Question about Zanussi FS1455W Front Load Washer
Machine program starts bleeps couple of times then end light flashes with no wash being done
maklean
  • 1665 Answers
SOURCE: washing machine fs1255w does not
Zanussi FS1255W Spare Parts & Accessories Check also door interlock function See necessary parts at above link.
Posted on Aug 07, 2008
SOURCE: Zanussi zwf1631w jetwash front loading washing m/c
had to call an enginer out, the problem was down to a faulty motor rota, to identify if e30 is this fault, rotate the drum (so the motor rotates) and try to start the m/c. if it runs ok you know to change the rota. hope this may help someone
Posted on Sep 16, 2008
  • 17 Answers
SOURCE: our washing machine (Zanussi ZWF 1632 W) flashes 5 times
This is a motor problem the end light flashing 5 times indicates error E50. The motor has either got wet or has just failed i would suggest trying to dry it 1st but i would suspect the motor has gone down to earth usually having to replace it. The part no. DST1246179079 Motor aprox £195 but shop around you may find it cheeper.
Posted on Dec 17, 2008
  • 236 Answers
SOURCE: Door not locking and program reverting straight to end
initially i would replaced the door interlock then if no result the control boart could be faulty.
Posted on Mar 13, 2009
  • 82 Answers
SOURCE: Exactly the Same Problem
It's difficult to say without seeing the machine or having a failure code.
The machine looks for a switch to close as it fills with water. Maybe a pressure switch?
You could find the switch and see if it clicks when blowing into it and even test it with a meter.
That's an easy test.
Maybe the module has failed.
Hope it's given you something to look for.
regards
john
Posted on Aug 28, 2009
Machine starts then program end light flashes constantly and has done nothing?
I had similar problem and Eventually replaced motor brushes which solved the problem
Feb 26, 2012 | Hotpoint WMA11 Front Load Washer
When pressing the start button on my washing machine it makes 2 clicking sounds at the door and then bleeps and the program goes to end. Could this be the door lock?
It possibly could be. If you push in on the door when it's closed and push start, does the door lock and the machine start. If it does than it is probably the door needs to be adjusted.
Mar 01, 2011 | Washing Machines
I have some problems with a Whirlpool DWF 406 dishwasher: The other day, my wife complained about it not finishing a program (just stopped and started bleeping). I saw a post at this forum where it said to...
We have the same problem. The dishwasher is 10 years old. In one of the German forums they said that usually it's because the sieve ahead of the membrane has a fine layer of sludge and the pump cannot pump out the dirty waste water. They said that you have to dismantle the sieve, clean it thoroughly, re-install it, and it should work just like it always did.
Nov 29, 2010 | Whirlpool Dishwashers
My Zanussi zwf1650w comes up with a message draining 0 0 after about 30 seconds of starting a wash cycle. The machine the stops and bleeps saying cycle ended, is there a solution to fix this?
zanussi zwf1650w washing machine. when starting any program after a few seconds machines stops and shows draining 0.0. have done diagnosis test and shows fault E91 & E48 fault codes also shows E34 code. any help much appreciated.
Nov 05, 2010 | Zanussi ZWF1650W Front Load Washer
Starts bleeping 10mins into cycle
http://www.manualnguide.com/dl/12334/ Check on the troubleshooting page as to what certain flashing sequences mean and that may help
Jan 08, 2009 | Baumatic 23 in. BDW5 Built-in Dishwasher
Our washing machine (Zanussi ZWF 1632 W) flashes 5 times
Dec 11, 2008 | Zanussi ZWF1430W Front Load Washer
Zanussi zwf 1432 w washing machine
pcb as the signs were that the pcb was stuck in a programme and unable to change. Anyway, long story short, to fix it:
Take the lid off the washing machine (2 screws at the back) *unplug first
Locate the pcb, unscrew and lift above the washing machine with all wires in tact.
Locate the wires that are coming out of the back of the "program" board, it should be 2 blue wires.
Follow these back to the pcb and unplug
plug in washing machine
Turn on washing machine
Only the on/off light should come on
Whilst on, and being careful, plug back in the wires you unplugged
VOILA, fixed washing machine!!
Right, have to go, got a weeks worth of washing to do!!!!
Feb 24, 2008 | Zanussi ZWF1430W Front Load Washer
Tecnik DW2677
check your water intake- i had the same issue - a leaky fitting wasn't supplying enough water to the dishwasher. had exactly the same symptoms you describe. fixed the leak, reset the dishwasher & it's working fine.
Oct 29, 2007 | Tecnik TDW2677 Built-in Dishwasher
Zanussi Washing Machine
At bottom left of machine there is a small metal flap where you can drain off water. Next to that is a grey pipe you can keep pulling and pushing i have done this quite a few time and it has let out sludgey stuff put washing machine is now spinning and draining. Good Luck.
Aug 29, 2007 | Zanussi ZWF1420W Front Load Washer
Zanussi FS1455W Front Load Washer Logo
37 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
