Question about Canon Cameras
I want to know what type of DC charger it uses.
Digital camera canon pc 1060,what type of DC charger does it use?
  • 431 Answers
Hi i am vortash just see how many batteries it uses .. each one will be 1.5 volts and add them up 2= 3volts etc then that is the voltage DC adapter you want then it just comes down to finding the right plug .They usually have a rubber cap over the dc input and it is usually a 1.5mm power plug ( looks like a tube with a hole in the center.) or sometimes a jack plug ..it should actually tell you in your manual if you do not have one you may be able to download one from this site free http://www.safemanuals.com hope this helps Regards Vortash
Posted on May 20, 2009
Free download software for digital camera pc 1060
You don't need any special software in order to use your camera.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program, such as Picasa.
Mar 09, 2012 | Cameras
Mau mencari baterai canon PC1060 i want baterai camera canon PC1060
i need to find a replacement LCD TFT Screen for Canon IXUS i SD10 digital camera Model number PC 1060
Mar 24, 2011 | Canon PowerShot SD10 / IXUS I Digital...
My name is Satheesbabu. I have a Canon Video camera MV 800i,purchased 6 years back. I lost the power chord. It is written on the camera 7.4V in one place and 8.4V at the power connection point. Please...
there are several power cords on ebay for your camera as well as new batteries if you need one. Do an ebay search for MV 800 charger, here is an example of one I found. http://cgi.ebay.com/Desktop-Charger-Canon-MV800i-Camcorder-/380317041118?pt=Batteries_Chargers&hash=item588ca981de#ht_3278wt_1141
Mar 04, 2011 | Canon Video Cameras
My Kodak Easyshare V1233 will only power up when plugged into the wall charger. Even after staying on the charger it will not power on unless plugged in.
Kodak has 3 types of charger that can be connected to a wall socket
USB AC Adapter - is especially useful when traveling, away from your computer, or just plain on-the-go. Connect your camera's USB cable to the adapter and plug it into a wall outlet to conveniently charge your camera.
5V AC Adapter - Provides in-camera charging for all KODAK EASYSHARE M and V Series Digital Cameras
Input: AC 100-240 V 50/60 Hz Output : DC 5.0 V
3V AC Adapter - Provides direct power to your camera but it will not charge the camera battery
Input: AC 100-240 V 50/60 Hz Output : DC 3.0 V
* You need to check the type of adapter your using. If your using the 5V AC adapter or USB adapter and the camera won't charge the battery contact kodak support line 1 800 235 6325 (23KODAK) for possible repair.
Nov 16, 2009 | Kodak Easyshare V1233 12.1MP Digital...
Replacement charger for Sharp Viewcam VL-Z3
As long as you can obtain a charger that is rated the same as the one for your camera it will not be a problem unless the original charger is a microprocessor controlled charger that has the ability to control and change the charging current as the battery charges.
A camera shop can check this out for you.
If it just a simple AC or DC charger, then you can simply use the connector from your original charger and join it either by soldering or with a screw terminal block(which you wrap in Insulating tape once fitted).
The main thing you need to be CERTAIN of is as to whether the original charger is an AC or a DC type.
This will be clearly indicated on the label on the charger.
Oct 25, 2009 | Sharp VL-Z5 Mini DV Digital Camcorder
Canon power adaptors
check your charger, if it's free voltage (110/240) you can use it in most countris. other wize you must buy a charger...
I hope this helps
Mar 24, 2009 | Canon EOS 40D Digital Camera
What kind/type of charger should be used with a Canon IXUS 86015?
DH68 Canon Digital IXUS 860 IS AC/DC Battery Charger
Don't forget to rate my answer a fixya.
Rob
Feb 19, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
I could not find driver to install on PC for PC-1060 canon digital camera
Please see the following post, as it outlines a much easier, faster, and less error prone alternative way to download your photos:
http://camerarepair.blogspot.com/2009/01/how-do-i-download-photos-or-pictures.html
Jan 26, 2009 | Canon PowerShot SD10 / IXUS I Digital...
My pc 1060 is dark when on
A Canon PC 1060 is a laser copier. Can you read and let us know exactly what model camera you have?
Nov 26, 2008 | Canon PowerShot SD10 / IXUS I Digital...
My Canon power shot S2 IS does not detect the batteries
There is a battery charge level sensor in the DC/DC internal converter board.
It seems that just started to fail such board.
You can try with other brand or type of AA batteries.
If still you have the same problem, you will need to have replaced the DC/DC converter board on your camera. This means a Camera repair shop service on it.
Best regards,
Nov 26, 2008 | Canon PowerShot A540 Digital Camera
Cameras Logo
44 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
