Question about Nemco Countertop Food Warmer 6055A
Tripping gfci when warmer warms up it trips the gfci
  • 30 Answers
I don't know what kind of warmer you are referring to. If you are trying to run to many appliances off of the same circuit the gfci will trip. The gfci could be warn out or defective. If the warmer is drawing lots of amps or has a short that will also trip the gfci
Posted on Apr 20, 2016
GFCI wont reset, or, runs for 5 minutes and shuts off
Refrigerators should not be plugged into a GFCI outlet. The surge of current when the compressor starts up will trip the GFCI.
Apr 18, 2015 | Refrigerators
WHAT PUMP RUNS FINE FOR A WHILE THEN IT WILL TRIP THE GFI...
the pump may draw more amps then the gfci can handle, check cord from pump near gfci at time of trip, if the cord is warmer than usual than the gfci is too low rated
Oct 02, 2014 | Electrical Supplies
GFCI keeps tripping when pump is submerged
Install another GFCI
http://waterheatertimer.org/How-to-wire-GFCI.html
Do not use anything that trips GFCI in water.
Just get another one and be safe.
May 30, 2013 | Pool & Spa
Hello,I have an old jacuzzi vectra II hot tub (1988) 120 volt.the gfci on the unit trips every time the pump is on low speed with the thermostat calling for heat. there is no trip when there is no demand...
hi,
ok so when the pump is on high and the heater is running it doesent trip? you didnt say if it did. undo the heater leads so the pump is isolated completely. run the pump on the control centers gfci and see if it trips. if it does then try wiring directly - with an extension cord to a plug with a gfci in your house and see if it trips the gfci in your bathroom. if no trip inside house then bypass tubs gfci and run it with heater and pump through your bathroom gfci. if no trip then try and replace the tubs gfci, it gets pretty humid in the control center and gfci's have a semiconductor which which do fail after years of rough duty like that. if it trips the gfci in your house with the heater again it has a cracked heater element. craigslist always has old hot tubs and parts. you might have to buy a whole used old hot tub but that may be cheaper than a new heater box.
later
jm
Feb 22, 2011 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Delfield freezer 6151-S keeps tripping GFCI
Try it in a normal plug. Freezers and refridgerators just pull too much to be used on a GFCI. The more a GFCI is used the eaiser it trips.
Aug 31, 2009 | Delfield Freezer 6151XLSR Stainless steel
Keeps tripping circuit breakers bunn NHb
Hello
Coffee makers have a heating unit in them which draw a lot of current. If it is on the same circuit as refrigerator, toaster and other it will trip the breaker. Also, some breakers are more sensitive than others. Have an electrician run a separate circuit for the coffee maker outlet. Try running it in the dining room outlet, which I hope is separate from the kitchen outlets. Is the house old? Older homes have a lot of mixed up wiring.
John
Aug 09, 2009 | Bunn NHB Coffee Maker
Trips GFI circuit brakers
First of all, lets clarify what is going on. You say it trips the GFI breaker, so I'm assuming that it is not a GFCI receptacle that you are plugging into. So you are going to the electrical panel and resetting the GFCI breaker.  If it were a GFCI receptacle, have you tried other loads in this receptacle for 30-40 seconds, ie: Toaster, hairdryer, coffee pot? If everything works fine then there is something wrong with the ESP8XL. It would seem that there is a leakage path to ground from one of the conductors. If it is new, bring it back.
Jul 30, 2009 | Breville ESP8XL Espresso Machine
Gfci breaker keeps tripping
sometimes gfi outlets go bad and trip try testing with a heavy draw machine in it or just replace it and see if this fixes the problem
Jun 22, 2009 | Balboa Instruments Duplex Digital Panel 2...
Gfci breaker for spa
gfci's are designed to trip if they receive voltage on there ground/neutral side, therefore my vote is for Smithbrother I would say there is probably a partial short somewhere in you system.
Mar 15, 2009 | Spa Parts Plus GFCI, Circuit Breaker, 30...
Nemco Countertop Food Warmer 6055A Logo
279 people viewed this question
Top Nemco Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Nemco Kitchen Appliances - Other Expert? Answer questions, earn points and help others
