Question about Cambridge Soundworks BassCube 12 Speaker
Bass cube 12 - Cambridge Soundworks BassCube 12 Speaker
Roland cube-100 bass
Could be just a bad soldering joint, especially if it does so when touched or moved.
Mar 10, 2014 | Audio Players & Recorders
How to put together a double cube bose speaker
The Bose speakers with the cubes and bass module are all interconnected with a proprietary cable available from Bose, if lost you get a replacement by called 1-800-444-BOSE.
When you connect the speakers all wires run from the receiver to the base module first, then out to each of the speakers. All terminals on the bass module are labeled.
The Bose cubes are all identical and can be used in the front or back positions.
Try to keep them at ear level or aimed at the listening position for best sound.
May 17, 2011 | Bose Acoustimass 15 System
Bass Cube 12 makes loud buzzing noise when turned on !
Hi Ok thanks. I cannot be 100 % sure about this without seeing it but it sounds alot like there is a power supply issue, either bridge rec or caps. Caps are very often very obvious. If you get into it and have a look at what is normally the 2 or 4 biggest capacitors at the start/power supply of the board and see if they are ok visibily. If they are bulged, (often they actually explode and leave paper residue) then those are what need to be replaced. Have a look and see.
If its the bridge rec, it could be 4 diodes, fairly large next to each other or a square component with 4 legs out. Need a meter to test, but i would start at caps first
All the best
Aug 03, 2009 | Cambridge Soundworks BassCube 12 Speaker
Want to connect non-bose speakers to a bose lifestyle system
this is possible, however not a very good idea.
Bose speakers are designed a little different than other brand speakers, the Equalizer built into the bose system will probably not sound amazing when you hook up your other speakers. Are you looking for more bass? cleaner highs?
if you want more bass, you could try doubling up your subs, if you want cleaner highs you could buy Bose Jewel Cube Speakers (purchased from a Bose Built-Invisible Dealer
Jul 28, 2009 | Bose Lifestyle 38 System
Front bose speakers and bass module stopped puttimg put sound
If you're saying you hooked the Bose speakers directly to the Yamaha's amp instead of the prescribed way through their own bass module - they're cooked.
Dec 23, 2008 | Bose Lifestyle 12 System
Do I have to have a powered bass module to make the cubes work?
Your Acoustimass 5 is a powered sub with powered surround speakers. If you are not getting sound output, the internal fuse may be open and you will have to replace it. Bose used a heavy multiple output cable terminated in a miniature DIN plug to connect speakers. You may be able to find one on eBay.
Apr 17, 2017 | Bose Acoustimass 6 III System
Changing out my monitor speakers to bose cube speakers
You probably can do it as long as the speakers there now are 8 ohm speakers and you must use the bose bass module with the cubes because the crossover is built into the bass module for the cubes to work. If you just wire up the cubes you will mess the cubes up and they want sound right at all. The cubes are no good without their bass module in other words. Hope this helps.
Nov 09, 2008 | Bose Lifestyle 12 System
No output from Bose Lifestyle 12 system
Sounds like you have a problem in the circuits, which of course would take an experience technician to find and repair. But a 1994 electronic item has pretty much reached the end of its expected life cycle (sadly, compared to older equipment which is still working great). Basically, it sounds like the power amp circuit is shutting down a few seconds after startup. Might check to make sure no speakers or cables have shorts, which could activate a protection shutdown circuit. If any of the cubes don't hiss when you turn it on, that would be the first place to look for a problem.
Jul 01, 2008 | Bose Acoustimass 15 System
BassCube 12 Startup Problem
same here. happened after moving residences
Jun 30, 2008 | Cambridge Soundworks BassCube 12 Speaker
Open Questions:
See all Cambridge Soundworks BassCube 12 Speaker Questions
Cambridge Soundworks BassCube 12 Speaker Logo
46 people viewed this question
Top Cambridge Soundworks Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
 Grubhead
Grubhead
Are you a Cambridge Soundworks Audio Player and Recorder Expert? Answer questions, earn points and help others
