Question about Sharp LL173C 17" Flat Panel LCD Monitor
My monitor does not turn on
There was a storm yesterday and the power went out . I have it connected to a surge protector,everything else is working. The yellow on off light is blinking but it does not turn on
  • Anonymous Jul 17, 2008
    the on light just blinks once on my monitor-i tried turning it on and off; but it does not work-i think its because of all the power shortages that occur in Africa
  • 93 Answers
There is power problem  in your monitor.check the fuse,regulator,and horizontal output transistor
Posted on Oct 19, 2007
SOURCE:
My lg tv won't turn on after a lightening storm
Your surge protector did not function properly, contact the manufacturer of the power strip.
Jul 05, 2012 | LG 55 55LW5600 3D LCD TV
I have a Dell LCD monitor (model number: E198FPf) that will not turn on. The power button is flashing and the monitor has a faint flicker with no discernable image. I removed it from the computer that it...
i believe you may have answered your own question here because what you are stating is a malfunctioned monitor if you plugged other monitors to the cpu and they worked and the monitor in question is not working maybe it was a storm surge and since it did not have a surge protector then maybe the monitor is shot and you may need to replace the monitor...
hope this helps
Feb 21, 2011 | Computers & Internet
My monitor doesn't go on anymore. Las night I had a pop-up appearing on the screen. I closed my computer and started over again. I'm sure I didn't turn off my monitor. Everything went well until this...
First, check to make sure the power cable is plugged properly in the back of the monitor and into the surge protector. You can try a different power outlet, but if you're still having the same problem and the light isn't turning on, it's likely you've either blown the fuse inside the monitor, or you had a power surge and blown something inside the monitor. This happens when you don't use a surge protector and just plug the monitor into the wall.
That said, if the above doesn't work then you have a hardware problem with your monitor and it needs to be serviced.
Jan 11, 2011 | Computers & Internet
No power either!!
Unplug the surge protector and plug the tv in directly to an outlet that you know is working, plug something else in first to be sure.
you may find that your surge protector is shot. if it is toss it and get a new one.
Sep 07, 2009 | Panasonic CT-36HL43 36" TV
The monitor was working one day and the next day, it would not come on, screen black. My grandson has had the monitor for almost three years.
I'll hope for the best and assume the simple fix first. Check the plug at the back of the monitor to insure it wasn't pulled out slightly. Sometimes, moving something around can cuse the plug to lose proper connection.
Also, check the power source to insure that you have power to the unit. We had a lightening storm recently and the power strip surge protector did it's job. I turned it back on and everything powered up again.
I hope this helps... Good luck!
Sep 02, 2009 | Computers & Internet
Hp laserjet printer 2840
Most surge protectors only protect up to a certain limit. If you had a large surge, then i would say the power board in your printer has been zapped. I would suggest you purchase a new or second hand printer to replace yours, unless your willing to pay more than the printer is worth to fix it.
Another thought is that the problem could be the actual power point it was plugged into. Try plugging it in to another power outlet that you know is working.
May 14, 2009 | HP LaserJet 2820 Printer
Blank Screen
Be sure that the power cable and the video cable are plugged into your monitor, the power cable is plugged into a good outlet, and the video cable is plugged into your computer. It's possible that you simply have a loose cable.
If everything is installed correctly, and if the screen is completely blank (no "cable disconnected" or "test mode" messages), then it sounds like your monitor is simply dead. Since there was a heavy wind storm recently, it was probably hit by a power surge. If you don't already, I recommend that you use a surge protector for all digital equipment.
Nov 12, 2008 | Computers & Internet
Storm last night, now Wii won't power up
Unplug everything! There is a "breaker" in the power supply and it may need to be reset. Just unplug all cables from the TV and outlets. Let it sit for a couple hours then plug everything back in and it should work fine. If not then the power supply has shorted out due to a strong power surge. You can claim it under your home owners insurance or call Nintendo and try to get it replaced. Thanks! Good luck and happy gaming!!
Aug 31, 2008 | Nintendo Wii Console
Transformer
Several things have happened. 1st have you tried plugging the monitor in the wall and not in the surge protector. 2nd does your power button or LED light uo when you power it on? You have stated the transformer is bad due to lighting strike. Have you replaced the transformer? Your monitor should be coverd under the surge protector warranty. Please answer questions and we will go from there.
Jan 03, 2008 | Computers & Internet
Constant beeping,won't turn on
What is the beep pattern? beeeeeeeep, beep,beep beeeeeep etc. also what BIOS do you have?
Aug 05, 2006 | Gateway EV 700 17" CRT Monitor
Sharp LL173C 17" Flat Panel LCD Monitor Logo
295 people viewed this question
Top Sharp Computers & Internet Experts
Jason Harris
Jason Harris
Siul Oyaratgam
Joe Negus
Joe Negus
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
