Question about Janome Sewing Machines
Janome 6600 makes loud clicking noise when needle goes down and shuts down
  • 9 Answers
SOURCE: Bernina deco noise
See if drive belt is not running against the plastic body on right side.!
Posted on Nov 18, 2008
bargainbox
  • 1388 Answers
SOURCE: janome 5700 handwheel stuck/inside pulley stuck
The error message relates to the motor sensing that it is working unusually hard.........the extra strain will have a physical cause, generally in the hook and bobbin region.......something blocking or slowing things down, so.......
Remove needleplate and bobbin case.
You will probably find an accumulation of lint in and around this area, also possibly in the feeddog channels.
Use a small brush and vacuum with crevice tool to remove the lint and wipe the hookrace with a tissue moistened with methylated (denatured) spirit to remove any dirt deposits.
Also check that the bobbin case is not damaged on the top surface by needle strikes or on the underside rim by the hook gouging as it spins.
If damage is present but mild, you can use very fine emery paper to smooth surface, if more severe, replace the bobbin case. Don't forget to change needles regularly too.
Best of ......
 www.bargainbox.com.au
Posted on Nov 21, 2008
SOURCE: Oiling a Jonome 6600
Remove the plate and bobbin case, beneath it will be a small round hole in the center. Inside the hole is a fluffy piece of absorbant material called the wick. DO NOT REMOVE IT! Place one drop of sewing machine oil on the wick. While you have the machine opened up, you should remove all the dust. I use the small brush that comes with the machine. Replace the bobbin case and make sure that it is clean too. Replace the plate. Lastly add a couple of drops of sewing machine oil to a q-tip and use it to apply oil to the needle bar above the needle clamp.
If your machine continues to squeek then bring it to a professional sewing machine repair technician and pay for the service to have it professionally cleaned and tune up. It is not worth damaging you machine over a few dollars well spent.
Posted on Jan 05, 2009
SOURCE: Needle touches a metal part and makes a weird noise!
Check your bobbin...make sure the handle is pointing upward.
Posted on Apr 07, 2009
  • 11 Answers
SOURCE: I have a Brother ex-660 and it is making a thumping noise
Change the needle and then using the side wheel wind through the stitch process manually. If the needle is still hitting something down under the needle plate, then your timing is out, take it to a mechanic.
Posted on Oct 07, 2009
Janome 6600. Needle came loose &fell down into the bobbin area. Needle did not break off. I took off the plate and manually tried to move a new needle and shaft up/down. needle is hitting something
If you did not get the old needle out, it may be blocking something. That old needle must be removed before you attempt to any further sewing. Try removing the bobbin case from the machine and looking in there to see if you can locate and remove the old needle. Sometimes, I've had to turn the machine sideways or upside down and shake it to dislodge the needle.
Open the bobbin area and hand rotate the handwheel while watching the needle action. If it is hitting, you should see it. If that is the case, the machine may be out of time and need service.
Jul 11, 2017 | Janome Sewing Machines
I just got a new Janome 8002d serger. Why does it make a clicking noise when I begin to serge and then it goes to straight stitching that comes unsewn.
I don't have a Janome, but you might check your threading to see if it's correct, lucky you to get a new one!!!
Mar 05, 2015 | Janome Sewing Machines
What is e4 error code on janome 7700qcp sewing machine
sounds like repair shop time as timing has slipped needle hitting bobbin case possibly
Feb 12, 2015 | Janome Sewing Machines
Janome hello kitty 525 won't feed fabric or needle does not move up and down. Everything seem to be thread correctly and clean.
Hi Thi: make sure the machine is not set to wind the bobbin. Turn the handwheel towards you and see if the needle moves. You may have a belt that has come off. Does the machine make noise like the motor is running when you press the foot control?
Sep 02, 2013 | Janome Sewing Machines
My brother started making a loud noise when sewing pant fabrics
Your machine is complaining because it doesn't have the power to push through the layers of fabric. That clunking noise is the gears in the machine skipping and being sheered off (or it will be eventually) STOP!
If you feel that you need to continue... stop when it does this noise and use the HAND WHEEL. You'll also need to make sure that the presser foot remains level while going over thick seams.
Jan 02, 2013 | Brother Sewing Machines
I think I've bent something!
when you have the foot down ready for sewing,the needle thread , pull on it slowly and make sure there is resistance through the top tension, if there isnt any then the tread will ball up underneath
May 03, 2010 | Janome Memory Craft 4900QC Mechanical...
Janome 5700 handwheel stuck/inside pulley stuck
Best of ......
Nov 04, 2008 | Janome Memory Craft 5700
Oct 27, 2008 | Janome Memory Craft 5700
Sewing Machines Logo
136 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
