Question about Tablets & eReaders
Hard reset gemini d71 - Tablets & eReaders
How do i do a factory reset on my Gemini D7
The Gemini tablet line performs factory resets and firmware updates with an SD card. Performing a factory reset requires writing files to an SD card with a computer, then starting up the tablet with the SD card present in it. Be aware that it will erase all data on the tablet, but with it in a boot loop, that may be a moot point.
Knowing the specific model number of your tablet is critical. Flashing the incorrect information can cause worse problems than you are encountering now. Rather than send you to the D7 GEM7007 page, I will give you the general page that leads to all the possible tablet results and directions. Look for the link that matches the Model Number, not just the name.
Factory Reset Original Firmware ROM Image Flashing Instructions
You will most likely need:
An SD card appropriate for the tablet (SD, MicroSD, Etc)
A reader for the card for your computer (Attached reader will handle SD and MicroSD)
The ability to get the Tablet to completely turn off to start the process.
The first two can be purchased. The last one is up to whether the tablet has a hardware fault. If the tablet has any kind of broken hardware inside it (wear and tear, aging, or damage) the process may not work. In the event of hardware failure, replacement under warranty or without warranty may be the best solution.
Apr 25, 2015 | Android Gemini Tab
How do I do a auto hard reset on my polarold internet tablet pmid701c and can it be able to download Google plays tore
Differnt hard reset/factory wipe methods for tablet pc, Hard reset or factory wipe is amethod of formatting any android device ( tablet or mobile). by doing hard reset all the apps and files that are installed or created.
How do i hard reset a polaroid t7 internet tablet? - my, Cannot factory reset polaroid internet tablet. how to hard reset a polaroid tablet model # pmid705x? i`m locked out of my polaroid internet tablet model ptab7xc i. How to hard reset android phones & tablets, restore to, Under the personal data heading near the bottom, you'll see an option to perform a factory data reset. select this option. if you're running android 2.3 or above, you.Hard reset - mobile recovery website, Hard reset ' follow @hard_reset new.hardreset.eu site would you do a hard reset of your device to wipe the data and start over? if you are about to sell your.
[how to] perform a factory reset - acer android tablet forum, Do not perform this factory reset procedure if you have an unlocked tablet and/or a custom recovery!!!! the factory data reset is a standard feature in android devices.. S7 factory data reset - southern telecom, S7 factory data reset if you have set a p.word on your tablet and forgotten the p.word, follow the instructions below to reset the tablet.How to factory reset an android tablet - pc advisor, Factory reset android tablet,google, android, tablet comments. lordganzgee said: i cant go to setting optionshow to reset my google account or p.word in my tablet.
Feb 25, 2015 | Tablets & eReaders
My Gemini tablet has locked up and will not power down, is there anything I can do
there is usually a reset button somewhere on the unit, try that
Feb 09, 2015 | Android Gemini Tab
My Gemini 9.7 inch tablet has locked up and I am unable to power it off, is there anything I can do ?
Try this, i have hope that it can work,
long press the off key button, and some options will appear and one of the options is the off.
Loading issues please help xx
Hello chloe you ned to free some of the memory by closing all resent used apps and IF the tablet is unresponsive you may be requierd to perform a hard reset your tablet
Resetting your device to Factory Defaults If you need to reset your device to the factory default settings for any reason please follow the process below:
WARNING!!!
Please be aware any information currently on the device will be permanently erased by following this procedure.
  1. Go to applications screen and touch the settings button.
  2. Touch the Backup & reset option.
  3. Select Factory data reset.
  4. Leave the erase SD card option unticked & touch "Reset tablet".
  5. Touch "erase everything".
  6. The unit will now reset itself back to factory reset and any previous information/data will have been permanently erased.
Getting further help and support
Please see our support site below for further help and support with your device including how to install software updates if available and much more:
http://getsatisfaction.com/geminidevices
Manufakturer
http://www.geminidevices.com/7030.html
manual
http://www.geminidevices.com/manuals/GEM7030-Manual.pdf
Jan 05, 2015 | Android Gemini Tab
Keeps constantly restarting
Warning: All applications and personal files contained on the tablet will be erased. Only do this if you are unable to start your tablet.
  1. First, ensure the tablet has been switched off.
  2. Hold both the VOL+ and POWER buttons until the Gemini logo appears. Release both buttons.
  3. You should see a green robot on the screen with a red warning sign.
  4. Press & hold POWER then press VOL+ once, then release the POWER button. A menu will show on-screen.
  5. Using the VOL+ and VOL- keys you can move up and down to select the Factory reset option. Press POWER to select this option, then move down to YES and press POWER again.
  6. Once completed, press POWER to restart the unit.
Apr 13, 2014 | Tablets & eReaders
Forgot my screen lock pin
If you have forgotten the screen lock PIN, you will have to perform a factory reset on the device, which deletes all data including the PIN. This process differs between tablets and is not trivial. See their directions for your device at https://geminidevices.zendesk.com/entries/23857527-How-do-I-perform-a-factory-reset-on-my-tablet-
Mar 28, 2014 | Android Gemini Tab
Tablets & eReaders Logo
67 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
