Question about SimpleTech SimpleDrive Pininfarina 500GB External USB 2.0 Hard Drive - Onyx
Can't access drive, drive won't start
I have two 320GB Black Cherries. Neither one will work off of my desktop USB's. I have a Western Digital USB drive that works fine, but not the Simpletechs.
The drive just sits there and clicks, and doesn't show up in My Computer.
Both drives work fine on my HP laptop.
Any ideas? Does anyone know if there is some access utility needed? or are these drives extra sensitive to voltage supply or something else quirky? Thanks for any ideas!
    President:
  • 272 Answers
If they are clicking it is because there is not enough power coming from the USB ports on your computer. If they don't have an external power source they will each need to be plugged into their own 2 separate USB 2.0 ports, they will not run on USB 1.0 as they won't get the power they need. Laptops tend to have more power robust USB ports than desktops. Hitachi supplies those drives with a pigtail adapter as they are power hungry. You can go down and get the external power supply for the drive and it will solve your problem as well. Or get a powered type USB hub, that has an external power adaptor that van power peripherals They will not run off an unpowered USB hub.
Posted on May 20, 2009
My Western Digital 320GB external hard drive not accessible
i noticed you ran the chkdsk utility on this drive did you try to repair bad sectors or just files
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
I found that you get best results by ticking one box then returning after it has finished then tick the other box if still no joy
try to use the external hard drive in a different computer and check whether you are able to access the data that is present on the external hard drive or you can try to connect it to a different port and check
hope this helps
Jun 27, 2012 | Western Digital 320GB MyBook External USB...
I cannot find my manual for my Wester Digital 320GB USB 2.0 Passport Elite Portable Hard Drive, Please let me know how I can get a copy of the manual.
Go to the western digital web site then click on support. Then select your hard drive and it should have a link to the manual.
Aug 01, 2011 | Western Digital Passport 320GB External...
I can't access my western digital external hard drive to any computers..How can i do?
Sometimes when a flashmemory stick or USB external hard drive fails because it was not removed fromthe USB port properly. If the device is removed byjust pulling it out of the USB port, it can cause the flash device to fail, youmust click on the Safely Remove Hardware icon on the Task Bar and select thedevice you wish to remove and only do so when instructed to do so When the flash memoryUSB hard drive device appears to malfunction it maybe possible to restoreit by reformatting it. Insert the flash or USB hard drive into the USB port then Click on Control Panel - AdministrativeTools - Computer Management - Disk Management. Then right click on Disk 1removable drive and click Format. After the flash drive has been formatted itwill indicate that it is Healthy.
Jun 13, 2011 | Western Digital Passport 320GB External...
Wd external drive stopped showing up on my desktop mac
Either you need to uninstall and reinstall the drivers and software and Check the cable and your usb ports are all working properly or your HD is done.
Mar 15, 2010 | Western Digital Passport 320GB External...
Western Digital External USB 2.0 Drive sometimes won't connect
problems like these are usually because of the usb connections, if the usb connection isnt strong enough i.e getting enough power,
try it on another pc if you can see if the problem persists
Sep 09, 2009 | Western Digital USB 2.0 External Enclosure...
My western digital Passport 320Gb usb drive is not detected
hi ,
looks like u primary hard drive is inside the laptop and so should be displayed as c : drive ,
and the reason , the external hard drive is not displayed seperately is csue ., the external HD  may be added as slave to the internal HD .,
can u tell me ,make a right click on c:/ drive and choose properties : and tell the totalsize dispalyed
Jul 23, 2009 | Western Digital Passport WDXML800UE...
Western Digital 320GB USB 2 My Book External Hard Drive
ALL hard drives need to be formatted... The question is, why wasn't this hard drive already formatted when you bought it?
Jan 09, 2009 | Western Digital 320GB MyBook External USB...
HP Computers using XP will not show drive to which Western Digital 320GB external harddrive is connected
Your usb device could be finished or your USB ports may not be strong enough/ enough power to run the device.
Jan 13, 2008 | Western Digital 320GB MyBook External USB...
SimpleTech SimpleDrive Pininfarina 500GB External USB 2.0 Hard Drive - Onyx Logo
315 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
