Question about Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Having hard time with new poulon 18" chainsaw starting.
Bought a brand new poulon (pp4218avx) 18" right after hurrican ike. Used new gas with 40:1 mixture and used 1 tank of gas. after that I have had a hard time starting machine. checked spark and it has strong arc. easy to pull cord without spark plug in, difficult to pull with spark in. please help.
  • capracktx May 20, 2009
    The filter is clean and I have sprayed carb cleaner in it and still same problem.
  • 10,865 Answers
Since you have good spark and good gas the only things left to check are the air filter and the carbeurator. If the air filter is dirty, replace it. While you are at the auto parts store also pick up a can of a gasoline additive called seafoam which will keep your carb. clean. Finally get a can of spray carb. cleaner and put a couple short squirts directly into the air intake which is right there when you remove the air filter.
Posted on May 20, 2009
  • Joe Hogan May 20, 2009
    OK the carb. is still the problem. It needs to be removed, soaked in cleaner for three hours and possibly rebuilt using the proper rebuild kit for that model.
Chainsaw runs then dies
Carburetor needs to be overhauled and replace all fuel lines and fuel filter.
May 06, 2014 | Poulan Pro Chain Saw. 18 in. 42 cc Gas...
THERE IS NO GAS LEAVING THE CARB AFTER PRIMING THE PUMP OF A PULSON PP4218AVX CHAINSAW. CHANGED THE FUEL LINES AND PUMP. STILL DOESN' T START.
Hi Leo...
Check to make sure you have the fuel lines installed correctly.
Check out the picture below
Please take time to rate me
Bud
Mar 21, 2013 | Garden
I just bought a used 350 husqvarna chain saw fires up n stalls right away put new premium gas in it
Start with a few simple things, replace the fuel filter in the fuel tank, check the fuel hoses for signs of leakage, replace if required.
Dec 22, 2012 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
The chain saw is brand new. It starts OK but after I make one cut it stalls (Every time).
Do you have the proper gas-oil mix? It should be 40:1, which is 3.2 oz of oil/synthetic oil to 1 gallon of fresh gasoline. Make sure you push in the choke after starting it. Also make sure the chain brake is off (chain should move freely by hand when the saw is TURNED OFF.) If gas mix is right, choke is turned off after starting and brake is off, take it back to the dealer/store.
Aug 29, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Yes i cracked the oil housing for my poulan pp4218avx 42cc chain saw and I was wondering if they sale a replacement housing to repair the saw.
A Poulan PP4218AVX Gas Saw link follows:
http://www.ordertree.com/modelinfo/PWE/PP4218AVX-Gas-Saw/75.PP4218AVX-Gas-Saw.1.59.1.html
See the "Handle, Chassis and Bar Assembly" print, item 38. Is this what is broken? If yes it is possible to replace it, it is not terribly expensive, it is a great deal of precision work. I hope you already removed the clutch (left handed thread). I would probably keep this for parts and purchase a PP4218AVHD Gas Saw Type 2 as a replacement. HTH
Lou
Feb 23, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I need a new primer bulb Poulan WildThing 42cc CS
Item 18 on the "Engine Assembly" detail IPL here:
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best; components are listed but may be on different illustrations.
If this is not your saw you can fin d your here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
HTH
Lou
Jan 23, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
The back post that holds the bar has come loose and turns
Provided your saw is a PP4218AVX, tThe bar studs are item 41 on the "Handle, Chassis & Bar Assembly" here:
If not an AVX the correct IPL can be found here:
Poulan.com
The tank is usually split to install a new bolt. Please read some of the repairs here:
ArboristSite.com Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
Sealing the new bolt to the fuel tank is the hard part.
Good Luck
Lou
Jan 17, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan Pro 42CC 2 Cycle Chainsaw, 18" Logo
543 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
