Question about Bruder Cat Skid Steer Loader
I have a Bobcat 751 and cannot get the traction lock to unlock with the safety bar down. When I lift the safety bar the wheels will unlock but then I can't of course operate the hydraulics.
3 Suggested Answers
SOURCE: Bobcat 553 f - traction lock problem...help
sounds to me like a bad connection or a weak solenoid causing the voltage drop. a good alt charges at 14.25-14.50. it takes voltage to open solenoids not close them.
Posted on Sep 05, 2009
SOURCE: 1998 751 Bobcat ! How do you remove fuel tank ?
hi i had the same problem . lift the cab up and look back by the hydrulic pump the tank is under it but you do not need to pull it out there is a 90 degree fitting for the supply line pry out the fitting and the tank strainer is hooked to it , if not it fell off in the tank .if it is there it is must likely cloged up it is a cheap part to replace . well i hope this helps you
Posted on Sep 26, 2010
Just replaced ignition on bobcat 751 but still no power to switch
Trace power wire from battery to the ignition switch.
Nov 05, 2016 | Bobcat Garden
How do you bleed the hydraulics on a Bobcat 751 skid steer loader?
Hi Joseph:
Usually hydraulic components will "self clear" any air in the system just by trying to cycle through the functions a few times.
Have to ask the question............
Did you remove and replace the hoses one at a time, or did you take them all off at the same time?
The reason I ask is............ Could there be a remote possibility that any of the hose onnection locations were switched?
Sep 23, 2015 | Toys
What do I need to check when my 2000 bobcat Maxine stop moving. I replaced the sensor for the lift but it still won't move.
in bobcats /skid steer loaders there are a multitude of safety micro switches that have to all work to get motion the main one is on the bar that locks the operator in the seat, there may be one under /in the seat It would be best to have a service technician call to fix the fault
Jun 19, 2015 | Cars & Trucks
Bobcat 753 arms wont move up or down.lights flashing on bix box for valve .have replaced valve on the right side below seat but same problem no movement in arms could it be the sensor switch on the s
if safety bar sw was defective then unit wont move fwd or backwrd . and park brk would not disengauge , no sounds as if you got a defective block pressure sensor for arms ckt
bobcat dealer service should have code scanner for this, would be faster less expensive than just changing parts to find cause
Oct 02, 2014 | Bobcat 773
Have 763 bobcat loader keeps locking up with the sencers disengaging have notice the voltage guage going up to 18 volts at same time where should i start looking to fix this
Hello I have a 763 highflow bobcat all gauges read good I lock down the bar and go and it locks up about like the park brake is on but its off I can 10 to 15 foot and bam it locks up if someone has a idea id sure try whatever thanks.
Jan 09, 2013 | Clarke Bobcat 643
Does 4 wheel drive help you stop faster or is it just a traction device
Four wheel drive is a traction devise. Not a braking devise.
So, no it will not help you stop faster.
That said, on slippery conditions when you let off the gas the extra, "traction" will help slow you down if you do not slide.
Hope this helps you out.
Wayne
Dec 30, 2010 | Chevrolet Blazer Cars & Trucks
May 10, 2010 | Bruder Cat Skid Steer Loader
Hydrolic arms wont lift up or down on Bobcat skidsteer 873
CHECK ALL THE SAFTEY SWITCHES ON THE SAFTEY BAR . IF THE UNIT MOVES FORWARD AND BACKWARDS THE SWITCHES AREN'T THE PROBLEM
Aug 23, 2009 | Danfoss Sundstrand-sauer-danfoss Hydraulic...
Jul 19, 2009 | Bruder Cat Skid Steer Loader
Bruder Cat Skid Steer Loader Logo
Top Bruder Toys Experts
MarK
Level 1 Expert
ptpumpman
Marc Taylor
Are you a Bruder Toy Expert? Answer questions, earn points and help others
