Ge wjsr2070b2ww agitator removal
Not agitating on normal cycle but does final spin
SOURCE: GE WASHER, MODEL# WJSE3110A0WW PROBLEM: WASHER
wont drain
Posted on Oct 06, 2008
jumptrout51
  • 3361 Answers
SOURCE: ge toploading washer will not agitate
Simply pull up on it very hard.
It will come off.
Posted on Mar 15, 2009
Bfsas1
  • 258 Answers
SOURCE: agitator doesn't spin during wash cycle
If The washer won't agitate
Check to make sure no clothing got wrapped around the agitator. Check the lid switch, timer, and drive belt, other potential causes, such as a bad transmission or bad agitate/spin solenoid, but they are much more involved.
if the washer won't spin, the lid switch, timer, drive belt, transmission, or agitate/spin solenoid could be the cause here as well. Sometimes if the load is unbalanced or too heavy, the washer won't spin. Take some of the clothes out and try the spin cycle again with a lighter load.
Here are the steps to replace the agitator.
1: Take the fabric softener dispenser off and pry off the agitator lid.
2: Use a socket wrench with an extension bar to remove the stud and seal.
3: Remove the agitator top and bottom.
4: Check the agitator clutch assembly (located in the agitator top) for excessive wear.
5: To replace, just reverse the directions.
Posted on Jun 29, 2009
SOURCE: will not go in to spin cycle
Remove agitator (it will pop off when pried) then you will find your answer. Mine was a broken tub collar to shaft.
Posted on Aug 18, 2009
  • 464 Answers
SOURCE: GE WDSR2080D4WW top load washer agitator - Is
pull out the agitator. this may be difficult because soap gets built up underneath and250 acts almost like a glue. use a leather belt and put it under the agitator and pull straight up. once you get it off you will see a bolt holding down a coupling. take the bolt out and replace the coupling with a new one. this should solve your problem with the machine not agitating. the part # for the bell coupling is: WH43X10009.
Posted on Oct 24, 2009
Testimonial: "thanks! we'll get back with you on if this works or not!"
I have a GE washer model # WHDRR418GWW. It is about 19 months old. It stopped agitating and spinning. It will fill with water and the timer/knob will go thru the cycles. But when it reaches the washing...
You have what is called "agitating dogs" there are usually 4 of them at the bottom of the agitator. They have small grippers which lock onto the agitator and agitates. If the washer is ever overfilled or over time filled to heavy this will wear down the nylon teeth on the "dogs". The top of the agitator will spin off, you will see a bolt inside at the bottom, remove bolt and the agitator will pull out. Google "agitating dogs on washer. It will give you pictures for a better understanding. If the belt was broken the washer would not drain, because the belt turns the pump. These dogs are about $5 and honestly easy to install. Good Luck.
Dec 04, 2010 | GE WHDRR418GWW 35 cu. ft. Washer
WJSR2070B2WW AGITATOR REMOVAL NOISY IN SPIN . AGITATOR SPINS BUT TUB DOESN'T.
got help on another site for free that told how to remove agitator which allwed me to see the metal part that connects inner drum to transmission had completely broken into two seperate parts. will replace.
anks
bobth
Dec 06, 2009 | GE Washing Machines
Agitator doesn't spin during wash cycle
Jun 29, 2009 | Washing Machines
Will not go in to spin cycle
May 09, 2009 | GE WBSR3140DW Top Load Washer
GE profile washing machine won't agitate it spins out, drains,
Pull the agitator out and check the drive collar splines.If you have the model I think you have just pull straight up on the agitator. Once removed you will see the drive collar with a 7/16 head bolt,remove it and pull off the collar.First before pulling it off spin it if splines are stripped it will spin freely.
Mar 25, 2009 | GE Profile WPRE6100G Top Load Washer
GE Top Load Washing Machine -- Agitator will not cycle
Agitator's don't spin on wash cycle.
I would suggest washing the clothes without soap until they rinse clear. If you have hard water, the soap will not easily rinse out of clothes, or off of you when you use soap to wash or shower.
Reduce the amount of soap you use in each wash if this is the case. It sounds like your washing machine is working right.
Jan 26, 2009 | GE WBSR3140DW Top Load Washer
Everything is working except the spin cycle
Sounds like the spin coil/brake solenoid is burnt out or broken. This is a coil situated on the motor plate under the machine with a lever attatched to it. When the machine goes into spin cycle, this solenoid pulls the brake away from the outer drum to allow the drum and agitator to spin together. The shaft that goes into this coil should move in and out freely. If tight, replace spin coil/brake solenoid.
Oct 31, 2007 | GE WSKS2060WWH Top Load Washer
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
