Question about Garden
Toro ccr powerliteE 3hp runs but only half speed
Snowthrower was running when it dropped to half speed still runs but not wide open so does not throw snow very far
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 90 Answers
Need to take the bowl off carb and take water out of it nine did the same thing
Posted on May 05, 2014
SOURCE: craftsman snowthrower will not throw snow
I have the same machine and it sounds like the belt is indeed slipping.  If the belt is not worn or stretched too badly, you can perform a small adjustment on the idler-wheel (the thing that controls belt tension) by sliding back the plastic cover on the spring that is attached to the bottom of the lever-cable and tightening the nut so that there is less slack in the cable.  If the nut is all already all the up, then you need to replace the belt, which can be easily accessed by removing the plastic cover in front of the motor under where the spare shear pin compartment is located.  There are two bolts (one on each side) that need to be removed and then the cover just pulls off.  This will expose both belts.  The front one is for the auger drive and the rear one is for the wheel drive.  The belt can be easily replaced without any further dis-assembly by simply removing and replacing it in the reverse manner.  Don't forget to readjust the spring so that excessive tension is not applied to the new belt.  Hope this helps.
Posted on Jan 20, 2009
  • 2926 Answers
SOURCE: Toro S200 doesn't blow to the side as far as it did
It's possible your auger may be worn, and it is not moving / propelling enough snow to make up the difference to blow the snow at the angled setting. It may throw the snow forward better due to less resistance, rather than the snow having to propel around an angle / curve. Just a thought for now.
Posted on Jan 20, 2010
Testimonial: "Thanks,that makes sense. It seems the paddles are not that worn but maybe the margin of error on wear and performance is small. "
steve_e_uk
  • 1675 Answers
SOURCE: Model 42 snowthrower throws more belts than snow.
what might be happening is that somthing is seezing as you are using it, a smoking belt meens that either the motor has seezed at some point and has burnt the belt, this in turn has made the belt thinner so will slipp allot, but i think the main problem is a bearing is seezing when it gets hot, thats possibly why it last a while then runs the belt, move the pullies in and out up and down to see if there is movement in them if there is they will need replacing, also feel if they are smooth when turned by hand, listen to them and see if you can hear a bit of graunching this is also a give away that the bearings are u/s...hope that helped
Posted on Feb 10, 2010
#1 Taper
  • 1041 Answers
SOURCE: I am looking for the
I think if you write the company and tell them your problem they will send you one. I wasn't able to find it either.
Good Luck,
Jim
http://www.toro.com/intl/ca_en/home/snowthrowers/gassinglestage/ccr325.html
Posted on Sep 10, 2010
  • 173 Answers
SOURCE: 5 hp tecumseh snow king engine on a murray
Turn it in all the way gently until it stops then turn out 11/4 turns out.Then tou can fine tune from there.
Posted on Dec 15, 2010
Other problems know with the toro 1000c 3hp snow blower model 38195
My blower runs fine and has no problem all I do is keep it nice and clean after use and oil the running parts after the season when I dont use it I am very happy with it.
Jan 09, 2015 | Toro Ccr Snowblower
Why it runs half speed wide open?
propeller could be slipping. It is sometimes held tight by a rubber washer that wears out.
May 23, 2014 | Minn Kota Maxxum 70 Freshwater Bow Mount...
I have a toro snow blower that wont throw snow
then you need to see if the belt is still in one piece... then inspect what else would cause this issue
Oct 10, 2013 | Toro Snow Blower Ccr 1000 Belt 715381...
My snowblower does not seem to run at full speed. Barely throws snow recently. Any adjustments I can make?
There is a spring attached to the throttle linkage. At the other end is an arm that the spring attaches to. Bend the arm so that the spring is tighter and it will throttle up higher under a load. Don't go too far or you will take a chance of blowing the engine. Best to use a rpm tester and set it to factory specs.
Feb 22, 2011 | Toro Snow Blower Ccr 1000 Belt 715381...
Toro snowthrower model 38185, wont stay running? It will run for about 5 to 10 minutes then stop.
For the easiest solution, try running some automotive type fuel system cleaner through the machine (added to the gasoline; not straight). Find some Chem Tool Berryman B-12 at the auto parts store and add 2-3 ounces in a gallon of fuel or 1-2 ounces in a half gallon. The solvents in the cleaner may aid in cleaning a dirty carburetor. You may want to drain the fuel and remove the carburetor bowl and clean it out as debris may be there, intermittently clogging up the main jet in the carburetor. Water will settle there too.
Jan 08, 2011 | Toro Snow Blower Ccr 1000 Belt 715381...
My Toro CCR 2450 GTS Snowthrower loses power after it gets warmed up. New spark plug and fresh gas with proper oil mix.Why?
Mine does same. Wait a half hour, restart, runs good for 20 minutes and slows again. Just had it in for a tune up. Machine is only three years old.
Dec 31, 2010 | Toro Lawn Mower With Toro Power Tools
I have a toro snowblower with a 2 cycle engine. When it's just running under no load it seems fine(maybe a little too high of rpm). When it starts throwing snow it gradually slows down until it quits...
It sounds like it is running lean. Back out your carbuerator adjustment screws a quarter turn counterclockwise. These settings should be 1 and a quarter on low speed (closest to engine block) and 1 and a half on high speed (farthest from engine block). These are starting points the adjustment may vary a little eigther way. Never adjust for max rpms that is too lean and will cause engine failure. Hope this helps ya.
Dec 22, 2010 | Toro Garden
I am looking for the owner's manual for a Toro snowthrower CCR Powerlite 325E 38182
Good Luck,
Jim
Sep 09, 2010 | Garden
Snowthrower. Won't even fire. Can I just clean carburetor?
See my tip on diagnosing small engines. It works for 2-stroke or 4-stroke engines.
It is best not to use starter fluid. Aerosol carb cleaner is what I use.
Jan 02, 2010 | Toro Lawn Mower With Toro Power Tools
Garden Logo
47 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
