Question about Adobe Photoshop CS3 10
How can i clean face
Just i want to know that how type can i clean some one face
Yes
Posted on May 20, 2009
The stereo's volume goes up and down on its and I cannot control it. Loose wire connection?
this is dirt and the tactile switches and soft touch pads
if its a face off then replace the face
or get it cleaned or repaired {replace the switches if you can}
touch pad types can be repaired quite easy just with a careful clean
you could try to clean with a 'gold cloth' or a glass fiber pen
http://www.ebay.co.uk/sch/i.html?_odkw=burnish+pencil&_from=R40'R40&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR7.TRC2.A0.H0.Xglass+fibre+pen.TRS0&_nkw=glass+fibre+pen&_sacat=0
Apr 29, 2015 | Car Audio & Video
How do you clean the rollers on a pc428 canon copier
on my canon copier, there is a menu, that has a cleaning mode, if you have manual, look up cleaning, and it should show you what to do
Apr 14, 2015 | Canon Office Equipment & Supplies
Need to clean filter
Hazel, I assume you want to know how to find and remove the filter for cleaning.
The filter is located behind the front air intake louvers and depending on which model you have, the filter can be accessed one of two ways. Before you attempt to remove the filter turn the unit OFF and unplug it.
1. Remove the bucket from it's holder. Look up inside the bucket cavity, just inside the unit behind the louvers and you will see a tab type pull handle. This is the handle to the frame of the filter. Pull it down and out.
2. As you're facing the unit on the fight side just behind the louvers, there will appear to be a trap type door. Open this door and you will have access to pull the filter out.
You can clean the filter in one of two ways: Vacuum it or it it's really dirty, wash it in warm soapy (dish washing liquid), rinse and dry thoroughly. NEVER operate the dehumidifier without the filter in place. Doing so, can cause damage to the unit.
Hope this helped you. Please let me know.
Jul 05, 2011 | Haier Dehumidifiers
How could I know which sunglass suites me?
Well, here are some advices on how to match your sunglass to your face: 1. Suare face: Most complimentary style of sunglasses for a square face: To minimize the width of the face, it is best to choose sunglasses that add length. This can be best achieved by buying sunglasses that are not as wide as the widest part of your face. It is also a good idea to soften the "squareness" of a face by more fluid, rounded style frames, so as to decrease the perception of a broad jaw line. 2.Oval face-Most complimentary style of sunglasses for an oval shaped face: Generally any type of sunglasses suits an oval face, but just make sure that the size of the frame is proportionate to the face. 3.Round face: Most complimentary style of sunglasses for round shaped face: To sharpen a round face, select frames with straight or angular lines that will help make the face look thinner and longer.
4.Diamond face:Most complimentary style of sunglasses for a diamond shape face: Glasses that are oval, shaped or rimless are very complimentary for this type of face.
5. Rectagle face-Most complimentary style of sunglasses for squar shaped face: To compliment this style of face, it is best to choose sunglasses that will shorten the face and widen the face, both at the same time. The best style of frame to choose is one that is round, or deep to help soften the face.
6.Triangle face-Most complimentary style of sunglasses for a Base-Down Triangle face: To compliment this style of face, it is best to emphasis the top part of your face with strong balancing frames. 7.Inverted triangle-Most complimentary style of sunglasses for an inverted triangle face: Choose a type of frame that balances your face and broadens the lower part of your face. Low temples and rimless style of sunglasses are a good style to consider.
Nov 07, 2010 | Clothing Accessories
Orange faces
Under printer driver properties clean the print head.
Use only genuine ink crg.
Use only genuine photo paper.
Jul 02, 2010 | Canon Pixma iP6000D InkJet Photo Printer
I have several old art deco watches that run but the dial faces have yellow spots. Can I do any type of cleaning to fix this safely.
Do not even try to clean. Any physical touch will destroy original colours and laquer. I'd advise to go to your nearest watch repair shop and do the estimate first. Then you will know what the each piece is worth. Only after estimate you can decide witch is the right one to clean. If the estimate is lower than $10 - you can put it in to your washing machine and just laugh about the struggle. Hope the rest of your watches have some value. :))) Rate me, plz.
Feb 18, 2010 | Watches
Battery replacement in heart rate watch
Hello decksrnice & Guest, The battery should face 'IN' when placing in watch. The smaller size of the watch is the face. For Guest there is a flat type spring on the cover, carefully bend the spring to apply more pressure to the battery. Use a pencile eraser to clean the area the battery makes contact. If you bend the flat spring too far IT WILL BREAK.
Sep 18, 2008 | Exercise & Fitness
Keyboard not responding or typing random letters
You have stuck keys from when you removed to clean. Remove the stuck keys and see if it works OK when you press the rubber cap instead of key
The back space one may have a link under it if it is a wide one ensure it is fitted correctly
Aug 09, 2008 | HP P2360AA Keyboard/Mouse
Okic3200n lazer jet printer
Best results will be if the paper you are using is designed for use in this machine and you print with the driver knowing paper type and using a direct flat paper path
Use The bypass tray (and you can also use face up delivery tray ) and make sure you tell printer what paper type it is using ie control panel, printers, preferences, paper type set to photo/gloosy or even card stock if it is thick.
Ensure feed rollers are clean, and paper is good quality
Dec 23, 2007 | OKI C3200n Led Printer
Cleaning
Hi, There are so many different types of units that it is really hard to answer this question. If you have the manual it may help. The filter can probably be removed without taking the face plate off. The filter may be all that needs cleaned. It usually slides up out of the face plate. Clean it with soap and water and replace it. The face plate its self may have some screws holding it on. Many of them just come off after removing the screws. Others pop off from the bottom first, some from the top. If this is a unit still being sold, You could go to the store and have someone there show you how to take it off. Home Depot usually have some helpful people that may just show you how a few of them come off. That may help you to understand more about what you need to do to get it off. You could ask a friend, relative or neighbor to give you a hand. Usually two minds work better than one on such maters. I hope I have helped you. kstfas
Sep 19, 2007 | Heating & Cooling
Adobe Photoshop CS3 10 Logo
73 people viewed this question
Top Adobe Computers & Internet Experts
lemesee
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
