Question about Epson AcuLaser C1900 Printer
Ghost image on Epson Acculaser C4000
I get a "ghost image" half way down any page that I print on the Epson Acculaser C4000. It is a faint but noticeable ghost image of whatever is at the top of the page. Does anyone know what this problem is, and more importantly, how to rectify it?
  • Frank Zhang
    Frank Zhang May 11, 2010
    how long you use it? any consume parts changed?
    no any messages shows on the panel?
    no any unusual noise inside?
  • Frank Zhang
    no any error mesages show on the panel?
    how
  • 163 Answers
Ghosting can be caused by several components: 2nd BTR transfer roller, Photoconductor Unit (PCU) or the Fuser unit. The most likely is the PCU contacts being dirty, caused by toner getting between them. Open the front of the printer (cover B) and lift out the photoconductor. Clean all of the metal contacts down the sides of the PCU with a cloth and wipe out any loose toner from inside the printer and give the contacts inside the printer on the R/H side a good clean. Replace the PCU and close the front cover.
Hopefully all will now be well, if not open cover A and clean the transfer roller on the inside of the cover. If problem persists you will need to get a Tech out to look further as without seeing the printer it is pretty hard to diagnose.
Good luck.
Posted on May 20, 2009
LJ4200 ghosting in middle of page
Perform half test page & check for the ghost image.If half test page not showing ghost image go for 2. (Half test page:while printing open the door, take out the cartridge, remove inside paper gently) 1. check with another cartridge
2. replace teflon sleeve if available or replace fuser assembly..
Nov 29, 2012 | HP LaserJet 4200 Printer
RICOH FW740 is printing with a ghost image. Can I clean it myself?
Ghost images appear on the printed page because of bad cleaning blade or improper charging of the drum unit. Ghost images appear on the next printed page if cleaning blade does not clean the drum surface. Drum/ photoconductor is very sensitive to light, so special care should taken while pulling it out. Read More here Image ghosting problem
Dec 02, 2011 | Ricoh Office Equipment & Supplies
After changing the ink catridges and resetting the drum fuse lately (note: it is known that the fuse will be blown off after certain number of prints but otherwise is in good condition), my Epson Acculaser...
The repeating image is a ghost image, and here is described what it can be. Probably if you solve this, you also solve the red-dot problem. If possible, I would suggest to replace the wiper blade.
Repeating images on laser printerThis likely means a faint ghost of the main printout at a distance equal to the circumference of one of the rollers or photosensitive drum.
Depending on where the problem originates, this could be a bad wiper (cleaning) blade, faulty corona, or incomplete fusing.
  • If the distance between successive images is equal to the circumference of the photosensitive drum, it is a wiper blade, erase lamp, or corona problem.A residual latent image or residual toner is sticking to the drum and not being properly cleared.
  • If the distance between successive images is equal to the circumference of one of the fuser rollers, then the fusing may not be complete due to damaged rollers or an incorrect temperature setting.
It is easy to determine where the problem is located: Interrupt a printout in mid-stride (where part of the paper is between the toner/developer and fuser. If the un-fused image has ghosting, it is a fault in the area of the drum
Jul 08, 2011 | Office Equipment & Supplies
Ghost images of the same printing repeated down the page
Run a half test. While printing a few pages, open the cover, pull out the toner and look down at the paper. If you see the ghost images replace the toner. If you don't see the ghost images, replace the fuser.
Sep 11, 2010 | HP LaserJet 1020 Printer
I am getting a ghost image of what I am printing repeating down the center of the page.
i would say ghost image is more likelly your imaging drum.
some printers have the imaging drum built into the cartridge some have it separate.
i would say try another cartridge
also don't trust remanufactured cartridges if you are concerned with print quality.
Apr 24, 2009 | Samsung ML 1430 Laser Printer
Epson 1290 prints a ghost image in cyan or magenta
I like this one! No don't have a solution but....interesting Try it's test not by computer, just printer, may need head alignment, should be a command for this on printer
Apr 23, 2009 | Epson Stylus Photo 1290 InkJet Printer
Xerox Phaser 6360N ghosting images on each page
Is it a ghost of the image or just a repeating defect? In the menu, there is a repeating defect information page that you can print out. Depending on the spacing of the defect, you can determine which component it is.
Mar 10, 2009 | Xerox Phaser 6360/N Printer
Epson C1900 "ghost " images
Sounds like the transfer roller or the fuser unit may be faulty. Look at the fuser to see if the roller surfaces are dirty. If so, replace the fuser.
Jul 20, 2008 | Epson AcuLaser C1900 Printer
Ghost images
Is it from the most recently printed page, or is it the same image avery time regardless of what you print? It sounds like your drum or roller (I'm not sure about the exqact term in english) might be the issue. Have you somehow managed to "force" a printing without paper in the printer?
May 18, 2007 | HP LaserJet 4 plus Printer
Epson AcuLaser C1900 Printer Logo
408 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
