Question about Dyson DC07 All Floors Bagless Upright Cyclonic Vacuum
DCo7 too much suction hard to push
Hi I have a DCo7 and its really hard to push when swithed on.The belt is ok and the roller spins fine and it moves fine until its swithed on and then digs in when i try to hoover.Any help woud be appreciated..Jon
    President:
  • 389 Answers
This suggests that the bristles on your brush roller are worn out.  When the bristles are a good working length, rotation of the roller actually helps to pull the machine over the carpet. When the bristles wear down this effect is lost.
Posted on May 21, 2009
My Eurika 4D bagless upright will not pick up anything. The belt is not broke but the roller won't spin and there is verry little to no suction. Still makes all the notice but won't roll as easily
You say the belt is not broken and the roller does not spin. Does the motor that spins the belt turn. If the belt does not spin and the little drive motor spins then you will burn the belt out. Try to turn the roller by hand. Could be plugged up with dirt and the roller seized. The little drive motor could be burnt out. Take all hoses and areas out that any dirt could be in. No suction means something is plugged. Even your main suction hose could be plugged.
Mar 15, 2017 | Vacuums
I have a simplicity 7350 vacuum. The belt and roller have recently been replaced. It runs fine on floor mode and has no problems with suction. When I put the vacuum in carpet mode, I do not hear the motor...
the motor spins around a steel shaft that sticks out on one end, and the belt is driven by that shaft, belts are easily damaged and broken, meaning roller wont spin. Often a burning smell of rubber is noticed after motor shaft spins on stuck belt. cause is always hair./string/something at the three contact points. motor shaft and belt, roller and vacuum body become clogged. become familiar with taking cover off roller/belt, and cleaning Checking moving parts roller/belt come out easily and simple to clean...keep spare belts.
Mar 10, 2014 | Vacuums
The suction is good, but it can't pick up most of the stuff on the floor. The hand held hose works very well, but it doesn't even pick up little fuzzies reliably when I push it along. And, the suction is...
Check entire length of hose, including the piece in the power head, for clogs. Simply drop a marble in one end and allow it to roll out the other. If it doesn't, then the hose is clogged somewhere.
Aug 22, 2010 | Dyson DCO7 Animal Bagless Upright Cyclonic...
Roller brush will not move when vaccum is turned on
maybe the belt is broken. clean the unit and replace the belt.
May 23, 2009 | Kirby Ultimate G Bagged Upright Vacuum
My vacuum has good suction but i can hardly push it across my carpet. any answers????
is your brush roller turning,that would cause it to be hard to push .the brush roller helps it walk across the floor.if your brush roller isn't turning then your belt is broke or the brush itself siezed up.unplug the vacuum and try to turn the brush roller .if it turns real free then your belt is broke.before you replace the belt always clean the motor shaft ,the old rubber from the old belt melts onto the motor shaft .if you don't clean it your new belt won't last very long.please leave feedback
May 04, 2009 | Kenmore Vacuums
While vacuuming it's unusually hard to push.
I see your post is from May. I just joined Fixya this month so, id you're still looking for a solution, I would saythe belt broken or is so stretched the roller isn't spinning. Here is an link to an online guide with illustrations for changing belt. Also check the roller brushes for wear and change if necessary. Hope this helps.
http://www.info-vacuum-cleaner.com/oreck-vac-belt.php
May 02, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Lost suction
Hi.
Remove the sole plate turn the 3 plastic screws to unlock & lift off.
Now remove the blockages that have accumilated from the oppening of short clear hose.
Check you can turn brush roller & check belt.
Now reassemble switch on pull handle back & look under machine is brush spinning ?
If not check the knob on side of machine is in drive (D) position.
http://dysonmanuals.llc.nu
Chris..
Dec 27, 2007 | Dyson DC07 Animal Bagless Upright Cyclonic...
Bad smell
it may be the roller bearings?
Dec 26, 2007 | Hoover U5450-900 Windtunnel Supreme Bagged...
Dyson Upright Vacuum Cleaner (Poss DC04- its green, if that helps?!?)
Hi.
Check brush roller is spinning & that belt has not snapped.
Check behind brush roller for blockages, Check clear pipe for rips or splits.
Check clear pipe for blockages.
http://dysonmanuals.llc.nu/
Chris.
Dec 20, 2007 | Dyson DCO7 Animal Bagless Upright Cyclonic...
Dyson DC07, too much suction...?
sounds like one of the filters is either damaged IE a hole or tear or is not seated correctly
Jun 09, 2007 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson DC07 All Floors Bagless Upright Cyclonic Vacuum Logo
300 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
