Question about Craftsman Garden
Tiller makes a loud grinding noise when i try to engage it.
I have acraftman 17'' counter rotating tine 5 hp tiller, model # 917.299710. It runs fine in all other gears but when I try to shift it into gear for it to till it makes a loud grinding noise. And when it does engage it keeps slipping out of gear and I have to engage it into gear again. Therefore when it goes into gear I have to strap a bungee cord around the gear shift and brace it to stay in gear without it slipping out and making the grinding noise.
5 Suggested Answers
pranaclimbin
  • 50 Answers
SOURCE: Yard Machines/Tiller
the tines are usually connected with shear bolts designed to break away when u hit something as a safety precaution so that u dont break anything in the transmission. its common that people dont know this and replace them with normal bolts. if this was done and the tines are not moving now chances are uve got a snapped gear shaft
Posted on Dec 04, 2008
steve_lima
  • 181 Answers
SOURCE: what type of lube is used in 917-294261 tiller gearbox?
80-90 gear lube
Posted on Jan 09, 2009
harlan301
  • 205 Answers
SOURCE: Tiller goes For./Rev. but wont drive forward with tines engaged
check the sher bolt on the tine to drive shaft. ill need model and ser number off the unit before i can go further with helping you thy changed them around a lot
Posted on Oct 13, 2009
  • 64 Answers
SOURCE: I have a Craftsman 17" rear tine tiller with
check to see if there is a snap ring on the shaft or a roll pin.
Posted on Feb 23, 2011
Troybilt tiller, rough,grinding noise when tines engaged
make sure there is nothing caught in them rubbing the shroud. check to be sure there is oil or lube in the drive transmission. if the oil leaks out it will make a grinding noise.
Jul 09, 2016 | Garden
I need an owners manual for this tiller
No make or model showed up in your post. Impossible to tell you what website to go to to get what you want.
Apr 04, 2016 | Garden
New tiller makes grinding noise when trying to run tillers
if it has a clutch
most small units just run a dog that you engage with a swift motion at low idle speed of the motor
have the tillers free above the dirt so they can turn with out any load to inhibit the dog engagement
May 20, 2015 | Garden
Craftsman rear tine tiller
If you cant move the tines by hand then I wouldn't think you sheared the pins, more like a gear box problem.
Mar 21, 2014 | Craftsman Garden
Tiller transmission frozen
I would take it apart and inspect the inner parts for damage
Sep 16, 2012 | Sears Craftsman 208cc* Counter Rotating...
Ryobi ry64400 tiller tines won't move engine runs fine
then you need to open the gear box and find out why if it has a forward and reverse the the shifting linkage it could be stuck in one gear and adding the other will lock it up as well
Apr 17, 2012 | Ryobi Cultivator
Craftsman rototiller mod. # 917-294260 won't go into gear
try rolling it a bit. Sometimes the gear doesn't fully mesh correctly. As you try to shift push or pull the tiller juuuust a bit back and forth and try to shift as you do that see what happens. Or go into neutral and rock it then try again.
May 05, 2010 | Craftsman 8.50 Torque Rating Dual...
Tiller tines will not turn. Engine runs fine...
Well hopefully it's not the transmission, as sometimes these tend to go. Another common but cheaper repair are the two bearings where the tines connect to the unit.
MORE THAN LIKELY.. The bearing is located above the worm gear housing, the part connected to the tines beneath the guard. This removal can be somewhat frustrating but if you remove it and remove the engine flange you'll be able to manually spin the drive shaft and see if it's the worm gear housing/lower bearings or if it's the more likely bearing on the clutch drum or the clutch itself.
Apr 06, 2010 | Honda 25cc 4-cycle Mini Tiller
Garden Logo
193 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
