find. If this is something you think is not within' your scope of expertise please call a pro.
I will try to help in any manner I can of course as well. Good luck.
Regards,
Macmarkus :)
Posted on Apr 03, 2011
Maytag dryer epicz says "controls
controls locked
This feature allows you to lock your settings to prevent
unintended use of the dryer. You can also use the Control Locked
feature to prevent unintended cycle or option changes during
dryer operation.
To enable the Control Locked feature:
Press and hold AUTO DRY LEVEL for 3 seconds. Control Locked
glows and a single beep tone is heard. To unlock, press and hold
AUTO DRY LEVEL for 3 seconds. The indicator light turns off.
Jul 15, 2011 | Kenmore Elite HE4 Electric Dryer
My kenmore 417 94082500 dryer keeps pausing and shutting off with no errors between 5 and 10 min from starting.
Rotate the cycle selector knob three clicks clockwise (3 o'clock position) from the Normal cycle option then press and hold the Select and Pause Cancel buttons simultaneously for six seconds.Immediately after, press and hold the START and Pause Cancel buttons simultaneously for 4 seconds. Rotate the cycle selector knob one click counterclockwise (2 o'clock position) and the error code will appear in the digital display as an "E" followed by two numbers, a number and a letter or two letters. Post back the error code for further advice.
Feb 23, 2011 | Dryers
Dryer is on LOCK CONTROL how do Iget it off?
The model number did not cross but here is what the manuals say for a Duet dryer:
CONTROL LOCKED
prevent unintended use of the dryer. You can
also use this feature to prevent unintended
cycle changes during dryer operation.
Press and hold the End Of Cycle Signal button
for 3 seconds. The control is locked when a
single beep is heard and the Control Locked
status light is on.
• When the dryer is off, it is not necessary to
press the Control On button before activating
the Control Locked feature.
To unlock the Control Locked feature:
for 3 seconds to turn this feature off.
NOTE: When the dryer is running and Control
Locked is on, the dryer can be stopped by
pressing the Pause/Cancel button, but cannot
be restarted until the control is unlocked
Let me know if this does not work.
Kelly
Jan 22, 2011 | Whirlpool Washing Machines
Control lock on
To enable the Control Locked feature when dryer is
running:
Press and hold the CYCLE END SIGNAL button for 3 seconds.
The control is locked when a single beep is heard and the Control
Locked status light is on.
 When the dryer is off, it is not necessary to press the Control
On button before activating the Control Locked feature.
To unlock:
Press and hold the CYCLE END SIGNAL button for 3 seconds to
NOTE: When the dryer is running and Control Locked is on, the
dryer can be stopped by pressing the Off button, but can’t be
restarted until the control is unlocked.
Jun 01, 2010 | KitchenAid KGHS01P Gas Dryer
How do you turn off the control locked key?
running:
Press and hold the END OF CYCLE SIGNAL button for
3 seconds. The control is locked when a single beep is heard and
the Control Locked status light is on.
To unlock:
Press and hold the END OF CYCLE SIGNAL button for 3 seconds
dryer can be stopped by pressing the Pause/Cancel button, but
can’t be restarted until the control is unlocked.
May 29, 2010 | Whirlpool GEW9250 Electric Dryer
Control locked light is on
dryer operation.
running:
To unlock:
Here is a manual.
Apr 10, 2010 | Whirlpool GEW9200L Electric Dryer
Machine is stuck in control lock
This feature allows you to lock your settings to prevent unintended use of the dryer.You can also use the Control Locked feature to prevent unintended cycle or option changes during dryer operation.
To enable the Control Locked feature when dryer is running:
Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Locked status light is on.When the dryer is off,it is not necessary
to press the Control On button before activating the Control Locked
feature.
To unlock:
Press and hold the END OF CYCLE SIGNAL button for 3 seconds to turn this feature off.
NOTE:
When the dryer is running and Control Locked is on, the dryer can be
stopped by pressing the Pause/Cancel button,but can't be restarted
Apr 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Control lock button of dryer came on and now it doesn't work
To enable the control lock feature: Press and hold END OF CYCLE SIGNAL button for 3 seconds. The Lock/Unlock Control icon lights up, and a single beep tone is heard. To unlock, press and hold END OF CYCLE SIGNAL button for 3 seconds. The indicator light turns off.
Jul 15, 2009 | Dryers
Dryer says controled lock
Hold the Press and hold the CYCLE SIGNAL button for 3 seconds. The
CONTROLS LOCKED icon lights up, and a single beep tone is
heard. To unlock, press and hold the CYCLE SIGNAL button for
Jul 11, 2009 | Dryers
Controls locked status light stays on and dryer cannot be used
Samsung DV520AGP Dryer Logo
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
