Question about Weiser Lock POWERBOLT ELEC DEADBOLT
Deadbolt doesn't function
Deadbolt does not go in and out
I bought a DEFIANT KEY PAD DEADBOLT.
Usually you just take it apart and turn everything around, the keypad would be turned over and the bolt would be removed and turned to the reverse of where it was.
If it is the type below, I am thinking you would remove the deadbolt part and turn it and then there must be something inside that reverses the throw of the bolt. No instructions with it?
Defiant Electronic keypad Deadbolt Satin Nickel The Home Depot Canada
Nov 11, 2015 | Defiant Stainless Steel Ball Entry Knob...
I can't figure out how to remove deadbolt since it doesn't have any svrews
I think you may have a friction fit type of deadbolt. Remove the door knob or the knob you turn to slide the deadbolt. There should be a shaft that comes out with the knob and was sticking through the inside part of the deadbolt. Now pull the deadbolt straight out, you probably need pliers for this part, be gentle so you don't take the finish off the bolt. I hope this helps, if it doesn't then I may need more info.
Sep 24, 2015 | Deadbolt Locks & Locksmithing
How to delete add new code
Add User code: Press PC, Press Schlage, Press 1, enter new user code, repeat new user code, Function completed!
Delete user code: Press PC, Press Schlage, Press 2, enter unwanted user code, repeat unwanted user code, Function completed!
PC(programming code)
Jan 18, 2013 | Schlage Camelot Deadbolt Keypad, Satin...
Deadbolt will not function
The Weiser brand and Kwikset brand Powerbolt are identical (Black & Decker), so these instructions will work just fine for you:
http://www.kwikset.com/Customer-Support/Product-FAQs/Faq/50160000000HhhEAAS.aspx
Notice that the above is a .PDF file type. That means that you need to have Adobe Reader or similar installed on your computer to view it. So if you are unable to view the file, download (for free) and install Adobe Reader first. You can get it here:
http://get.adobe.com/reader/
Good luck--and please provide feedback if this helps!
Oct 09, 2011 | Kwikset Powerbolt/Electronic Deadbolt-...
The system doesn't seem strong enough to turn my deadbolt. I checked and double checked my installation....
I hope that you have been able to get your lock working properly since I sent the "Ask for clarification" post several days ago, which included several suggestions for your problem. I'm considering this fixed, since you haven't re-posted.
Jul 14, 2011 | Weiser Lock POWERBOLT ELEC DEADBOLT
My Kwikset Electronic Deadbolt is working in reverse. When I push the lock button it retracts the deadbolt. When I put in the access code it extends the deadbolt. What is wrong?
My lock did not have jumpers, but adjusts itself automatically... You have to hold the lock button in (on the exterior side) while you insert the battery pack - the deadbolt will cycle in and out, then beep a couple times. You'll be holding button for maybe 10 seconds.
I have to say while this step is included in the instructions in a big red box, it says nothing about why or what its doing, so I imagine many people miss this...
Mar 05, 2011 | Kwikset 907 907-15 Satin Nickel Powerbolt...
Weiser keypad deadbolt lock deadbolt does not move when motor runs
Hi... You have too be sure that the deadbolt is free when it go inside the deadbolt hole... however this system is very low power and the (over torque clutch) will sleep if the deadbolt it's not completely free.
Also if you try to open the door before you unlock it, you may block the the deadbolt inside the deadbolt hole. Take care too unlock the door before open-it...
Dec 30, 2010 | Weiser Lock POWERBOLT ELEC DEADBOLT
Schlage deadbolt installed about a month ago. The key will not turn the lock from inside but will from outside. Any suggestions?
my guess is that during installation the inside lock cylinders were 1/2 or a full rotation more in one direction than the outside cylinders. remove it from the door, assemble it and try it without installing it. If it doesn;'t work, take it back. If it's old, oil it. if that doesn't work- toss it- you've spent an hour on a $15 item.
Sep 24, 2010 | Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA...
I have exactly 5 and 1/4 inches between the center of my deadbolt and door handle. Why do I need 5 and 1/2 inches? thanks
The standard sizes represent what is available in terms of the measurment from the door jamb plate and the center of the lever hardware. Your release handle will not operate correctly, both deadbolt and passage lock.
It sounds, however that you are referring to the distance between two items. The height of the deadbolt in reference to the door handle is not critical. It is dictated by looks, more than function.
Sep 17, 2010 | Schlage BE365-PLY BE365PLY626 Satin...
Deadbolt stuck on lock position
hello there:
you will need to dissasemble the deadbolt there is a plastic piece that wears out over time and once this wears out it wont work right probably best just to replace the deadbolt (sorry)
Jul 22, 2009 | Schlage B362 619 KA4 Dbl Cyl Deadbolt Per...
Weiser Lock POWERBOLT ELEC DEADBOLT Logo
90 people viewed this question
Top Weiser Lock Locks & Locksmithing Experts
Jim Goldsmith
Jim Goldsmith
john h
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
