Question about Dimplex OFC1500 Oil Filled Radiator Heater
Dimplex ofc1500 not heating up - Dimplex OFC1500 Oil Filled Radiator Heater
Need replacement grille for Dimplex floor drop-in heater FFIH15A31
Get the dimensions of grille and contact dimplex, or plumbing & heating supply store for new grille.
Apr 15, 2014 | Dimplex FFIH15A31 Electric Heater
Is it cheaper to leave my heaters on?
It works both ways if you are home it will give a constant heat , but is it safe in your place to leave it on while you are out .
Once they are hot they should cut out on the thermostat thus costing less to run .
Dec 08, 2012 | Dimplex OFC1500 Oil Filled Radiator Heater
I have 2 Dimplex DS4411 fireplace heaters. One has the fire display, but does not heat. The other has heat, but no fire display. How do I fix it?
The fire display is a simple replacement of the light bulbs that produce the effect.
The heater issue could be a bad temp sensor, or a bad heater.
You can contact Dimplex support here:
Technical specialists:
1-888-346-7539
Monday - Friday
8:00 a.m. - 4:30 p.m. EST
Nov 28, 2012 | Dimplex DS4411 Electric Heater
There is not heat coming out my dimplex
1-888-346-7539
Monday - Friday
Oct 08, 2012 | Dimplex DF3003 Electric MidSize Heater
I have a Dimplex Ritz electric 2000w heater that is only working on the low 1000w setting. When the high setting is selected it auto turns off and there was a funny smell which I am assuming a fuse has...
Yes, it can be repaired, if Dimplex still stocks that particular heating element. It's not to difficult to replace the heating element, just mark all the wires before removing the old one. Also, it will require removing the logs inside the heater, because you will need to turn the stove upside to do the removal and replacement. Contact Dimplex Technical Support at 1-888-346-7539.
Hope this helps you.
Jul 06, 2011 | Dimplex Compact Electric Flame Stove...
Dimplex manual
HI
you could try here at or even email/contact them these should be able to give you the manual
Dimplex Heating & Fireplaces
riz.
Feb 05, 2009 | Dimplex Compact Electric Flame Stove...
No Heat or fan on model DS4411 Or 6901050100
I had the same problem. One or more of the switches for the stove have melted and broken. You need to call Dimplex and request new switches. They should ship you out a 3 pack for free, and the pack will come with easy instructions for removing the bottom panel and replacing the switches.
Dec 22, 2008 | Dimplex DS5598 Mid-Size Heater
Dimplex OFC1500 Oil Filled Radiator Heater Logo
70 people viewed this question
Top Dimplex Heating & Cooling Experts
Paul Carew
ashburton
Kory Ronning
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
