Question about Sta Rite Pool & Spa
Error message, EO1 and spa heater will not fire
5 Suggested Answers
SOURCE: Hayward H300 Spa Heater will not fire up
try to replace the thermo sensor it is located on the left side of tghe unit and has 3 wires running to it.
Posted on Jun 13, 2009
  • 990 Answers
SOURCE: Water Temprature read 126 on heater and will not Fire
This is a problem with your thermister (heat sensor) You will find this on the left side of the water manifold about half way down. I'm not sure but I think it is a small tube that slides into the manifold and if you follow the wires back to the board it just plugs in. The part is reasonable priced for a heater part and very easy to install. Good luck.
Posted on Dec 21, 2009
  • 760 Answers
SOURCE: ao error message in Hayward heaters
You didn't indicate exatctly which model you have. But on most the AO error code is :Blower vacuum switch
open error If the blower prover switch does not close after the blower starts the control will
stop the ignition trial go into lockout. The blower will continue to run. Automatic reset is immediate after the switch closes.Check to be sure combustion blower starts
If you don't have your manual you can download one for your exact model at : www.haywardnet.com
Posted on Jul 29, 2010
Coastsider
  • 331 Answers
SOURCE: Hello- my customer is getting
Suggest you contact Hayward directly at https://www.haywardnet.com/forms/contactForm.cfm
Posted on Sep 10, 2010
Lay-Z-Spa e01 error
E01 error code. Drained hot tub, unhooked green egg. Ran hose into the two filter pipes and back flushed the pump. Plugged back in and it works fine now.
Jun 02, 2017 | Pool & Spa
Eo1 error code
EO1 is a thermister/temp sensor fault
Mar 28, 2016 | Pool & Spa
Heater wont start has code EO1 model SP 400LP
eo1 is a thermistor failure. problem is either with temp sensor, wiring from thermistor to circ board, or the circ board itself
Jun 13, 2014 | Sta Rite Sta-Rite Max-E-Therm High...
What is an IF error message?
ignition failure means tried to fire 3 times turn off and try again
Jun 11, 2014 | Hayward H Series Pool & Spa Heater 400k...
Ao error message in Hayward heaters
Jul 29, 2010 | Hayward H Series Pool & Spa Heater 400k...
E01 message when we attempt to turn on pool heater
These pool heaters have a great troubleshooting section in the users manual (link below). Try walking through that step by step. It should help you correct your problem in no time.
http://www.backyardcitypools.com/images/bwp/Max-E-Therm-Manual.pdf
Jun 04, 2010 | Sta Rite Sta-Rite Max-E-Therm High...
The EO1 signal comes on the heater
EO1 is a signal for low voltage. Your heater will run on 110v or 220v and you need to check your voltage comming into the heater and the wireing to the unit. Then check to be sure the heater is wired to that voltage. I hope this helps.
Jun 13, 2009 | Sta Rite STA-RITE CONTROL BOARD KIT -...
E01 fault and service light on
If you are still seeing the EO1 error code, turn over the display panel and see if there is a RED light next to a set of letters. Whatever the light is next to, that would be the cause of the error code.
Jun 08, 2009 | Sta Rite Maxi Therm 400k Btu Propane...
Pool & Spa Logo
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
john h
steve morris
steve morris
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
