Kenmore Solid State 110-82294500 Does not spin and empty all water
Kenmore Solid State 110-82294500 Limited Edition Series belt drive Washing Machine. Purchased around 1986. The Limited Edition has a solid state control panel. I Have checked the lid switch and I think it is okay - when I put the two wires together the tub still does not spin. Can only access workings by the back lower panel or by tipping the washer over. Washer does not spin and completely empty of water. Please help!
  • 2071 Answers
SOURCE: Kenmore Series 70 Washing Machine - won't drain water
small_11_21.jpg For a detailed Washing Machine illustration, click below.
redarrow.gif Top Load Maytag Style
redarrow.gif Top Load Whirlpool Style
redarrow.gif Top Load GE Style
redarrow.gif Front Load Maytag Style
redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Some problems that can occur with your top-loading washing machine are:
There's an error code on the digital display
It doesn't work at all
It won't drain
It doesn't spin
It doesn't agitate
It's noisy
It leaks
It's off balance
There's no hot water
There's no cold water
It's slow to fill
There's no water at all
The clothes are wet after spinning
The cycle doesn't advance
There's no delicate or regular spin or agitate
It's overfilling
It's underfilling
The water temperature is incorrect
Hope this may help;
Posted on Aug 10, 2008
  • 115 Answers
SOURCE: GE top load washer does not agitate or spin.
sounds like a bad lid switch how old is it?
Posted on Dec 30, 2008
  • 88 Answers
SOURCE: Spin cycle does not work; I can open lid and push
There is likely a problem with the clutch, or transmission, or both. A quick check would be to LEAN (don't lay the machine on it's back) the washer back, and check for oil spray on the inside of the cabinet walls, or just a puddle of oil underneath. If there is oil, the transmission will need replaced, along with the clutch. When the oil leaks out, it tends to get into the clutch band and cause slipping, (clutch may look brown from heat, should be shiny) which is why you have to give it a boost with your hand. hope that helps some.
Posted on Apr 19, 2009
  • 5911 Answers
SOURCE: Kenmore 80 series lid switch
The following link explains how to replace one:
If the switch DOES require replacement, a new one can be purchased on line at, or Just use your model number as your search criteria. All three sites offer competitive pricing, so shop all three for the best price. If you still need assistance, please contact me and let me know. If my diagnosis is not correct, please post back and elaborate a bit more so I can assist you further. If your washer is not configured this way, or if you still have questions, please let me know.
Posted on May 11, 2009
  • 28 Answers
SOURCE: GE washer does not agitate or spin
There is a fusable link that is known to blow. The replacement is available. Open the front access panel, Remove the tape from the wires that are taped together near the top of the wiring harness,about 3/4 of the way up. You will see a wire that is covered with shrink wrap (White with Red stripe I think) Cut it out, check for open circuit with an ohm meter. If it is open, (no continuity) Replace it. I used a regular piece of wire as a jumper for testing till I got the new fuse. The fuse kit I got comes with 2 of these fusable links. One is for a spare.
Posted on Dec 05, 2009
My washer has slow drain and won't spin out completely. What might be the problem?
Repairing a Washer That Won't Drain or Spin ' ThriftyFun
Did everything look at everything that has to do with slow water draining. ReplyWas ... My washer washes fine, but it won't drain the water out or spin on any cycle. The guy who .... My Kenmore 417 washer will not completely empty and spin.
my washer won't spin and empty? ' Yahoo Answers
Jan 15, 2008 - If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing ... My Whirlpool washing machine won't empty all of the water after ...
Mar 21, 2013
Clothes washer won't spin clothes to drain water out?
Jun 11, 2008
More results from
Why won't my washer spin or drain? - Kenmore 110 Series ...'t+my+washer+spin+or+drain
iFixitMar 16, 2014 - Belt, Water Pump If the washer won't drain the pump belt might havebroken or might have worn ... It will fill with water but won't spin or drain on its own. ... Keep in mind that any water in the washer will pour out of the hoses when removed. ... I would have had to take apart entire washer to fix clogged pump.
My washing machine won't drain -
If your washing machine will spin but it won't pump water out, then the drain line is probably clogged up. In most washing machines, a small sock or small piece ..
Jan 05, 2016 | Washing Machines
Machine won't spin, therefore water cannont be emptied. The agitator works. I have a top open Kenmore 90 series machine.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
Aug 14, 2011 | Kenmore Washing Machines
Squeaking washing Machine during spin cycle
Loks that your machine is pretty old and hence the belt has hardened making a squeaking noise.
Good fix is get a new drive belt.
Quick fix is you could put some oil on the drive belt..... it will work for now but not a permenant solution.
Feb 01, 2010 | Kenmore Washing Machines
Kenmore washing machine not running through cycles.
The Timer is the most common problem. There is no belt, it is direct drive. Call appliance repair store in your area for replacment timer, or call Sears, they will mail it to you
Apr 06, 2009 | Kenmore 23822 Top Load Washer
Kenmore washer 80 series 110 model not spinning.
unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not.
need to know if it agitates or drains and just wont spin.
if it agitates but no spin or drain, then you have a bad lid switch.
if it wont agitate or spin, but will drain, then you have a broken drive coupling.
Jan 08, 2009 | Kenmore 24032\24036 Top Load Washer
Washer wont aggitate or spin
I think this is the direct drive model, no belt. There is a coupling between the motor and transmission that needs to be replaced. This is a common problem with that type washer.
Dec 21, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore series 70 washer
Dear Customer,
please rate this solution if it meets ur needs, else choose fixya..
Noisy or vibrates too much
  • General tips
  • Balance the load
  • Level the machine
  • Inspect the water pump for a blockage
  • Inspect the coupling
  • Inspect the transmission
  • Adjust the drive belt tension
  • Check the motor bearings
  • Check the drum brakes
Drum does not spin
  • Test the lid switch
  • Test the timer control
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
No water is entering the wash tub
or no hot water
or no cold water
Washer does not work but it does make noise
please rate this solution if it meets ur need, else choose fixya.Thank you..
Nov 11, 2008 | Kenmore 22422 Top Load Washer
Kenmore Washing Machine 70 series
When this machine is not spinning, the water should still be able to drain, as the motor drives the pump on the same shaft as the coupler for the tranny. Set to the spin setting and depress the lid switch, if the water still does not drain, you may have something stuck in your pump, which would also lock the motor shaft and not allow it to spin or agitate. If the water does drain, check the motor coupler, which is located between the motor and transmission, if broken, the motor will run but there is no drive to the transmission. Hope this helps...
Sep 14, 2008 | Kenmore 20722
Washing Machines Logo
Top Washing Machines Experts
