Question about Whirlpool 24 in. DU1100XTPS Built-in Dishwasher
Whirlpool gold GU1200XTKS0 not cleaning
Leaves dirt on glasses after wash cycle
  • 677 Answers
SOURCE: Whirlpool gold dishwasher leaves film on dishes
the problem is hard water i bet. there is a new product out that actually filters the water going into your dishwasher. this i think is awesome becasue who knows whats in the water cleaning the dishes you eat and drink with. my dishes use to be white and spotty and after the first load with the filter they came out spotless. you can get it at www.dishwasherfilter.com. you will be glad you did. oh it goes under the sink and is small and affordable.
Posted on Jun 01, 2008
  • 338 Answers
SOURCE: my whirlpool gold doesnt clean properly there is a sandy residue
Sounds like you have a calcium issue with your water. if you have a water softner time to get it serviced. also you can get a cleaner for the dishwasher to clean it out called Dishwasher Magic.
Posted on Dec 04, 2008
CRTN
  • 716 Answers
SOURCE: Bad smell on dried dishes after being washed.Stale water smell.
Try Running Goo Gone Through It Although It Smells Like Oranges It Removes Stains As Strong As Sap. Also Try Running The Dry Cycle While Its Empty Two Or Three Times.
Posted on Jan 06, 2009
  • 949 Answers
SOURCE: Dishwasher won't reset, stays on gree-flashing light- Clean cycle
HI,
This is an indication that the water did not heat properly. I have put together some instructions on what can cause this and how to reset the control so you can use the dishwasher again. Follow the link below and let me know if this helps.
http://www.fixya.com/support/r4628906-flashing_or_blinking_green_clean_light_7
Posted on May 11, 2010
SOURCE: Whirlpool Gold quiet partner III, leaves dirty, greasy dishes
You need to clean out the trap in the bottom. It's a little involved to gain acess. You need to remove the bottom dish tray and set it aside. Then use a pair of pliars to hold the nut on the bottom spray arm and unscrew the arm from the nut. When you do it right, the spray arm will come off. Then you need to unscrew the two #2 phillips screws that hold the white water passage in the back and top. You can then turn it to the right and it will come out when you line up the 3 tabs. Then there are 4 Torx T20 screws that hold the screen on. Remove the screws and the screen. You should find all kinds of gunk, food, and who knows what else inside. You're not done yet, remove yet another T20 screw to acess the food grinder way at the bottom. You'll have to clean all the gunk out of there and make sure the screen and grinder aren't broken. Reassemble, and try doing another load, it should work much better. I found small chicken bones, wrappers, even a toothpick in mine.
Posted on Jan 29, 2011
Defrost cycle leaves water puddles on glass shelves
The drain is blocked with either ice or dirt. Open the freezer floor and you should see the drain.
Dec 08, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool dishwasher leaves white coating on plastic utensils like spatulas etcwhen finished washing. It also doesn't seem to clean a glasses and dishes as well as it used to. dishwasher is about 8years...
Hi
White film deposits are observed if water is hard or when you are using more detergent than needed, try filling detergent cup half way. Try using white vinegar after the wash cycle is complete, run a complete cycle. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results.
You can also add vinegar in the final rinse cycle.
Hope this helps... Please post back if more information is required.
Daniel
Aug 15, 2010 | Whirlpool Dishwashers
I am using the same quality products to wash the dishes as I have done in the past when I used this machine effectively but now--it doesn't seem to clean the dishes and leaves a film and food residue. My...
Dishwashers have a part usually called a separator or accumulator which traps the dirt from the water during the wash cycles while the water is continuously recycled to clean the dishes. At the end of the cycle the separator is flushed out and the trapped dirt goes down the drain. If it doesn't get flushed out the dirt builds up till it starts showing up on the dishes. Some separators have a hole on top and one on bottom with a valve which stops up one hole or the other depending which cycle it's running. The valve can be stuck or broken causing the problem.
See part 1 on this parts list and diagram. http://www.partselect.com/MultiModels.aspx?ModelNum=kuds03ft&searchTerm=img_6G53WSWK&RefineSearch=0&imgMfg=Whirlpool
May 17, 2010 | KitchenAid Architect? II S SERIES KUDS03FT...
Leaves specs of dirt on glasses, hard specs of dirt or hard food dries on glasses after wash and dry cycle are completed
1.you must fill the rinse agent
2.make sure you turn on water until its hot then start machine
3.add dishwashing soap
that will solve the problem
Feb 25, 2010 | Dishwashers
Whirlpool gold gu1200
Sounds like glass fragments against the pump impeller. This may jam the impeller and reduce water pump volume giving poor wash performance and possible inability to evacuate the wash tub. It will not go away and may cause the impeller to fail. Remove screens and get the glass out. Do not poke around with your fingers unless you like cuts.
Sep 26, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
No water going thru washer arms
remove the pump screen and, clean the pump
you probably have broken glass preventing the pump impeller from moving
May 29, 2009 | Whirlpool Gold Black-on-Black 25.4 cu. ft....
My whirlpool gold doesnt clean properly there is a sandy residue
Dec 04, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
are you in a hard water area such as florida ? do you have a water softener? if so take a can of frozen concentrate orange juice and put the frozen hunk in the bottom of dishwasher and run for one cycle. the citric acid will dissolve undisolved soap . this works much better. than vinegar which will only remain through the first cycle and then drain out as for the already grey glasses wash them in a solution of equal amounts red wine vinegar and water with just a touch of dish soap using a sponge.
Feb 16, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool Gold Dishwasher
Is The Motor Running During The Wash? If not you have a bad motor.
Jan 17, 2008 | Dishwashers
Whirlpool 24 in. DU1100XTPS Built-in Dishwasher Logo
29 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
