Question about Capital Cooking PERFORMANCE PSCT486B 48 in. Gas Cooktop
Uneven heat distribution on the griddle
My griddle gets extremly hot only in the back and moderate in the front.
Technician looked it over and the burner is burning evenly.
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 05, 2010
How do I clean a Viking griddle that hasbeen
I use a product called Greasecutter Plus by ECOLAB, it makes the griddle look brand new, gets everything off. You just spray it on and let it set for a little bit then it wipes clean.
May 13, 2010 | Viking Cooktops
I was given a 36" magic chef gas cooktop with griddle. It was very greasy and dirty, all the burners were sticky and slow to get turned on, but 2 of them refuse to turn on, parts lists say the griddle...
If it's two burners on the same side that won't light, it is probably the igniter for that side. If so, remove the grates, griddle, and griddle sub pan, and then lift up the main "pan (if it's like mine, it's hinged at the back and lifts up). Now, if each burner on that side has a tube going to the middle between the burners, the igniter is in that middle section. Mine is a small plug-in ceramic and metal part (see photo). If yours looks like this, contact me at jazzskier@verizon.net, I have a spare.
Nov 29, 2009 | Magic Chef 30 in. 8241RT Gas Cooktop
I need a Thermador griddle control/ignitor & a light switch knob
We are Thermador factory authorized service and parts suppliers. Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
and we can get your ignitor and light switch out to you asap.
We look forward to working you. Thanks, Ella
Nov 10, 2009 | Thermador 37 in. SGSX365 Gas Cooktop
Need to restore the non-stick surface on a GE griddle
Put a sheet of wax paper between the two plates for a few minutes while it heats up, then remove. It will transfer the wax to the grill so you'll temporarily restore the non-stick coating.
Oct 17, 2009 | GE Cooktops
I have a viking cooktop with 4 burners and a center griddle. The griddle will not hold heat. It fires up then goes out.
This can be cause dby one of 2 problems.
When you turn the control to turn the Griddle on, does it come immediately or do you have to turn it a long way before it comes on?
If it turns on immediatly then it is more than likely the Ignitor
If you have to turn it a long way you have a defective Thermostat
Feb 18, 2009 | Viking VGRT600-6G Gas Cooktop
Thermador Gas Range - Griddle ignition will not spark
I have a Thermador Gas Range PG364GDBS - Oven, 4 burners, and center griddle. All are gas. The four burners and gas oven work fine. The griddle just stopped working, no spark. Turning on the griddle control, the gas valve opens(hear it), gas flows (smell it), but the ignitor will not spark (no loud or faint spark that I can hear). I got a replacement ignition device (mount at the burner) thinking it might be the problem, but still no spark. I checked the AC voltage at the terminal and measured 39 VAC between the terminal and ground. Not sure if that is the correct voltage. Any insights or advice would be great.
Dec 07, 2008 | Thermador SGS36GS Gas Cooktop
Thermador PCS364GDUS griddle needs cleaning.
Wear gloves, put all items in a garbage bag. Put outside and spray a can of easy-off oven cleaner on all parts. Seal bag and let sit for 24 hrs. They should come out looking new after you rinse them off. After you wash them off, put them in a 300* preheated oven for about 30 min to ensure they are dry.
Oct 22, 2008 | Thermador PC366BS Stainless Steel Gas...
Broken griddle control
Hello
It sounds like you have a short. Replace the switch is very simple. Here are the Owners Manual and the Instalation Instructions.
  • Owners Manuals (1)
  • CCGP2720P.pdf (942.48 KB)
  • Jun 28, 2008 | Jenn-Air 36 in. CCGP2720P Gas Cooktop
    GE Stove
    check all holes on burner make sure all air/gas holes are unclogged do not use any ajax or any cleanser that will leave a powdery residue.
    Nov 30, 2007 | Cooktops
    Capital Cooking PERFORMANCE PSCT486B 48 in. Gas Cooktop Logo
    156 people viewed this question
    Top Capital Cooking Cooktops Experts
    Dan Webster
    Dan Webster
    paulcarew
    Are you a Capital Cooking Cooktop Expert? Answer questions, earn points and help others
